  3. Error compiling for Arduino / Energy Monitor Shield
9 Posts 4 Posters 4.4k Views 4 Watching
  • Christian WilhelmC Offline
    Christian Wilhelm
    I am trying to get the Energy Monitor Shield from Seeed to work (http://wiki.seeedstudio.com/wiki/Energy_Monitor_Shield_V0.9b) but struggling to use the provided sketch. As far as I know I need to transform the code to make it work with MySensors 2.0. I am rubbish with code (only know a little python) and have no clue where to start or decipher the error messages.
    The original code looks like this:
     This example code is in the public domain.
    #include <MySensor.h>  // Include MySensors.org Library V1.5
    #include "EmonLib.h" // Include Emon Library
    #include <LCD5110_Graph_SPI.h> // Include NOKIA5110 Library
    #define CHILD_ID_POWER 0
    EnergyMonitor emon;
    LCD5110 myGLCD(5,6,3);
    extern unsigned char SmallFont[];
    MyTransportNRF24 transport(7, 8); //for EMv1
    MySensor gw(transport);
    unsigned long lastSend;
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    float Irms;
    float lastIrms = -99;
    char tbuf[8];
    char sbuf[12];
    MyMessage IrmsMsg(CHILD_ID_POWER, V_KWH);
      myGLCD.InitLCD();
      myGLCD.setFont(SmallFont);
      myGLCD.update();
      // The third argument enables repeater mode.
      gw.begin(NULL, AUTO, true),
      gw.sendSketchInfo("Energy Monitor v1", "1.0");
    //  emon.current(0, 111.1);             // Current: input pin, calibration.
       emon.current(0, 66.5);
      gw.present(CHILD_ID_POWER, S_POWER);
      unsigned long now = millis();
      double Irms = emon.calcIrms(1480);  // Calculate Irms only
      float realIrms  = emon.Irms*220;        //extract Real Power into variable
     if (realIrms != lastIrms) {
          gw.send(IrmsMsg.set(realIrms, 1)); //send to gateway
      lastIrms=realIrms;
       dtostrf(realIrms,5,2,tbuf);
        sprintf(sbuf, "  %s kWt", tbuf);
        myGLCD.print(sbuf, 20, 0);
        myGLCD.print("Powr:", 0, 0);
        dtostrf(Irms,5,2,tbuf);
        sprintf(sbuf, "  %s Amp", tbuf);
        myGLCD.print(sbuf, 20, 10);
        myGLCD.print("Irms:", 0, 10);
        myGLCD.update();
          Serial.print("Power: ");
          Serial.println(realIrms);
      gw.sleep(SEND_FREQUENCY);
    Then I transformed it to:
    #include <nRF24L01.h>
    #include <RF24.h>
    #include <RF24_config.h>
    #include <MySensors.h> // Include MySensors.org Library V1.5
    EnergyMonitor emon;
    float Irms;
    char tbuf[8];
    char sbuf[12];
    myGLCD.InitLCD();
    myGLCD.update();
    lastIrms=realIrms;
    myGLCD.update();
    But still get the same error which is:
    MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    exit status 1
    Error compiling for board Arduino/Genuino Mega or Mega 2560.
    I think the sketch was written some time ago, using MySensors 1.5, not sure how to change it to the updated version.
    Appreciate any help
    Regards
    Christian
    • H Offline
      H Offline
      Move the MySensors include to the bottom of your sketch
        Christian Wilhelm
        Thanks for your help, still struggling to make it work. I have amended the sketch to that:
        EnergyMonitor emon;
        MySensors gw(transport);
        float Irms;
        char tbuf[8];
        char sbuf[12];
          myGLCD.InitLCD();
          myGLCD.update();
          process();
          lastIrms=realIrms;
            myGLCD.update();
          #include <MySensors.h>  // Include MySensors.org Library V2.0
        Still get this error message:
        Documents/Arduino/libraries/MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
        exit status 1
        Christian
        • H Offline
          H Offline
          You seem to have picked some old 1.5 sketch and compile it using MySensors 2.0 .
