  3. Error compiling for Arduino / Energy Monitor Shield
9 Posts 4 Posters 4.5k Views 4 Watching
  • Christian WilhelmC
    Christian WilhelmC
    Christian Wilhelm
    I am trying to get the Energy Monitor Shield from Seeed to work (http://wiki.seeedstudio.com/wiki/Energy_Monitor_Shield_V0.9b) but struggling to use the provided sketch. As far as I know I need to transform the code to make it work with MySensors 2.0. I am rubbish with code (only know a little python) and have no clue where to start or decipher the error messages.
    The original code looks like this:
     This example code is in the public domain.
    #include <MySensor.h>  // Include MySensors.org Library V1.5
    #include "EmonLib.h" // Include Emon Library
    #include <LCD5110_Graph_SPI.h> // Include NOKIA5110 Library
    #define CHILD_ID_POWER 0
    EnergyMonitor emon;
    LCD5110 myGLCD(5,6,3);
    extern unsigned char SmallFont[];
    MyTransportNRF24 transport(7, 8); //for EMv1
    MySensor gw(transport);
    unsigned long lastSend;
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    float Irms;
    float lastIrms = -99;
    char tbuf[8];
    char sbuf[12];
    MyMessage IrmsMsg(CHILD_ID_POWER, V_KWH);
      myGLCD.InitLCD();
      myGLCD.setFont(SmallFont);
      myGLCD.update();
      // The third argument enables repeater mode.
      gw.begin(NULL, AUTO, true),
      gw.sendSketchInfo("Energy Monitor v1", "1.0");
    //  emon.current(0, 111.1);             // Current: input pin, calibration.
       emon.current(0, 66.5);
      gw.present(CHILD_ID_POWER, S_POWER);
      gw.process();
      unsigned long now = millis();
      double Irms = emon.calcIrms(1480);  // Calculate Irms only
      float realIrms  = emon.Irms*220;        //extract Real Power into variable
     if (realIrms != lastIrms) {
          gw.send(IrmsMsg.set(realIrms, 1)); //send to gateway
      lastIrms=realIrms;
       dtostrf(realIrms,5,2,tbuf);
        sprintf(sbuf, "  %s kWt", tbuf);
        myGLCD.print(sbuf, 20, 0);
        myGLCD.print("Powr:", 0, 0);
        dtostrf(Irms,5,2,tbuf);
        sprintf(sbuf, "  %s Amp", tbuf);
        myGLCD.print(sbuf, 20, 10);
        myGLCD.print("Irms:", 0, 10);
        myGLCD.update();
          Serial.print("Power: ");
          Serial.println(realIrms);
      gw.sleep(SEND_FREQUENCY);
    Then I transformed it to:
    #include <nRF24L01.h>
    #include <RF24.h>
    #include <RF24_config.h>
    #include <MySensors.h> // Include MySensors.org Library V1.5
    EnergyMonitor emon;
    float Irms;
    char tbuf[8];
    char sbuf[12];
    myGLCD.InitLCD();
    myGLCD.update();
    lastIrms=realIrms;
    myGLCD.update();
    But still get the same error which is:
    MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    exit status 1
    Error compiling for board Arduino/Genuino Mega or Mega 2560.
    I think the sketch was written some time ago, using MySensors 1.5, not sure how to change it to the updated version.
    Appreciate any help
    Regards
    Christian
      Move the MySensors include to the bottom of your sketch
        Christian WilhelmC
        Christian Wilhelm
        Thanks for your help, still struggling to make it work. I have amended the sketch to that:
        EnergyMonitor emon;
        MySensors gw(transport);
        float Irms;
        char tbuf[8];
        char sbuf[12];
          myGLCD.InitLCD();
          myGLCD.update();
          process();
          lastIrms=realIrms;
            myGLCD.update();
          #include <MySensors.h>  // Include MySensors.org Library V2.0
        Still get this error message:
        Documents/Arduino/libraries/MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
        exit status 1
        Christian
          You seem to have picked some old 1.5 sketch and compile it using MySensors 2.0 .
            Christian WilhelmC
            Christian Wilhelm
            Yes the sketch was written using MySensors 1.5, but these don't seem to work anymore with the new IDE. I assume to code needs to look quite a bit differently.
