  3. Domoticz
  4. lost serial gateway after un plug power Rpi
45 Posts 8 Posters 20.4k Views 7 Watching
  • sinczeS sincze
    No problem.
    I had problems with original FTDI arduino.
    For testing i changed to 340 arduino that worked.
    Than ordered new FTDI arduino.. And it worked again.
    Do you have a spare ARDUINO that you can flash with your gateway software??
    If your gateway is not assigned a /dev/ttyUSBx address It will not work.
    R
    R
    Reza
    @sincze
    sorry again , i am beginner :)
    first i do this Instructions (https://www.domoticz.com/wiki/PersistentUSBDevices) and dont work , after this , @tbowmo told me :
    lsusb
    -> provide the output
    unplug / plug the usb device
    once more in your terminal
    lsusb
    -> provide output
    also i do :
    dmesg
    so now after unplug/plug , my gateway dont detect and dont work
    • R
      R
      Reza
      i change usb port for my gateway and this working now , but after reset my problem again,,,,
      • sinczeS sincze
        No problem.
        R
        R
        Reza
        @sincze
        i use a spare ARDUINO but there is my problem yet...
        • tbowmoT tbowmo
          after you have powered on your raspberry, you log in
          then at the command prompt you type:
          lsusb
          lsusb
          -> provide output
          the same for dmesg. In a terminal type "dmesg" hit return, and provide the output, both before you unplug a device that is not working, and after you have done it, and it is working.
          R
          R
          Reza
          wrote on last edited by Reza
          #34
          @tbowmo
          now i run this
          lsusb
          lsusb
          -> provide output
          but after unplug power . there is my problem yet
          • sinczeS
            sinczeS
            sincze
            MySensors Evangelist
            @Reza just to be sure: unplug power you mean:
            Unplug the power cord from raspberry right?
            Not unplug and replug FTDI device?
            R 1 Reply Last reply
            • sinczeS sincze
              R
              R
              Reza
              my serial gateway is always plug and connect. i mean unplug power of raspberry.
              Suppose i use solar panel and battery for home and in cloudy day . power's home is off... so raspberry will be turn off...(or other reason for power off...)
              • tbowmoT
                tbowmoT
                tbowmo
                @Reza
                from the initial logs, after powerup, there is no FT232 listed in your lsusb listing, then you unplug and plug it again, and THEN the FT232 is present..
                This IS not a bug in mysensors, as it's an HW chip (FT232) that your linux doesn't see before it's unplugged / plugged, it smells of a hardware issue with your nano. Now @sincze mentioned to you that he have had the same issues, and he cured it by exchanging the arduino, maybe it's worth a shot?
                @awi also linked to a document, that describes how to make USB devices persistent in the naming (this can happen once in a while, that a USB device enumerates as a different device number.. That is, /dev/ttyUSB1 instead of /dev/ttyUSB0).
                @Reza said:
                R 2 Replies Last reply
                • tbowmoT tbowmo
                  @Reza
                  @Reza said:
                  R
                  R
                  Reza
                  #38
                  @tbowmo
                  thank you my friend . so this is related to my arduino totally . very very thank you
                  so i think , when complete gateway with a Rpi , this problem will be solved !!!
                  • tbowmoT tbowmo
                    @Reza
                    @Reza said:
                    R
                    R
                    Reza
                    @tbowmo
                    i test some arduino but all have this problem .
                    i have a question . is there a code in linux(Rpi) that after turn off/ on or reset Rpi (after some minutes) , usb port Be reset once !?
                    is there a ready code for this ?
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @Reza
                      Not that I know of..
                      • tbowmoT tbowmo
                        @Reza
                        R
                        R
                        Reza
                        @tbowmo
                        I'm looking for a solution for this issue :)
                        thank you
                        • peerkersezuukerP
                          peerkersezuukerP
                          peerkersezuuker
                          I have the same problem, i posted a question at the Domoticz Forum :
                          Not reconnecting serial portt
                          Greetz Peer
                          Domoticz / My Sensors / Z-Wave
                          https://www.kermisbuks.nl
                          • bjacobseB
                            bjacobseB
                            bjacobse
                            Somehow I think it's more related to the linux kernel than it's a mysensors or Domticz related issue
                            I would start to check which linux kernel you are using with uname -a and then start to search from this
                            Maybe it could also be USB power related? Try to use a better USB power supply to your RPI
                            https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=53832
                            • dbemowskD
                              dbemowskD
                              Why not connect the gateway to one of the onboard serial ports through the GPIO header? I have an Orange Pi which has a GPIO header that is pin compatible with the Raspberry Pi and I ran my gateway from there with no problems. I used pins 6, 8 and 10 which for me was /dev/ttyS3:
                              The trick in doing this with Domoticz is to create a synlink. The reason for this is that Domoticz looks for a ttyUSBxxx device, so with the symlink you are basically tricking Domoticz into thinking that the onboard serial port is USB. In my case I created a symlink for ttyS3 to ttyUSB30 like this:
                              sudo ln -s /dev/ttyS3 /dev/ttyUSB30
                              This way you avoid having the problem of USB devices not being detected on boot.
                              • peerkersezuukerP
                                peerkersezuukerP
                                peerkersezuuker
                                Thank's for the answers to this problem.
                                They didn't work for me, but i think i solved mine.
                                Stop monitoring the serial port for data from a terminal session.
                                See my post at Domoticz forum.
                                12.5k
