  3. OpenHAB
  4. Gateway suggestion
Gateway suggestion
10 Posts 4 Posters 4.0k Views 4 Watching
  • speedmaxS
    speedmaxS
    speedmax
    I'm new with MySensors.
    I already bought some stuff to built sensors and a gateway.
    What's your gateway suggestion...
    I running openHab 2 (beta4) on a RPI V2.
    Thanks for your help!
    • T
      TimO
      I haven't tested it myself, but if you already have a RPi running I would go for the Linux gateway with the NRF24 directly attached to the RPi.
      I'm using a serial and an ethernet gateway in parallel.
      • speedmaxS
        speedmaxS
        speedmax
        Thanks for your answer.
        I suppose you talk about this...
        https://www.mysensors.org/build/raspberry
        Can I plug the NRF24 directly to the GPIO of the Pi?
        Thanks!
        Max
        • speedmaxS speedmax
          Thanks!
          Max
          Yes
          speedmaxS 1 Reply Last reply
            Yes
            speedmaxS
            speedmaxS
            speedmax
            @mfalkvidd Thanks!
            • Freedom1029F
              Freedom1029F
              Freedom1029
              I built my serial gateway as instructed in the build section. The tutorial is oriented for the vera, so I wonder, is it the exact same code if I am with Openhab? For example I read somewhere that the baud rate must be set to 9600 instead of 38400, is it still true with Openhab 2.0? What the next step, once I my serial gateway is connected to the usb port of my Raspberry Pi?
              • T
                TimO
                The baud rate depends only on your hardware. If you're using an arduino with 16 MHz a baud rate of 115.200 is a good choice. The baud rate in the OH2 binding is adjustable and defaults to 115.200.
                If your serial gateway is running fine, you are able to check that with the serial monitor of the arduino IDE, the next step is to install OH2 and the binding.
                • Freedom1029F
                  Freedom1029F
                  Freedom1029
                  Thanks for the info Tim. I am new to this so could you point me in the right direction for the OH2 binding installation, as it is not in the list of binding available it seems. As it is right now a have a clean installation of the standard Openhab.
                  • T
                    TimO
                    The instructions are in the wiki on github: https://github.com/tobof/openhab2-addons/wiki
                    • Freedom1029F
                      Freedom1029F
                      Freedom1029
                      Thanks for the info. I'll try to install that tonight.
