  3. Domoticz
  4. domoticz auto add device (mysensors) even if disable "Accept new Hardware Devices"
65 Posts 10 Posters 26.3k Views 6 Watching
  • scalzS
    scalzS
    wrote on last edited by scalz
    #41
    @Reza
    sad from this, is not needed :)
    the thing is : this is not a big bug!! generally the big bug is elsewhere ;) Here you have two issues.
    You are using radios which are on the same frequency. Not a bug. That makes sense that a fresh node for your network can talk with others. If you don't want them on same freq, just change the freq/band using the right define (i don't remember).
    It also has been suggested encryption or signing. And that can help you too. Encryption can't help you for this. It just hides crypt the text if you want. It does not authenticate anything. Signing is authentication. But you would need this for all your nodes.
    Finally, the inclusion mode. That's mostly the feature you need, because it could help you to block new nodes. I think this is a feature that the controller has to implement. I don't use inclusion mode in mysensors (not tried yet),
    but in the controller I'm using (jeedom), it works well. There is one inclusion button (I don't advice you to use jeedom, it's french! and not 2.0 full compliant). As you can see this is possible to have a working inclusion button in controller :)
    On my side, I actually miss time to do tests or doc on this...but i'm pretty sure all is in main doc, or with the right keyword in the forum...i understand this is not an "out of the box" solution, but temporarily, and maybe with luck and spare time there might be a dedicated doc for inclusion even if it's quite simple..
    N R 2 Replies Last reply
    • scalzS scalz
      @Reza
      N
      N
      Nicklas Starkel
      @scalz said:
      @Reza
      You have to use whitelisting to block nodes. 'Signing' in GateWay does not work as it accepts non signed nodes. Signing primarily is used for nodes receiving info.
      R 1 Reply Last reply
      • scalzS scalz
        @Reza
        R
        R
        Reza
        @scalz
        thank you my friend
        • N Nicklas Starkel
          @scalz said:
          @Reza
          R
          R
          Reza
          @Nicklas-Starkel
          are you sure about whitelisting? this problem resolved with whitelisting???
          N 1 Reply Last reply
          • R Reza
            @Nicklas-Starkel
            N
            N
            Nicklas Starkel
            @Reza
            From what I understand the GateWay will add all nodes even if you do not want them to. But not to the controller if you have "inclusion option" on the GateWay.
            There is a possibility that if you use the "inclusion option" maybe it will pick up all sensors not already added (ie your neighbour) if they are sending while inclusion is looking for new sensors.
            If you want to stop this you will have to use whitelisting on MAC adress. But this requires you to reprogram GateWay everytime you want to add new sensor (or maybe it is possibility to have same MAC for all?).
            And of course you will have to program a MAC adress for all sensors/per sensor the first time as well.
            I thought this problem would be solved with only using Signing, but because of backwards compability the creators did not enable this in the GateWay.
            If you only would want signing, you could make all nodes connect via a repeater node.
            Because between repeater nodes and regular nodes signing is enabled and no other nodes is accepted which aren't signed with correct signing :)
            And if you use Whitelisting only between GateWay and repeater node, you are set.
            Note: I could be wrong ;)
            AnticimexA 1 Reply Last reply
            • N Nicklas Starkel
              @Reza
              AnticimexA
              AnticimexA
              Anticimex
              @Nicklas-Starkel repeater nodes will just forward signed messages. It will only verify messages addressed directly to it like all nodes. Signing is end to end.
              • AnticimexA Anticimex
                N
                N
                Nicklas Starkel
                @Anticimex yes. But since his neighbours nodes aren't signed (or with wrong signation), the repeater will not forward them to his gateway.
                Or am I totally wrong?
                • N Nicklas Starkel
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @Nicklas-Starkel repeater forwards what is sent to it. But if your gw is set to require signatures and your node has presented itself as a node that require signatures, gw will not accept unsigned messages from that node. If the message passes through a repeater or not does not matter.
                  • R
                    R
                    Reza
                    This post is deleted!
                      R
                      R
                      Reza
                      @Anticimex
                      can i use a specific range "node_id" for my gateway? for example my gateway just add device that range of node id is between 5000 until 5500 ? and out of range dont detect and add ?!
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Reza
                        The Gateways doesn't care at all by nodeId's. It only acts as a Gatteway, and retransmits the signal received on air, to the controller on the computer.
                        There is no pairing mode, or inclusion mode, implemented in the gateway.
                        The INCLUSION_FEATURE will send a command to the controller and instruct it to turn on inclusion mode (if implemented correct)
                        That is, all inclusion mode specifics are made on the controller side (Vera, Domoticz, OpenHab etc). All the gateway are doing is sending the data from nodes, to the controller, and from the controller, to the nodes.
                        The Gateway can not reserve a number of node ID's (and specially not id 5000, because mysensors only supports up to 255 nodes on the network, all with 255 child sensors attached). As the reservation is done on the controller level.
                        • tbowmoT tbowmo
                          @Reza
                          R
                          R
                          Reza
                          @tbowmo
                          so this issue is related to domoticz Fully ! ok very thank you and i am sorry for this topic
                          • tbowmoT tbowmo
                            @Reza
                            R
                            R
                            Reza
                            wrote on last edited by Reza
                            #53
                            @tbowmo
                            one more question
                            if we want , the node after add to one controller , node lock ! and dont add to other controller. this is related to controller or our sketch ?
                            so my neighbor can not add my device
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              If your neighbor knows your network frequency / network address, he can potentially add your nodes to his network. That is why signing is there for sensitive nodes, like locks etc.
                              • tbowmoT tbowmo
                                R
                                R
                                Reza
                                1.so with signing this problem can resolved? i use a signing for my WSN and i told to my neighbor that use a signing for his WSN . Will solve it?
                                2.also suppose a thief come near my home door , and he has a domoticz with a mysensors gateway ! so if i use a mysensors relay (signing) for electric door lock , he can add my relay to his controller and open my home door ?
                                please first told me about 1 , and about 2
                                • R Reza
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @Reza Read the documentation please. https://www.mysensors.org/about/signing
                                    R
                                    R
                                    Reza
                                    @Anticimex
                                    thank you and just one question :) i'm sorry.
                                    how to change frequency for my gateway and my sensors and devices?
                                    • R Reza
                                      @Anticimex
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @Reza I don't know. Signing does not care about frequencies. But a good guess would be to check in MyConfig.h as has already been suggested in this thread. Or search the codebase for "frequency" perhaps.
                                      We are not a living dictionary, you have to expect to do some searching yourself when you work with a project that is "DIY". The slogan for the entire site/community says it all: "IOT+DIY=MySensors".
                                        R
                                        R
                                        Reza
                                        @Anticimex
                                        in domoticz forum told me to "You should separate these two networks by using different frequency" so i want test this for Separation my WSN with neighbor WSN
                                        thank you my friend for help
                                        • P
                                          P
                                          pjr
                                          If I'm reading the domoticz codebase correctly there is two problems:
                                          1. It will add the node in MySensors node/child listing even if the "Accept new hardware device" flag is disabled. But it wont create domoticz core/ui/..-devices from those.
                                          2. I_INCLUSION_MODE message is not supported by domoticz.
                                          @Reza can you update title of this topic also :)
                                          For reference: https://www.domoticz.com/forum/viewtopic.php?f=6&t=13481&start=20#p97600
                                          Please correct if I've provided misleading information.
