  3. Wiring plain DHT22 chip
4 Posts 2 Posters 1.7k Views 1 Watching
  • solaS
    solaS
    sola
    Hi All,
    As a MySensors noob, I ordered a standalone DHT22 chip (4 pin) instead of a module (3-pin) - didn't notice the difference.
    I found a wiring diagram on the Adafruit site (https://learn.adafruit.com/dht/connecting-to-a-dhtxx-sensor) which seems to use a plain DHT chip like myself.
    Is this wiring OK for the Mysensors library? Will it read the sensor the same way as from a module?
    Any help is appreciated.
    • solaS sola
      Hi All,
      @Andras-Soltesz - Hi and welcome Andras!
      No problem, wire the DHT like the link and use the Mysensors sketch (https://www.mysensors.org/build/humidity) and everything will work out fine!
      Just note that data input on the arduino uses D2 on the adafruit link but standard defined is D3 for MySensors.
      • solaS
        solaS
        sola
        Thanks, I will try it out.
        • solaS
          solaS
          sola
          It works, many thanks.
          I used a 4K7 resistor as pull-up and it seems to be enough.
