  3. Ethernet gateway broken ? (W5100)
3 Posts 2 Posters 1.4k Views 2 Watching
    A Former User
    wrote on last edited by [[global:former-user]]
    I'm using mysensors 2.0.0-beta with a W5100 ethernet gateway for quite a while now, and I decided to update it to the 2.0.0 stable.
    I can't manage to make it work.
    On 2.0.0 stable it keeps rebooting
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.0.250
    IP: 192.168.0.250
    IP: 192.168.0.250
    IP: 192.168.0.250
    On 2.0.1-beta, il's having a different behavior, if I connect a telnet session it's stop rebooting, but As soon as I try to pass a command (like 0;0;3;0;2;) the telnet session break and the gateway reboot.
    I never get the message "Gateway startup complete", is it still send when startup is finished ?
    I tried to downgrade to 1.5.4 and it's working, telnet ok. So it's not hardware related.
    Am I missing something ?
    Unfortunatly I haven't backup my 2.0.0-beta version so I'm quite blocked for the moment :disappointed:
    YveauxY 1 Reply Last reply
    • ? A Former User
      IP: 192.168.0.250
      IP: 192.168.0.250
      IP: 192.168.0.250
      IP: 192.168.0.250
      YveauxY
      YveauxY
      @dark-nico It's a known-issue. Please refer to this thread for a solution: https://forum.mysensors.org/topic/4628/solved-mysensors-2-0-ethernet-gateway-enc28j60-restart-ip-issue/47
        A Former User
        Hi
        Thank you!
        I've used the search fonction but with no luck apparently.
        Thanks again for the fast answer.
