  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
    Did you by any chance change SLEEP_MODE to true?
    @hek I said I found the problem, I didn't say I know how to solve it 😅
      Here is the log I get from node
      7230 TSF:MSG:READ,0-0-250,s=1,c=2,t=24,pt=0,l=7,sg=0:1682675
      rece
      Received last pulse count from gw:1682675
      11817 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:528
      Watt:528
      Watt:197065
      21820 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682677
      21913 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6770
      Watt:196807
      36824 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682679
      36917 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6790
      Watt:197368
      51827 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682681
      51920 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6810
      Watt:196850
      Am I the only one using this sketch?
        mickecarlsson
        Please post you sketch.
          it is the one in https://www.mysensors.org/build/pulse_power
            mickecarlsson
            wrote on last edited by mickecarlsson
            #118
            How is the pulse counter set up? Is it connected to the S0 port?
            Edit:
            If you are using S0 it is vital that you use a pull down resistor, if you dont’t have that you get false pulses.
            pulse connection
              I'm using the lm393 light detector. Domoticz is able to do a calculation from the pulses to give a Watt value and it is correct but it does it every 5 minutes and it is too slow for me
                sundberg84S
                sundberg84S
                @gohan - is Domoticz updating anything (except switches) faster than 5 min? I dont think so...
                S 1 Reply Last reply
                  If you send the watt reading faster it updates like the switch, anyway I need the watt values for node-red also
                    Could it be the Light sensor is triggering more interrupts from each pulse?
                    • NiklasON NiklasO
                      Just changed from 1-wire counter to MySensors for logging my power consumption. Using the same LED detector as I did when using 1-wire. Also changed watt limit to 20 000 (my heat pump likes to use 9-10kW sometimes). The wires from the old 1-wire net now provide power for the new MySensors-sensor. I have 10 000 led blinks per kWh. Had som crazy counter values with 1-wire that totally messed up the graphs and haven't seen anything like that with this sketch. Let's hope it stays that way. ;) Dumping data to Domoticz. This sensor gives me higher resolution as a bonus. The 1-wire counter was read every minute, this every 20-sec. ;-)
                      My old 1-wire counter with one crazy value messing upp all the graphs:
                      I know that you can hold shift and click the value that is crazy to make the graphs show up good but you loose the data for the full day. That's not good. ;-)
                      henninneH
                      henninneH
                      henninne
                      @niklaso
                      Hi Niklas,
                      I know this is a very old post, but its worth a try. How did you get out the daily Kwh usage? As default my sensor only gives Watts and Kwh (accumulated from start), I have tried to run a Scene in Vera UI7 where there are a function in the sensor called resetKWh(), but it looks like it doesn't do anything. Any tips would be great, thanks.
                      Henning
                      • sundberg84S sundberg84
                        smilvert
                        @gohan I think it is a little tricky to update domoticz every minute but try update the sql-file, see the domoticz forum
                        https://www.domoticz.com/forum/viewtopic.php?t=10183
                          The main issue is the fact that the sensor is not calculating the instant power correctly
                          xydixX 1 Reply Last reply
                          • D
                            DaTim69
                            I created this kWh sensor with the TCRT5000 IR Barrier Line Track Sensor.
                            My powermeter is a ferarrismeter with 375 rotations per kWh.
                            I also had the problem with spikes in the power usage. But after long...too long investigation I solved the problem.
                            At my config it was a double issue.
                            Issue 1.
                            The problem is the pulse width of the rotation.
                            The pulse are at night ( low power) much wider that during the day when more power is consumed. At night the spikes in power usage where huge.
                            Issue 2.
                            Switching on/off the halogen light causes spikes and related to also strange power measurement.
                            Solution:
                            I added a second arduino mini pro as a pulse regulator between the TCRT5000 and the power meter arduino.
                            this arduino triggers on Rising and will always give a 100ms puls. Als debounce is handled (spikes).
                            I don't upload the sketch here, I'm a beginning programmer on arduino. It's made on " trail and error" but it functions as it supposed to do.
                            If someone wants a copy feel free to contact mee
                              xydixX
                              xydixX
                              xydix
                              @gohan Did you solve this?
                              I get very high watt usage as well. Sometimes like 40 000 - 130 000 watt if I check the serial monitor.
                              Of course, those values will never be sent to the controler.
                                Nope, I am looking at other things now. Very little time available for too many things. I'm looking at buying CT clamp and do a more direct measurement.
                                • xydixX
                                  xydixX
                                  xydix
                                  wrote on last edited by xydix
                                  #129
                                  Okay. Really annoying. Check this.
                                  Received last pulse count from gw:2527
                                  Watt:121065
                                  22235 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2539
                                  22246 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5390
                                  Watt:121621
                                  42238 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2551
                                  42250 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5510
                                  Watt:121342
                                  62239 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2563
                                  62251 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5630
                                  Watt:121539
                                  82240 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2575
                                  82251 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5750
                                  Watt:121951
                                  102239 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2589
                                  102250 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5890
                                  Watt:122067
                                  122243 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2601
                                  122254 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.6010
                                  The plus count seems OK, right?
