  3. TTP226 module touch panel serial mode library for Mysensors?
ttp2268 oeysserial modetouch module
5 Posts 2 Posters 2.7k Views 2 Watching
  • V
    V
    vikasjee
    Re: How To: Make a Simple/Cheap Scene Controller (with video)
    Do we have any serial mode library?
    AWIA 1 Reply Last reply
    • V vikasjee
      AWIA
      AWIA
      AWI
      @vikasjee no need for a library there. The thread contains an example for using the TTP226.
      V 1 Reply Last reply
      • AWIA AWI
        V
        V
        vikasjee
        @AWI I need to use the Serial Mode ( 2 pins ) in TTP226 module instead of Direct Mode which requires ( 9 pins) on Arduino with Interrupt enabled on 8 inputs. Hence the request for the Serial Mode TTP226 library
        • V vikasjee
          AWIA
          AWIA
          AWI
          @vikasjee sorry I forgot to attach the link to the thread where the serial interface is used. This piece of code is sufficient:
          // fetch serial data, store in keyState
          int fetchData(){
              digitalWrite(SCL_pin, LOW);                             // get first bit
              delayMicroseconds(100);                                 // allow for stable input
              digitalWrite(SCL_pin, HIGH);
              for(int i = 0; i < keyboardSize; i++){                  // read all keys
                  keyState[i] = (digitalRead(SDA_pin) == LOW) ;       // set key if pressed
          • AWIA AWI
            int fetchData(){
            V
            V
            vikasjee
            @AWI Thanks for the piece of code. Now i can see where i was wrong! Let me run it... this seems to be missing the interrupt part though. I will try using DV on Int2...
