  3. [SOLVED] latest git-snapshot causes freezes
46 Posts 6 Posters 13.2k Views 5 Watching
  • cimba007C
    cimba007C
    cimba007
    wrote on last edited by cimba007
    Okay ... I switched back between snapshot from yesterday and stable 2.0.0 and all I can say is that the stable is perfectly fine and the snapshot freezes.
    prepare to sleep
    17416 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
    17481 MCO:SLP:TPD
    17498 MCO:SLP:WUP=1
    .18
    Nothing on the code has been changed. Only difference is that I had to modifie latest stable to include a few delays for my slow 1mhz node ..
    PS: I currently don't have the time to debug this issue further .. last time it took me some days to figure out the delay-issue of slow nodes ...
    tekkaT 1 Reply Last reply
    • cimba007C cimba007
      prepare to sleep
      17481 MCO:SLP:TPD
      17498 MCO:SLP:WUP=1
      .18
      tekkaT
      tekkaT
      tekka
      @cimba007 Could you upload a minimal sketch (ideally without external dependencies) to reproduce this?
      • cimba007C
        cimba007C
        cimba007
        // http://www.earth.org.uk/OpenTRV/Arduino/bootloader/ATmega328P-1MHz/README.txt
        #define MY_NODE_ID 14
        #define MY_BAUD_RATE 9600 // DONT GO HIGHER AS 57600 !!! 115200 might cause DEADLOCKS!!!
        #define MY_DEBUG_LIGHT
        //#include "helper.h"
        //MySensorChild motionSensor = MySensorChild(0, S_MOTION, V_TRIPPED, "");
        void before()
          //wdt_enable(WDTO_8S);
          char datetime[30]; // 22 + 1 should ben enough
          snprintf(datetime, 30, "%s | %s", __DATE__, __TIME__);
          #ifdef MY_DEBUG_LIGHT
          Serial.print(F("SketchInfo: "));
          Serial.println(datetime);
          sendSketchInfo("adxl345", datetime);
        #include <Wire.h>
        #include <FaBo3Axis_ADXL345.h>
        FaBo3Axis fabo3axis;
        //void ADXL_ISR()
          Serial.begin(9600); // シリアルの開始デバック用
          Serial.println("Checking I2C device...");
          //if(fabo3axis.searchDevice()){
          //  Serial.println("I am ADXL345");
          Serial.println("Init...");
          fabo3axis.configuration();
          fabo3axis.powerOn();
          //fabo3axis.enableTap();
          fabo3axis.enableActivity();
          //attachInterrupt(digitalPinToInterrupt(3), ADXL_ISR, RISING);
          fabo3axis.readIntStatus();
          // http://www.avrfreaks.net/forum/wire-library-increasing-i2c-speed
          //TWBR = ((F_CPU / 400000) - 16) / 2;
          TWBR = 0;
          Serial.print("i2c @ "); Serial.print(TWBR); Serial.println();
          //wdt_reset();
          MyMessage msg(0, V_TRIPPED);
          //motionSensor.set(1);  motionSensor.waitsend(50);
          //send(msg,true);
          //uint8_t s = fabo3axis.readIntStatus();
          uint8_t s = 1;
          if(false){
            Serial.print("activity ");
            //Serial.println(millis());
            msg.set(1);
            send(msg,true);
            //motionSensor.set(1);  motionSensor.waitsend(50,60000);
          else
            Serial.print(s,HEX);
            msg.set(0);
            send(msg,true);
            //motionSensor.set(0);  motionSensor.waitsend(50,60000);
          //Serial.println("prepare to sleep");
          Serial.flush();
          // Pending Int-Stati might prevent interrupt!
          sleep(digitalPinToInterrupt(3),RISING,16);
          //millis_offset += 16;
          Serial.print(" | ");
          Serial.println(hwMillis());
        bool my_ack_received;
          if (message.isAck())
            my_ack_received = true;
        I suspect the sleep/interrupt combination.
        Could not remove the accelerometer cause it is the source of the interrupts
        • cimba007C
          cimba007C
          cimba007
          no sleep = fine
          no i2c-communiction/no interrupts = fine
          both = lockup
          • cimba007C
            cimba007C
            cimba007
            I noticed that I can make the node crash if I trigger some interrupts by force (moving the accelerometer) .. nice ..
            I guess the sleep/interrupt code has some kind of bug since the latest rework in the developer branch.
