  3. Domoticz
  4. lost serial gateway after un plug power Rpi
45 Posts 8 Posters 20.4k Views 7 Watching
  • tbowmoT tbowmo
    @Reza
    Not that I know of..
    R
    R
    Reza
    @tbowmo
    I'm looking for a solution for this issue :)
    thank you
    • peerkersezuukerP
      peerkersezuukerP
      peerkersezuuker
      I have the same problem, i posted a question at the Domoticz Forum :
      Not reconnecting serial portt
      Greetz Peer
      Domoticz / My Sensors / Z-Wave
      https://www.kermisbuks.nl
      • bjacobseB
        bjacobseB
        bjacobse
        Somehow I think it's more related to the linux kernel than it's a mysensors or Domticz related issue
        I would start to check which linux kernel you are using with uname -a and then start to search from this
        Maybe it could also be USB power related? Try to use a better USB power supply to your RPI
        https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=53832
        • dbemowskD
          dbemowskD
          Why not connect the gateway to one of the onboard serial ports through the GPIO header? I have an Orange Pi which has a GPIO header that is pin compatible with the Raspberry Pi and I ran my gateway from there with no problems. I used pins 6, 8 and 10 which for me was /dev/ttyS3:
          The trick in doing this with Domoticz is to create a synlink. The reason for this is that Domoticz looks for a ttyUSBxxx device, so with the symlink you are basically tricking Domoticz into thinking that the onboard serial port is USB. In my case I created a symlink for ttyS3 to ttyUSB30 like this:
          sudo ln -s /dev/ttyS3 /dev/ttyUSB30
          This way you avoid having the problem of USB devices not being detected on boot.
          • peerkersezuukerP
            peerkersezuukerP
            peerkersezuuker
            Thank's for the answers to this problem.
            They didn't work for me, but i think i solved mine.
            Stop monitoring the serial port for data from a terminal session.
            See my post at Domoticz forum.
