[SOLVED] latest git-snapshot causes freezes
@tekka said:
AVR board def
What do you mean with AVR board def?
https://forum.mysensors.org/topic/4999/latest-git-snapshot-causes-freezes/17
I am using an arduino pro-mini china clone (328p) with 8mhz internal oscillator and DIV_8 fuse.
The bootloader is an "APM Optiboot 1Mhz" .. cant find the link right now.
btw .. the "old" library is running happy for 6 minutes now ... still continuing
TSP:MSG:READ 0-0-14 s=0,c=1,t=16,pt=2,l=2,sg=0:0
1TSP:MSG:SEND 14-14-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=ok:0
readI2cgot # from slave: 1
r | 373997
r | 374177@tekka: I will try the "new snapshot" with the board defs you mentioned .. standby
@1.6.12 board defs
r68550 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255 68599 MCO:SLP:TPD 68632 MCO:SLP:WUP=1 | 68632 68632 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0 68632 TSF:MSG:ACK 168632 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0 readI2c@1.6.13 board defs
readI2cgot # from slave: 1 r62914 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255 62980 MCO:SLP:TPD 62996 MCO:SLP:WUP=1 | 62996 62996 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0 62996 TSF:MSG:ACK 162996 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0 readI2c -
hmm..too bad that didn't do the trick..but there was something (and that's an issue which can appear easily when using other libs, "hidden" while) and difficult to reproduce exactly the same case on my side as i'm not using the same radio.
i've dl the latest snpashot. so i will check on my side if one of my sketch is still running fine (with 4ints) and if i get the problem i'll try to debug it too. but i hope to not get it lol :) -
That would be nice .. my latest findings point out that the i2c-function is getting stuck. I investigated the i2c-source of arduino a bit and found out it is quite depending on interrupts.
This is now
wild speculation
For some reason interrupts got disabled while the i2c library is trying to write some data on the i2c-bus ..
wild-speculation-end
Code working: (4minutes+)
sei(); fabo3axis.readIntStatus();Code not working:
//sei(); fabo3axis.readIntStatus();I noticed that interrupts in the sleep function are only detached if the intrrupt occurs ..
whereas in the stable
detachInterrupt(interrupt1); if (interrupt2!=0xFF) detachInterrupt(interrupt2);They get detached after the wakeup in the sleep ..
What if .. for some strange reason the interrupt is interfearing with .. whatever?!
EDIT: with the added sei(); the node is running for 10 minutes now ...
EDIT2: Running for 20 minutes now .. -
@tekka, the versions are:
Mysensors is development branch, I didn't pay attention while cloning, it's set to default to development:
commit 8cacb4825b256f63aa2fc51468fd11a90bb19678 Merge: 75a100f 8ccb1ca Author: Patrick Fallberg <patrick@fallberg.net> Date: Thu Sep 22 19:02:11 2016 +0200Arduino IDE is 1.6.4
$ rpm -qa arduino* arduino-core-1.6.4-8.fc24.noarch arduino-doc-1.6.4-8.fc24.noarch arduino-1.6.4-8.fc24.noarchMy IDE board manager shows Arduino AVR boards version 1.6.7, and it seems there is newer one available, 1.6.14. I will update that.
Mysensors AVR board definition for Micro version is 1.0.1
so far, on my side, using custom sleep() and other mix, my ints are still working..i'm using latest snap' now, and still in 1.6.8..
but that's not the same usecase as i'm not using mys sleep for this node..
I will try your case; at least mine is working well :) . it could be sort of race..always a dilemma somewhere.. -
I got suspecious about the code working with the manual adding of
sei()before calling the i2cread-function.So I changed the end of
hwPowerDownto include a serial output with a flush.// restore saved WDT settings WDTCSR = WDTsave; Serial.println("sei()"); Serial.flush(); sei(); // enable ADC ADCSRA |= (1 << ADEN); }Now have a close look at how
sei()-output is missing just before the freeze:57114 MCO:SLP:TPD<\n> sei()<\r><\n> 57147 MCO:SLP:WUP=-1<\n> | 57180<\r><\n> 57180 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n> 57245 TSF:MSG:ACK<\n> 157262 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0<\n> readI2cgot # from slave: 1<\r><\n> r57376 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255<\n> 57442 MCO:SLP:TPD<\n> sei()<\r><\n> 57475 MCO:SLP:WUP=-1<\n> | 57491<\r><\n> 57507 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n> 57573 TSF:MSG:ACK<\n> 157589 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0<\n> readI2cgot # from slave: 1<\r><\n> r57704 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255<\n> 57769 MCO:SLP:TPD<\n> 57786 MCO:SLP:WUP=1<\n> | 57786<\r><\n> 57786 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n> 57786 TSF:MSG:ACK<\n> 157786 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0<\n> readI2cJust after "57769 MCO:SLP:TPD<\n>" the sei()-output is missing. Thus I suspect that interrupts are not enabled when the readI2c-function is called .. and as i2c is depending on interrupts the code gets stuck there.