            Christian Wilhelm
            Yes the sketch was written using MySensors 1.5, but these don't seem to work anymore with the new IDE. I assume to code needs to look quite a bit differently.
            O 1 Reply Last reply
            • Christian WilhelmC Christian Wilhelm
              O Offline
              O Offline
              Oleg Greengo
              wrote on last edited by Oleg Greengo
              @Christian-Wilhelm
              try this sketch
              This sketch is for a Energy Monitor v 1.0
              http://www.elecrow.com/cooperated-designers/devicter/energy-monitor-shield-p-835.html
              and MySensors 2.0
              https://www.mysensors.org/
               modified
               17 Oct 2016
               by greengo
              #define MY_NODE_ID       AUTO
              #define SKETCH_NAME "Energy Monitor v1.0"
              #define SKETCH_VERSION "2.0.0"
              #define MY_REPEATER_FEATURE
              #define MY_RF24_CHANNEL 76
              // Connected we have to move CE/CSN pins for NRF radio
              #define MY_RF24_CE_PIN   7
              #define MY_RF24_CS_PIN   8
              #include <Time.h>
              //extern unsigned char SmallFont[];
              extern uint8_t SmallFont[];
              #define WINDOW 15
              #define MEASURE_INTERVAL    1000 //for 1 sec
              #define FORCE_TRANSMIT_INTERVAL 600 //every 10 min
              unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
              int TEMP_TRANSMIT_THRESHOLD = 0; //~3-5 Watt
              #define CHILD_ID_FLOATING_CUR_SENSOR 1 //floating sensor
              EnergyMonitor emon;
              unsigned long CHECK_TIME = millis();
              MyMessage IrmsMsg(CHILD_ID_POWER, V_WATT);
              MyMessage kWhMsg(CHILD_ID_POWER, V_KWH);
              MyMessage FloatingMsg(CHILD_ID_FLOATING_CUR_SENSOR, V_VAR1);
              // Global settings
              int measureCount = 0;
              boolean transmission_occured = false;
              boolean timeReceived = false;
              unsigned long lastUpdate = 0, lastRequest = 0;
              double realWatt = 0;
              float realkWt = 0;
              double Irms;
              float lastIrms = 0;
              int Floating;
              float PMin = 99;
              float PMax = 0;
              int stateFloating = 0;
              long wattsum  = 0;
              long wattsumS = 0;
              //int seconds   = 0;
              double wh     = 0;
              double kwh    = 0;
              double whS    = 0;
              double kwhS   = 0;
               double cIrms = 0;
                 emon.current(0, 11.0);        // Current: input pin, calibration.
               double Irms[WINDOW];
                       Irms[0] = emon.calcIrms(1480); // первое значение при измерении явно "кривое"
                //    Serial.println("calculate delta");
                    for (int i=0; i<WINDOW; i++) {
                      Irms[i] = emon.calcIrms(1480);
                   cIrms = cIrms + Irms[i];
                      delay(100);
              sendPowerMeasurements(true);
                wait(500);
                //request Time
                requestTime();
                myGLCD.InitLCD();
                present(CHILD_ID_POWER, S_POWER, "POWER");
              //present(CHILD_ID_POWER_COUNTER, S_CUSTOM, "COUNTER");
                present(CHILD_ID_FLOATING_CUR_SENSOR, S_CUSTOM, "Float");
              void receiveTime(unsigned long time) {
                Serial.println(time);
                // Ok, set incoming time
                setTime(time);
                timeReceived = true;
                // If no time has been received yet, request it every 10 second from controller
                // When time has been received, request update every hour
                if ((!timeReceived && now - lastRequest > (unsigned long)10 * 1000)
                    || (timeReceived && now - lastRequest > (unsigned long)60 * 1000 * 60)) {
                  // Request time from controller.
