  2. Announcements
  3. πŸ’¬ Power Meter Pulse Sensor
183 Posts 40 Posters 92.4k Views 37 Watching
    The problem with "unsigned long" is that it can have different size based on platform it's compiled on.
    Like @mfalkvidd says, use int32_t, uint32_t, int16_t and uint16_t which has a fixed width.
      I was suspecting something like that, but I was not sure if changing variable type would affect something else
        Ok, I got it working. On wemos it doesn't count pulses though. On domoticz does it have to configured as the value computed or from device? I'm asking because if you disconnect the sensor, on domoticz I keep seeing the same power reading
          BTW, is there a way to have the pulse meter running on gateway? I got stuck because at startup it asks the controller the last count value and since the controller is not yet connected it just doesn't work.
          A rejoe2R 2 Replies Last reply
            A
            A
            arifuleee
            @gohan for the first time use only the watt value....that time oldcounts will not bother.....
              What do you mean? And how do I keep the count of the pulses if I don't get it from controller?
                @hek is it me or the WATT readings are never sent? What could it be? Only V_VAR1 and V_KWH are sent.
                  rejoe2R
                  rejoe2R
                  rejoe2
                  @gohan How about
                  #define MY_TRANSPORT_WAIT_READY_MS 2000
                  This will start up your code so you won't miss any pulses until controller is ready.
                  You may ask for the last known Value in presentation(), then it will be fetched as soon as the controller is really there after startup. This could/should be combined with a bool pcReceived, so you may decide to either add the value received from controller to the counts the node meassured in between or just use the received value (starting from second time value is received from controller).
                    That actually is not that critical, as I am going to move to MQTT and that should be working anyway. Right now it is working on a UNO with NRF24, but my biggest issue is the WATT reading that it is missing
                      Any more suggestions on the Watt issue?
                        Did you by any chance change SLEEP_MODE to true?
                        gohanG 1 Reply Last reply
                          No, I get every pulse reported as soon as it is detected.
                            wrote on last edited by gohan
                            #113
                            I think I found a problem: the WATT calculation is returning values over 172000 watts and since I put 10000 as the max value, it was not sending anything. I double checked my energy meter and indeed it is 1000 pulses per KWH and this is what I set in sketch
                              @hek I said I found the problem, I didn't say I know how to solve it πŸ˜…
                                Here is the log I get from node
                                7230 TSF:MSG:READ,0-0-250,s=1,c=2,t=24,pt=0,l=7,sg=0:1682675
                                rece
                                Received last pulse count from gw:1682675
                                11817 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:528
                                Watt:528
                                Watt:197065
                                21820 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682677
                                21913 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6770
                                Watt:196807
                                36824 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682679
                                36917 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6790
                                Watt:197368
                                51827 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682681
                                51920 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6810
                                Watt:196850
                                Am I the only one using this sketch?
                                  mickecarlsson
                                  Please post you sketch.
                                    it is the one in https://www.mysensors.org/build/pulse_power
                                      mickecarlsson
                                      wrote on last edited by mickecarlsson
                                      #118
                                      How is the pulse counter set up? Is it connected to the S0 port?
                                      Edit:
                                      If you are using S0 it is vital that you use a pull down resistor, if you dont’t have that you get false pulses.
                                      pulse connection
                                        I'm using the lm393 light detector. Domoticz is able to do a calculation from the pulses to give a Watt value and it is correct but it does it every 5 minutes and it is too slow for me
                                          @gohan - is Domoticz updating anything (except switches) faster than 5 min? I dont think so...
                                          S 1 Reply Last reply
                                          With your input, this post could be even better πŸ’—
