  3. My 2AA battery sensor
90 Posts 27 Posters 126.7k Views 36 Watching
  • S
    sineverba
    This post is deleted!
    • S
      sineverba
      Sorry for the noob question...
      I would re-create your setup. At which point of it you insert the multimeter to measure the current?
      Is it ok to "interrupt" the ground (proximity to the step up) and measure the current there?
      Thank you
      m26872M 1 Reply Last reply
      • S sineverba
        Thank you
        m26872M
        m26872M
        m26872
        @sineverba Just cut one of the battery wires of the finished assembly. Solder together again when your done measuring.
        • P
          P
          palmerfarmer
          Has anyone got a V2 version working for this?
          F 1 Reply Last reply
          • P palmerfarmer
            F
            F
            flopp
            @palmerfarmer said in My 2AA battery sensor:
            Do you mean running with MySensors 2.3?
            • P
              P
              palmerfarmer
              Any Ver 2.xx,
              So I have cobbled together/hacked this and it seem to work, battery has stayed at 97% for 2 weeks now. Feel free to Hack about and improve i have this mounted on an easyPCB board, x2AA batteries, NRF radio, BME280 with a 3.3v convertor .
              * use mysensors library 2.2.0
              * ALL WORKING AND TESTED ON EASY PCB BOARD WITH BATTERY SAVING CODE 29/11/18
              * Time SET to 15 mins
              * also added BME280.writeMode (smSleep); to reduce quisecent to current to 40uA
              * BME280 sensor connections: 3.3v, 0V, SCL to A5, SDA to A4, BAT to A0
              //Enable debug prints to serial monitor
              #define MY_RF24_PA_LEVEL RF24_PA_MIN //settings are MIN, LOW, HIGH, MAX
              #define MY_NODE_ID 18
              #include <Wire.h>
              #include <BME280_MOD-1022.h>
              // BME280 libraries and variables
              // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code
              // Written originally by Embedded Adventures
              // https://github.com/embeddedadventures/BME280
              #define BARO_CHILD 0
              #define TEMP_CHILD 1
              #define HUM_CHILD 2
              unsigned long SLEEP_TIME = 15*60000;  // sleep time between reads (seconds x*1000 milliseconds)
              //unsigned long SLEEP_TIME = 20000;  // Debug test time 20 seconds
              int oldBatteryPcnt = 0;
              long interval = 1000;                // 1 min interval at which to send (milliseconds)
              long previousMillis = interval;        // will store last time data was sent
              const float ALTITUDE = 0; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
              const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
              enum FORECAST
                STABLE = 0,     // "Stable Weather Pattern"
                SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
                CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
                UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
                THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
                UNKNOWN = 5     // "Unknown (More Time needed)
              const int LAST_SAMPLES_COUNT = 5;
              float lastPressureSamples[LAST_SAMPLES_COUNT];
              // this CONVERSION_FACTOR is used to convert from Pa to kPa in the forecast algorithm
              // get kPa/h by dividing hPa by 10
              #define CONVERSION_FACTOR (1.0/10.0)
              int minuteCount = 0;
              bool firstRound = true;
              // average value is used in forecast algorithm.
              float pressureAvg;
              // average after 2 hours is used as reference value for the next iteration.
              float pressureAvg2;
              float dP_dt;
              boolean metric;
              MyMessage tempMsg(TEMP_CHILD, V_TEMP);
              MyMessage humMsg(HUM_CHILD, V_HUM);
              MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
              float getLastPressureSamplesAverage()
                float lastPressureSamplesAverage = 0;
                for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                  lastPressureSamplesAverage += lastPressureSamples[i];
                lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                return lastPressureSamplesAverage;
              // Algorithm found here
              // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
              // Pressure in hPa -->  forecast done by calculating kPa/h
              int sample(float pressure)
                // Calculate the average of the last n minutes.
                int index = minuteCount % LAST_SAMPLES_COUNT;
                lastPressureSamples[index] = pressure;
                minuteCount++;
                if (minuteCount > 185)
                  minuteCount = 6;
                if (minuteCount == 5)
                  pressureAvg = getLastPressureSamplesAverage();
                else if (minuteCount == 35)
                  float lastPressureAvg = getLastPressureSamplesAverage();
                  float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                  if (firstRound) // first time initial 3 hour
                    dP_dt = change * 2; // note this is for t = 0.5hour
                  else
                    dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                else if (minuteCount == 65)
                  if (firstRound) //first time initial 3 hour
                    dP_dt = change; //note this is for t = 1 hour
                  else
                    dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                else if (minuteCount == 95)
                    dP_dt = change / 1.5; // note this is for t = 1.5 hour
                  else
                    dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                else if (minuteCount == 125)
                  pressureAvg2 = lastPressureAvg; // store for later use.
