  3. [SOLVED] latest git-snapshot causes freezes
46 Posts 6 Posters 12.9k Views 5 Watching
  • cimba007C cimba007
    I only used the pin change interrupt in another sketch. I was doubting Serial in sections without isr too! But they are clever. Serial output depends on polling in sections where interrupts are disabled ;-)
    YveauxY
    YveauxY
    Ok, learned something today ;-)
    The PR has now been merged to development btw.
    cimba007C chrilleC 2 Replies Last reply
    • YveauxY Yveaux
      cimba007C
      cimba007C
      cimba007
      wrote on last edited by cimba007
      #42
      @Yveaux While we are at this topic .. any chance to let the user-code know what caused the wakeup during sleep() ??
      For example .. if there was a wakeup at all or which of the two interrupt sources was the cause.
      Unforunatly the "cause" gets cleaned up at the end of hwSleep:
      bool interruptWakeUp()
          return _wokeUpByInterrupt != INVALID_INTERRUPT_NUM;
      Calling this from user-code will always return 0 as the end of hwSleep does this:
       _wokeUpByInterrupt = INVALID_INTERRUPT_NUM;
      Not clearing the "last interrupt source" would be nice.
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @cimba007 The return value of sleep() indicates the wake-up cause: irq (nr) or timer (=MY_WAKE_UP_BY_TIMER).
        See here: https://github.com/mysensors/MySensors/blob/development/core/MyHwATMega328.cpp#L146-L147
        cimba007C 1 Reply Last reply
        • ikkeTI
          ikkeTI
          ikkeT
          I also confirm it fixed my problem. Thank you!
          • tekkaT tekka
            cimba007C
            cimba007C
            cimba007
            @tekka Thanks, that is what I was looking for
            • YveauxY Yveaux
              chrilleC
              chrilleC
              chrille
              @Yveaux Thank you for committing this fix. I had the same issue and it caused me a lot of headache
