  3. Mysensors for pur avr
8 Posts 3 Posters 2.9k Views 3 Watching
  • yogui79Y
    yogui79Y
    yogui79
    Hello does somebady adapt the mysensors lib for using wihth éclipse without using the arduino libs. I need to use pur avr code.
    Thanks for yor answhere
    Regards
    YveauxY 1 Reply Last reply
    • yogui79Y yogui79
      Regards
      YveauxY
      YveauxY
      @yogui79 No, MySensors for AVR depends on Arduino.
      • yogui79Y
        yogui79Y
        yogui79
        Thanks for your answhere . do you think that it is possible to do the adaptation?
        The sensor is on a arduino but the code doesnt work whel when i use the arduino ide
        • yogui79Y yogui79
          @yogui79 anything is possible in the do-it-yourself world :) All that's needed is people with sufficient interest and time.
          • yogui79Y
            yogui79Y
            yogui79
            Thanks for your anwhere i will try to take the time to do it!
            • yogui79Y yogui79
              @yogui79 Maybe others are interested in joining the effort. What main benefits do you see with pure avr? It could be benefits that others want as well.
              An alternative could be to port the sensor library to work well on Arduino. Not sure what would give the best value quickest.
              • yogui79Y
                yogui79Y
                yogui79
                Hello
                I have some timer isue in the arduino ide.
                The microsecond timer is not very precise. And if i put my code in the arfuino ide and i use the loop i have a différents in the frequence from 40 us for a timer with a timer value from 2500us this is tu mutch for my use
                • yogui79Y
                  yogui79Y
                  yogui79
                  Hy, I solved my problem an do a mysensors bridge for somfy rts.
                  I post the lib and the sample on the jeedom forum : https://www.jeedom.com/forum/viewtopic.php?f=35&t=21456 its in french but I can translate if needed
                  All the code and description inside the sample is in english