                    dP_dt = change / 2; // note this is for t = 2 hour
                  else
                    dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                else if (minuteCount == 155)
                    dP_dt = change / 2.5; // note this is for t = 2.5 hour
                  else
                    dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                else if (minuteCount == 185)
                    dP_dt = change / 3; // note this is for t = 3 hour
                  else
                    dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                  pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                  firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
                int forecast = UNKNOWN;
                if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
                  forecast = UNKNOWN;
                else if (dP_dt < (-0.25))
                  forecast = THUNDERSTORM;
                else if (dP_dt > 0.25)
                  forecast = UNSTABLE;
                else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
                  forecast = CLOUDY;
                else if ((dP_dt > 0.05) && (dP_dt < 0.25))
                  forecast = SUNNY;
                else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                  forecast = STABLE;
                else
                  forecast = UNKNOWN;
                return forecast;
                 analogReference(INTERNAL1V1);
              #else
                 analogReference(INTERNAL);
                metric = getControllerConfig().isMetric;  // was getConfig().isMetric; before MySensors v2.1.1
                Wire.begin(); // Wire.begin(sda, scl)
                #else
              void presentation()  {
                sendSketchInfo("BME280_BAT_V2", "V2e.");
                // Register sensors to gw (they will be created as child devices)
                present(BARO_CHILD, S_BARO);
                present(TEMP_CHILD, S_TEMP);
                present(HUM_CHILD, S_HUM);
              // Loop
                 // get the battery Voltage
                 #ifdef MY_DEBUG
                 Serial.println(sensorValue);
                 #ifdef MY_DEBUG
                 float batteryV  = sensorValue * 0.003363075;
                 Serial.print(batteryV);
                 Serial.println(" V");
                 Serial.print(batteryPcnt);
                 Serial.println(" %");
                   // Power up radio after sleep
                   oldBatteryPcnt = batteryPcnt;
               //  sleep(SLEEP_TIME);
              if(currentMillis - previousMillis > interval) {
                  // save the last time sent the data
                  previousMillis = currentMillis;
                wait(500);
                // need to read the NVM compensation parameters
                BME280.readCompensationParams();
                // Normal mode for regular automatic samples
                BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
                BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
                BME280.writeOversamplingPressure(os16x);    // pressure x16
                BME280.writeOversamplingTemperature(os8x);  // temperature x8
                BME280.writeOversamplingHumidity(os8x);     // humidity x8
                BME280.writeMode(smNormal);
                  // Just to be sure, wait until sensor is done mesuring
                  while (BME280.isMeasuring()) {
                // Read out the data - must do this before calling the getxxxxx routines
                BME280.readMeasurements();
                float temperature = BME280.getTemperatureMostAccurate();                    // must get temp first
                float humidity = BME280.getHumidityMostAccurate();
                float pressure_local = BME280.getPressureMostAccurate();                    // Get pressure at current location
                float pressure = pressure_local/pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255); // Adjust to sea level pressure using user altitude
                int forecast = sample(pressure);
                if (!metric)
                  // Convert to fahrenheit
                  temperature = temperature * 9.0 / 5.0 + 32.0;
                Serial.println();
                Serial.print("Temperature = ");
                Serial.print(temperature);
                Serial.println(metric ? " °C" : " °F");
                Serial.print("Humidity = ");
                Serial.print(humidity);
                Serial.print("Pressure = ");
                Serial.print(pressure);
                Serial.println(" hPa");
                Serial.print("Forecast = ");
                Serial.println(weather[forecast]);
                Serial.println();
                  send(tempMsg.set(temperature, 1));
              wait(50);
                  send(humMsg.set(humidity, 1));
              wait(50);
                  send(pressureMsg.set(pressure, 2));
              wait(50);
              sleep(SLEEP_TIME);
              • P
                P
                palmerfarmer
                wrote on last edited by palmerfarmer
                #87
                11months on battery at 87%... still working!0_1574260268012_BME280 battery.JPG
                TRS-80T 1 Reply Last reply
                • P
                  P
                  palmerfarmer
                  • P palmerfarmer
                    TRS-80T
                    TRS-80T
                    TRS-80
                    @palmerfarmer,
                    That project box is perfect! Where did you find it (it doesn't look printed)?
                    • P
                      P
                      palmerfarmer
                      I got it from CPC in the UK which are owned by Farnell
                      https://cpc.farnell.com/hammond/1593qgy/case-with-bat-compart-110x66x28mm/dp/EN82140
                      You may have to make a slight mod to the board or enclosure to make it fit.
                      good luck