Still no idea why the
sei()is "sometimes" not called ...Notice how the "millis" interrupt is not called after the missing sei .. thus all timestamps are the same:
57786 MCO:SLP:WUP=1<\n> | 57786<\r><\n> 57786 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n> 57786 TSF:MSG:ACK<\n> 157786 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0<\n> readI2c -
Comparing the code to the atmel documentation here:
http://www.atmel.com/webdoc/AVRLibcReferenceManual/group__avr__sleep.html
mysensors explicit disables interrupts after wake from sleep:
sei(); // Directly sleep CPU, to prevent race conditions! (see chapter 7.7 of ATMega328P datasheet) sleep_cpu(); sleep_disable(); // restore previous WDT settings cli();whereas the atmel documentation enables interrupts
#include <avr/interrupt.h> #include <avr/sleep.h> ... set_sleep_mode(<mode>); cli(); if (some_condition) { sleep_enable(); sleep_bod_disable(); sei(); sleep_cpu(); sleep_disable(); } sei();Might not be totally related as the code did not change from last stable .. except one line:
WDTCSR |= (1 << WDIE); // set the WDIE flag to enable interrupt callback function.is now missing in the snapshot ..
Adding an extra sei() after the sleep_disable() is not the solution .. still thought it might be noteworthy
is now missing in the snapshot ..Can you indicate where this change is located?
I compared 2.0.0 (master) to 2.0.1beta (development) and WDTCSR is only touched in MyHwATMega328.cpp
The watchdog related parts seem identical between both versions...Futhermore, is it the library located at https://github.com/FaBoPlatform/FaBo3Axis-ADXL345-Library/blob/master/src/FaBo3Axis_ADXL345.cpp that you are using?
Jep, this is the library.
https://github.com/mysensors/MySensors/blob/development/core/MyHwATMega328.cpp#L86
https://github.com/mysensors/MySensors/blob/master/core/MyHwATMega328.cpp#L75well .. I have no idea but on my code it is there:
Seems to be neither in the stable nor the developement branch .. but I most gotten it somewhere .. lets check
I think I added it for some reason on latest stable. Otherwise pinchage-interrupt was not working with mysensors-library .. I will try to remove it on stable to see if I get stuck there too and add in snapshot to see if it helps in some way.
EDIT1: Adding in the latest snapshot doesn't change a thing
EDIT2: Removing it in the latest stable doesn't change a thingI might have added it from another testsketch .. but it would be better located in that sketch right after the sleep function .. so just ignore it for now - my bad ;_(
@cimba007 Well, I filed (https://github.com/mysensors/MySensors/issues/598) and fixed (https://github.com/mysensors/MySensors/pull/599) and issue with interrupts not being detached correctly in all cases when using hwSleep().
This might be causing your issue, but is hard to say without actually debugging the code.
Once the PR is merged, could you try getting the latest development branch and see if it fixes the issue? (please use the development branch, without any local modifications) -
Just copy'pasted your fix and .. voila
Problems seems to be solved - although I do not unterstand why?!
- _wakeUp2Interrupt should be totally unrelated as it is never set
- detach should happen in the ISR
.. even if the interrupt is not detached correctly .. how should it lead to the total skip of these code:
cli(); wdt_reset(); // enable WDT changes WDTCSR |= (1 << WDCE) | (1 << WDE); // restore saved WDT settings WDTCSR = WDTsave; Serial.println("sei()"); Serial.flush(); sei(); // enable ADC ADCSRA |= (1 << ADEN); //WDTCSR |= (1 << WDIE); // set the WDIE flag to enable interrupt callback function.As this code-snipped is skipped sei() gets never called in my case .. and the subsequent call to i2c freezes the node ... as i2c depends on interrupts ..
Anyway thanks Yveaux .. althour your fix is simple .. i don't know why it is working ...
EDIT: Furthermore .. even if the interrupt is not detached in the isr .. there should be no further interrupt if the interrupt register is not read via i2c .. and that in fact doesn't happen >:>
@cimba007 Great to hear it solves your problem!
Regarding the serial print not showing: you call it from withing a section with interrupts disabled; I don't know if this will work at all, or maybe even cause a hang... I would toggle some IO pins instead and use an oscilloscope to verify program flow.
Sleeping an AVR using the watchdog and pin interrupts is some tricky stuff, which is very susceptible to race conditions and almost impossible to debug without a decent hardware debugger.
Having a compiler that woes every now and then also isn't helping... -