            O 1 Reply Last reply
            • Christian WilhelmC Christian Wilhelm
              O
              O
              Oleg Greengo
              wrote on last edited by Oleg Greengo
              @Christian-Wilhelm
              try this sketch
              This sketch is for a Energy Monitor v 1.0
              http://www.elecrow.com/cooperated-designers/devicter/energy-monitor-shield-p-835.html
              and MySensors 2.0
              https://www.mysensors.org/
               modified
               17 Oct 2016
               by greengo
              #define MY_NODE_ID       AUTO
              #define SKETCH_NAME "Energy Monitor v1.0"
              #define SKETCH_VERSION "2.0.0"
              #define MY_REPEATER_FEATURE
              #define MY_RF24_CHANNEL 76
              // Connected we have to move CE/CSN pins for NRF radio
              #define MY_RF24_CE_PIN   7
              #define MY_RF24_CS_PIN   8
              #include <Time.h>
              //extern unsigned char SmallFont[];
              extern uint8_t SmallFont[];
              #define WINDOW 15
              // How many milli seconds between each measurement
              #define MEASURE_INTERVAL    1000 //for 1 sec
              // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
              #define FORCE_TRANSMIT_INTERVAL 600 //every 10 min
              unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
              int TEMP_TRANSMIT_THRESHOLD = 0; //~3-5 Watt
              #define CHILD_ID_FLOATING_CUR_SENSOR 1 //floating sensor
              EnergyMonitor emon;
              unsigned long CHECK_TIME = millis();
              MyMessage IrmsMsg(CHILD_ID_POWER, V_WATT);
              MyMessage kWhMsg(CHILD_ID_POWER, V_KWH);
              MyMessage FloatingMsg(CHILD_ID_FLOATING_CUR_SENSOR, V_VAR1);
              // Global settings
              int measureCount = 0;
              boolean transmission_occured = false;
              boolean timeReceived = false;
              unsigned long lastUpdate = 0, lastRequest = 0;
              // Storage of old measurements
              double realWatt = 0;
              float realkWt = 0;
              double Irms;
              float lastIrms = 0;
              int Floating;
              float PMin = 99;
              float PMax = 0;
              int stateFloating = 0;
              long wattsum  = 0;
              long wattsumS = 0;
              //int seconds   = 0;
              double wh     = 0;
              double kwh    = 0;
              double whS    = 0;
              double kwhS   = 0;
               double cIrms = 0;
                 emon.current(0, 11.0);        // Current: input pin, calibration.
               double Irms[WINDOW];
                       Irms[0] = emon.calcIrms(1480); // первое значение при измерении явно "кривое"
                //    Serial.println("calculate delta");
                    for (int i=0; i<WINDOW; i++) {
                      Irms[i] = emon.calcIrms(1480);
                   cIrms = cIrms + Irms[i];
                      delay(100);
              sendPowerMeasurements(true);
                wait(500);
                //request Time
                requestTime();
                myGLCD.InitLCD();
                present(CHILD_ID_POWER, S_POWER, "POWER");
              //present(CHILD_ID_POWER_COUNTER, S_CUSTOM, "COUNTER");
                present(CHILD_ID_FLOATING_CUR_SENSOR, S_CUSTOM, "Float");
              // This is called when a new time value was received
              void receiveTime(unsigned long time) {
                Serial.print("Time value received: ");
                Serial.println(time);
                // Ok, set incoming time
                setTime(time);
                timeReceived = true;
                // If no time has been received yet, request it every 10 second from controller
                // When time has been received, request update every hour
                if ((!timeReceived && now - lastRequest > (unsigned long)10 * 1000)
                    || (timeReceived && now - lastRequest > (unsigned long)60 * 1000 * 60)) {
                  // Request time from controller.
                  Serial.println("Requesting time");
                  Serial.println("Time now: ");
                  Serial.println(timeReceived);
                  wait(300);
                  requestTime();
                  lastRequest = now;
                 displayUpdate();
                int HH = hour();
                int MM = minute();
                int SS = second();
                unsigned long NOW_TIME = millis();
                if(NOW_TIME - CHECK_TIME >= SLEEP_TIME)
                measureCount ++;
                  realWatt  = (emon.Irms * 220);  // Extract Real Power into variable
                  long watt = Irms * 220.0;
                  realkWt   = (Irms * 0.220);
                  wattsum = wattsum + watt;
                  wattsumS = wattsumS + watt;
                  //   seconds++;
                  Serial.print("    Real TIME   =    ");
                  Serial.print(hour());
                  Serial.print(" : ");
                  Serial.print(minute());
                  Serial.println();
                  // hours KW reading
                  if ( (MM >= 59) & (SS >= 59)) {
                    wh = wh + wattsum / 3600;
                    kwh = wh / 1000;
                    send(kWhMsg.set(kwh, 4)); // Send kwh value to gw
                    wattsum = 0;
                    wh = 0;
                    //   seconds = 0;
                    // end of hourly KW reading
                  // fixing minimum and maximum values for Nokia
                if ( realkWt > PMax) PMax = realkWt;