                                  My energy meter is 1000 pluses /kwh
                                  Here is my sketch. I use Home assistant so i created three sensors for this as I don't think V_VAR1 is supported with S_POWER.
                                  Otherwise it is the standard example.
                                   * Version 1.0 - Henrik EKblad
                                   * This sketch provides an example how to implement a distance sensor using HC-SR04
                                   * Use this sensor to measure KWH and Watt of your house meeter
                                   * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                                   * The sensor starts by fetching current KWH value from gateway.
                                   * Reports both KWH and Watt back to gateway.
                                   * Unfortunately millis() won't increment when the Arduino is in
                                   * sleepmode. So we cannot make this sensor sleep if we also want
                                   * to calculate/report watt-number.
                                   * http://www.mysensors.org/build/pulse_power
                                  // Enable debug prints
                                  #define MY_NODE_ID 78
                                  #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                                  #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
                                  #define MAX_WATT 20000          // Max watt value to report. This filetrs outliers.
                                  #define WATT_CHILD_ID 1              // Id of the sensor child
                                  #define KWH_CHILD_ID 2
                                  #define PC_CHILD_ID 3
                                  unsigned long SEND_FREQUENCY =
                                      20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                                  double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                                  bool pcReceived = false;
                                  unsigned long oldPulseCount = 0;
                                  unsigned long oldWatt = 0;
                                  double oldKwh;
                                  unsigned long lastSend;
                                  MyMessage wattMsg(WATT_CHILD_ID,V_WATT);
                                  MyMessage kwhMsg(KWH_CHILD_ID,V_KWH);
                                  MyMessage pcMsg(PC_CHILD_ID,V_VAR1);
                                    request(PC_CHILD_ID, V_VAR1);
                                    pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                                    attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                                    lastSend=millis();
                                    present(WATT_CHILD_ID, S_POWER);
                                    present(KWH_CHILD_ID, S_POWER);
                                    present(PC_CHILD_ID, S_CUSTOM);
                                    unsigned long now = millis();
                                    if (pcReceived && (SLEEP_MODE || sendTime)) {
                                      if (!SLEEP_MODE && watt != oldWatt) {
                                        if (watt<((unsigned long)MAX_WATT)) {
                                        Serial.print("Watt:");
                                        Serial.println(watt);
                                        oldWatt = watt;
                                      // Pulse cout has changed
                                      if (pulseCount != oldPulseCount) {
                                        send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                                        double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                                        oldPulseCount = pulseCount;
                                        if (kwh != oldKwh) {
                                          send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                                          oldKwh = kwh;
                                      lastSend = now;
                                    } else if (sendTime && !pcReceived) {
                                      // No count received. Try requesting it again
                                      lastSend=now;
                                    if (SLEEP_MODE) {
                                      sleep(SEND_FREQUENCY);
                                    if (message.type==V_VAR1) {
                                      pulseCount = oldPulseCount = message.getLong();
                                      Serial.print("Received last pulse count from gw:");
                                      Serial.println(pulseCount);
                                      pcReceived = true;
                                  void onPulse()
                                    if (!SLEEP_MODE) {
                                      unsigned long interval = newBlink-lastBlink;
                                      if (interval<10000L) { // Sometimes we get interrupt on RISING
                                        return;
                                      watt = (3600000000.0 /interval) / ppwh;
                                      lastBlink = newBlink;
                                    pulseCount++;
                                  Anyone got any ideas?
                                  BTW. First i tried the original example sketch, unmodified, with the same result.
                                    That's pretty much the same problem as I have
                                    • xydixX
                                      xydixX
                                      xydix
                                      I think i solved this.
                                      I don't know if it is a good solution.
                                      Maybe it is possible to solve in the code?
                                      I added a 0,1uf ceramic capacitor between DO and GND on the LM393.
                                      Then i tuned the LM393 until i had it blink as expected.
                                      I think, in my case the LED pulse from my meeter was to short, it gives a very short blink.
                                      Anyway.
                                      I tested it all day and it seems fine now.
                                        Are you getting instant power measurements correct?
                                        • xydixX
                                          xydixX
                                          xydix
                                          #133
                                          Yes. I guess.
                                          I don't have anything to compare with but i think it is accurate.
                                          I have a 1000blink/kwh
                                          Example:
                                          Node send state every 20 sec.
                                          pulsecount: 8 pulses every 20 sec.
                                          Instant power in W is about 1400W
                                          8 pulses x 3 = pulses /minute =24
                                          24 pulses x 60 min = pulses /hour = 1440.
                                          Edit.
                                          Now I get a new value every 20 sec, before I didn't get any value (W) from the node at all because it was too high. I only received pulse count and kWh earlier.