            • ikkeTI
              ikkeTI
              ikkeT
              I hope you catch it, as I believe I'm hit by the same bug. It the happens similar way on Sensebender Micro & NRF24L01+. I have a thread on troubleshooting forum with topic of interrupt mystery. I'm arduino newbie, so I'm not much help. I'm just about to try it on Arduino Pro mini just for comparison.
              Somehow the enbling of interrupts lock it within a minute or so. If no interrupt enabled, no locking.
              BR,
              Ikke
              cimba007C 1 Reply Last reply
              • ikkeTI ikkeT
                BR,
                Ikke
                cimba007C
                cimba007C
                cimba007
                @ikkeT Are you using the latest stable or snapshot version?
                tekkaT ikkeTI 2 Replies Last reply
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  @cimba007 Thanks, I'll try to reproduce it. What Arduino IDE & AVR Board defs are you using?
                  @ikkeT Same here, can you upload your (minimal) sketch to reproduce and also indicate MySensors, Arduino IDE and AVR board def versions?
                  cimba007C ikkeTI 2 Replies Last reply
                  • scalzS
                    scalzS
                    wrote on last edited by scalz
                    @cimba007
                    just an idea..i don't know if it can help at all..but it looks there is a while loop in FaBo3Axis::readI2c
                    do you think if adding some debug here you get something??
                    i was just thinking..a freeze that's weird..no wdt?
                    • tekkaT tekka
                      cimba007C
                      cimba007C
                      cimba007
                      @tekka Arduiono 1.6.12
                      # Add the new board to boards.txt (normally located at "C:\Program Files\Arduino\hardware\arduino\avr"
                      # The *.bootloader.* etries only matters if you want to program bootloader (and fuses) from Arduino IDE.
                      # See http://www.engbedded.com/fusecalc (select Atmega328p) for interpretation of fuse values and how
                      # extended fuses are written in different applications (07h in Arduino IDE = FFh in Atmel studio).
                      apm96.name=APM Optiboot internal 1MHz noBOD 9600baud
                      apm96.upload.tool=avrdude
                      apm96.upload.protocol=arduino
                      apm96.upload.maximum_size=32256
                      apm96.upload.speed=9600
                      apm96.bootloader.tool=avrdude
                      apm96.bootloader.low_fuses=0x62
                      apm96.bootloader.high_fuses=0xde
                      apm96.bootloader.extended_fuses=0x06
                      apm96.bootloader.path=optiboot_v50
                      apm96.bootloader.file=atmega328_1a.hex
                      apm96.bootloader.unlock_bits=0x3F
                      apm96.bootloader.lock_bits=0x2F
                      apm96.build.board=AVR_APM96
                      apm96.build.mcu=atmega328p
                      apm96.build.f_cpu=1000000L
                      apm96.build.core=arduino
                      apm96.build.variant=standard
                      I changed the fuses to include BDOUT @ 1,8Volt
                      VCC of my setup is 2-3Volt
                      • scalzS scalz
                        @cimba007
                        cimba007C
                        cimba007C
                        cimba007
                        @scalz Thanks for the hint with the while-loop. I changed the i2c-read the following way:
                        void FaBo3Axis::readI2c(uint8_t register_addr, uint8_t num, uint8_t buffer[])
                          Wire.beginTransmission(_i2caddr);
                          Wire.write(register_addr);
                          Wire.endTransmission();
                          Wire.requestFrom(_i2caddr, num);
                          int i = 0;
                          uint8_t limit = num;
                          while(Wire.available() && limit--)
                        	Serial.print("r");
                            buffer[i] = Wire.read();
                            i++;
                        Now it should under no circumstanced read more then the number given. Sadly this had no impact:
                         | 34291
                        34291 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                        34357 TSF:MSG:ACK
                        134390 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                        r34471 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
                        34537 MCO:SLP:TPD
                        34553 MCO:SLP:WUP=1
                         | 34553
                        34553 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                        34553 TSF:MSG:ACK
                        134553 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                        Just before the sleep ..
                        I then added a Serial.flush() to the "r"-output ..
                        	Serial.print("readI2c");
                        	Serial.flush();
                          int i = 0;
                        	Serial.print("r");
                        	Serial.flush();
                            i++;
                        54706 MCO:SLP:WUP=1
                         | 54706
                        54706 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                        54706 TSF:MSG:ACK
                        154706 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                        Now the freeze is clearly before entering the sleep function ..