                if ( realkWt < PMin &&  realkWt > 0.05) PMin = realkWt;
                bool forceTransmit = false;
                if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                  forceTransmit = true;
                  measureCount = 0;
                   sendPowerMeasurements(forceTransmit);
               // Serial.print(" measureCount: ");
               // Serial.println(measureCount);
               // Serial.print(" ");
                     CHECK_TIME = NOW_TIME;
              void sendPowerMeasurements(bool force)
                bool tx = force;
                TEMP_TRANSMIT_THRESHOLD = loadState(CHILD_ID_FLOATING_CUR_SENSOR);
                Floating = TEMP_TRANSMIT_THRESHOLD;
                //  Serial.print("TEMP_TRANSMIT_THRESHOLD: ");Serial.println(TEMP_TRANSMIT_THRESHOLD);
                float diffIrms = abs(lastIrms - realWatt);
                //  Serial.print(F("IrmsDiff :"));Serial.println(diffIrms);
                if (diffIrms > TEMP_TRANSMIT_THRESHOLD) tx = true;
                if (tx) {
                  measureCount = 0;
                  //   Serial.print("Watt: ");Serial.println(realWatt);
                  send(IrmsMsg.set(realWatt, 1));
                  lastIrms = realWatt;
                  transmission_occured = true;
                //  Serial.print("seconds : "); Serial.println(seconds);
                Serial.print(" ***************** ");
                Serial.print("wh : "); Serial.println(wh);
                Serial.print(" ");
                Serial.print("kwhS : "); Serial.println(kwhS, 4);
                Serial.print("wattsum : "); Serial.println(wattsum);
                Serial.print(" ");
                Serial.print("wattsumS : "); Serial.println(wattsumS);
                Serial.print(" ");
                Serial.print("Irms : "); Serial.println(Irms, 4);
                Serial.print(" ");
                Serial.print("kwh : "); Serial.println(kwh, 4);
                Serial.println(" ");
                Serial.print("Watt: "); Serial.println(realWatt);
                Serial.print("realkWt : ");Serial.println(realkWt);
                // LCD Nokia
               void displayUpdate()
              // myGLCD.clrScr();
               char tbuf[8];
               char sbuf[12];
                  dtostrf(realWatt,5,2,tbuf);
                  sprintf(sbuf, " %s Watt", tbuf);
                  myGLCD.print(sbuf, 20, 0);   //от края, высота
                  myGLCD.print("PWR:", 0, 0);   //от края, высота
                  myGLCD.print(sbuf, 20, 10);   //от края, высота
                  myGLCD.print("IRM:", 0, 10);   //от края, высота
                  dtostrf(PMin,5,2,tbuf);
                  myGLCD.print(sbuf, 20, 20);   //от края, высота
                  myGLCD.print("MiN:", 0, 20);   //от края, высота
                  dtostrf(PMax,5,2,tbuf);
                  myGLCD.print(sbuf, 20, 30);   //от края, высота
                  myGLCD.print("MaX:", 0, 30);   //от края, высота
                  dtostrf(Floating,5,2,tbuf);
                  myGLCD.print(sbuf, 20, 40);   //от края, высота
                  myGLCD.print("flt:", 0, 40);   //от края, высота
                  myGLCD.update();
                if (message.isAck()) {
                if (message.type == V_VAR1) {
                   // Change state
                   stateFloating = message.getInt();
                   // Store state in eeprom
                   saveState(CHILD_ID_FLOATING_CUR_SENSOR, stateFloating);
                   // Write some debug info
                   Serial.print(message.sensor);
                   Serial.print(", Delta =: ");
                   Serial.println(message.getInt());
                 //  Serial.print(", New status: ");
                 //  Serial.println(message.getBool());
                Christian WilhelmC
                Christian Wilhelm
                Thanks for the sketch :)
                I managed to find the time library but seem to have a problem with settime I don't understand:
                It says 'setTime' was not declared in this scope
                : In function 'void receiveTime(long unsigned int)':
                New_powermonitor:132: error: 'setTime' was not declared in this scope
                setTime(time);
                : In function 'void loop()':
                New_powermonitor:156: error: 'hour' was not declared in this scope
                int HH = hour();
                New_powermonitor:157: error: 'minute' was not declared in this scope
                int MM = minute();
                New_powermonitor:158: error: 'second' was not declared in this scope
                int SS = second();
                : In function 'void displayUpdate()':
                277:30: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                :282:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                :287:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                :292:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                :297:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                exit status 1
                • Vincent PandoyV
                  Vincent PandoyV
                  Vincent Pandoy
                  Does anyone here done with this code?
                    setTime(time);
                    int HH = hour();
                    int MM = minute();
                    int SS = second();
                    exit status 1
                    O
                    O
                    Oleg Greengo
                    @Christian-Wilhelm
                    #include <Time.h>
                    add them to your library
                    C:\Program Files\Arduino\libraries
