  3. Several ESP8266 Gateways in parallel supported?
8 Posts 4 Posters 2.5k Views 3 Watching
  • ragflyerR
    ragflyerR
    ragflyer
    I am experiencing many ghost sensors and new sensor variables like wind sensors etc. which I have not connected nor built at all.
    It happened after connecting a second Wireless Gateway to reach some sensors in the garden.
    Is this actually supported or should I find another way to increase range?
    Thank you
    chrilleC 1 Reply Last reply
    • ragflyerR ragflyer
      Thank you
      chrilleC
      chrilleC
      chrille
      It may depend on your controller, but it's possible. I have two ESP8266 gateways connecting to domoticz. One is using NRF24 and the other RFM69. If you want to build two NRF24 gateway I think you need to change the frequency/channel of the second gateway, and the attached sensors
      • Jan
      • chrilleC chrille
        • Jan
        @chrille, @ragflyer - and its not possible to have them working in the same time, parallel. If you attach sensor to one gateway in Domoticz I have not found any way to change to the other gateway, not automatically (which would be nice if one gw fails) or manually.
        • sundberg84S sundberg84
          chrilleC
          chrilleC
          chrille
          Maybe you should consider building a dedicated repeater node instead?
          • ragflyerR
            ragflyerR
            ragflyer
            Thanks, I guess the repeater node will be the best solution but I couldn't find the official documentation for enabling it. Solved the problem with the antenna mod for now:
            https://forum.mysensors.org/topic/1851/extending-range-of-regular-nrf24l01
              @ragflyer documentation on repeaters is available at https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes
              Could you describe where you expected it to be? Maybe we should add a link or page somewhere.
              • ragflyerR
                ragflyerR
                ragflyer
                Yes a link on https://www.mysensors.org/about/network would be great as I didn't find any mentioning of repeaters other than forum posts which did not end in a definite success message. To me it seemed a bit like a cool but undocumented feature :)
                  Thanks @ragflyer, that sounds reasonable. I'll see what I can do.