                        but then .. on another round ..
                         | 56623
                        56623 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                        56623 TSF:MSG:ACK
                        156623 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                        readI2c
                        readI2cgot # from slave: 1
                        r78987 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
                        79052 MCO:SLP:TPD
                        79069 MCO:SLP:WUP=1
                         | 79069
                        79069 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                        79069 TSF:MSG:ACK
                        179069 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                        readI2c
                        So .. your tip was very good .. it seems to be related to the
                        -call .. only one questions remains .. why was it working perfectly on the stable library?
                        Just to be sure I will run exactly the same code in a non-stop loop with the stable library ..
                            int i = 0;
                          	Serial.print("r");
                              i++;
                           | 34291
                          34357 TSF:MSG:ACK
                          34537 MCO:SLP:TPD
                          34553 MCO:SLP:WUP=1
                           | 34553
                          34553 TSF:MSG:ACK
                          	Serial.flush();
                            int i = 0;
                          	Serial.print("r");
                          	Serial.flush();
                              i++;
                          54706 MCO:SLP:WUP=1
                           | 54706
                          54706 TSF:MSG:ACK
                           | 56623
                          56623 TSF:MSG:ACK
                          readI2c
                          79052 MCO:SLP:TPD
                          79069 MCO:SLP:WUP=1
                           | 79069
                          79069 TSF:MSG:ACK
                          readI2c
                          tekkaT
                          tekkaT
                          tekka
                          @cimba007 What AVR board defs are you on?
                          • cimba007C
                            cimba007C
                            cimba007
                            @tekka said:
                            AVR board def
                            What do you mean with AVR board def?
                            https://forum.mysensors.org/topic/4999/latest-git-snapshot-causes-freezes/17
                            I am using an arduino pro-mini china clone (328p) with 8mhz internal oscillator and DIV_8 fuse.
                            The bootloader is an "APM Optiboot 1Mhz" .. cant find the link right now.
                              @tekka said:
                              AVR board def
                              tekkaT
                              tekkaT
                              tekka
                              #21
                              @cimba007 You'll find the information in your Boards Manager (under Tools | Board | Boards Manager)
                              • cimba007C
                                cimba007C
                                cimba007
                                yeah .. sorry
                                0_1475435692355_upload-68958f1f-2d52-4640-bdf0-b33688831f9f
                                  yeah .. sorry
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @cimba007 ok, do you see it hapepening if you downgrade the AVR board defs to 1.6.12 or 13?
                                  • cimba007C
                                    cimba007C
                                    cimba007
                                    btw .. the "old" library is running happy for 6 minutes now ... still continuing
                                    TSP:MSG:READ 0-0-14 s=0,c=1,t=16,pt=2,l=2,sg=0:0
                                    1TSP:MSG:SEND 14-14-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=ok:0
                                    r | 373997
                                    r | 374177
                                    @tekka: I will try the "new snapshot" with the board defs you mentioned .. standby
                                    • cimba007C
                                      cimba007C
                                      cimba007
                                      @1.6.12 board defs
                                      r68550 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
                                      68599 MCO:SLP:TPD
                                      68632 MCO:SLP:WUP=1
                                       | 68632
                                      68632 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                                      68632 TSF:MSG:ACK
                                      168632 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                                      readI2c
                                      @1.6.13 board defs
                                      r62914 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
                                      62980 MCO:SLP:TPD
                                      62996 MCO:SLP:WUP=1
                                       | 62996
                                      62996 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                                      62996 TSF:MSG:ACK
                                      162996 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                                      readI2c
                                      • scalzS
                                        scalzS
                                        #26
                                        hmm..too bad that didn't do the trick..but there was something (and that's an issue which can appear easily when using other libs, "hidden" while) and difficult to reproduce exactly the same case on my side as i'm not using the same radio.
                                        i've dl the latest snpashot. so i will check on my side if one of my sketch is still running fine (with 4ints) and if i get the problem i'll try to debug it too. but i hope to not get it lol :)
                                        • cimba007C
                                          cimba007C
                                          cimba007
                                          That would be nice .. my latest findings point out that the i2c-function is getting stuck. I investigated the i2c-source of arduino a bit and found out it is quite depending on interrupts.
                                          This is now
                                          wild speculation
                                          For some reason interrupts got disabled while the i2c library is trying to write some data on the i2c-bus ..
                                          wild-speculation-end