                  Serial.println("Requesting time");
                  Serial.println("Time now: ");
                  Serial.println(timeReceived);
                  wait(300);
                  requestTime();
                  lastRequest = now;
                 displayUpdate();
                int HH = hour();
                int MM = minute();
                int SS = second();
                unsigned long NOW_TIME = millis();
                if(NOW_TIME - CHECK_TIME >= SLEEP_TIME)
                measureCount ++;
                  realWatt  = (emon.Irms * 220);  // Extract Real Power into variable
                  long watt = Irms * 220.0;
                  realkWt   = (Irms * 0.220);
                  wattsum = wattsum + watt;
                  wattsumS = wattsumS + watt;
                  //   seconds++;
                  Serial.print("    Real TIME   =    ");
                  Serial.print(hour());
                  Serial.print(" : ");
                  Serial.print(minute());
                  Serial.println();
                  // hours KW reading
                  if ( (MM >= 59) & (SS >= 59)) {
                    wh = wh + wattsum / 3600;
                    kwh = wh / 1000;
                    send(kWhMsg.set(kwh, 4)); // Send kwh value to gw
                    wattsum = 0;
                    wh = 0;
                    //   seconds = 0;
                    // end of hourly KW reading
                  // fixing minimum and maximum values for Nokia
                if ( realkWt > PMax) PMax = realkWt;
                if ( realkWt < PMin &&  realkWt > 0.05) PMin = realkWt;
                bool forceTransmit = false;
                if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                  forceTransmit = true;
                  measureCount = 0;
                   sendPowerMeasurements(forceTransmit);
               // Serial.print(" measureCount: ");
               // Serial.println(measureCount);
               // Serial.print(" ");
                     CHECK_TIME = NOW_TIME;
              void sendPowerMeasurements(bool force)
                bool tx = force;
                TEMP_TRANSMIT_THRESHOLD = loadState(CHILD_ID_FLOATING_CUR_SENSOR);
                Floating = TEMP_TRANSMIT_THRESHOLD;
                //  Serial.print("TEMP_TRANSMIT_THRESHOLD: ");Serial.println(TEMP_TRANSMIT_THRESHOLD);
                float diffIrms = abs(lastIrms - realWatt);
                //  Serial.print(F("IrmsDiff :"));Serial.println(diffIrms);
                if (diffIrms > TEMP_TRANSMIT_THRESHOLD) tx = true;
                if (tx) {
                  measureCount = 0;
                  //   Serial.print("Watt: ");Serial.println(realWatt);
                  send(IrmsMsg.set(realWatt, 1));
                  lastIrms = realWatt;
                  transmission_occured = true;
                //  Serial.print("seconds : "); Serial.println(seconds);
                Serial.print(" ***************** ");
                Serial.print("wh : "); Serial.println(wh);
                Serial.print(" ");
                Serial.print("kwhS : "); Serial.println(kwhS, 4);
                Serial.print("wattsum : "); Serial.println(wattsum);
                Serial.print(" ");
                Serial.print("wattsumS : "); Serial.println(wattsumS);
                Serial.print(" ");
                Serial.print("Irms : "); Serial.println(Irms, 4);
                Serial.print(" ");
                Serial.print("kwh : "); Serial.println(kwh, 4);
                Serial.println(" ");
                Serial.print("Watt: "); Serial.println(realWatt);
                Serial.print("realkWt : ");Serial.println(realkWt);
                // LCD Nokia
               void displayUpdate()
              // myGLCD.clrScr();
               char tbuf[8];
               char sbuf[12];
                  dtostrf(realWatt,5,2,tbuf);
                  sprintf(sbuf, " %s Watt", tbuf);
                  myGLCD.print(sbuf, 20, 0);   //от края, высота
                  myGLCD.print("PWR:", 0, 0);   //от края, высота
                  myGLCD.print(sbuf, 20, 10);   //от края, высота
                  myGLCD.print("IRM:", 0, 10);   //от края, высота
                  dtostrf(PMin,5,2,tbuf);
                  myGLCD.print(sbuf, 20, 20);   //от края, высота
                  myGLCD.print("MiN:", 0, 20);   //от края, высота
                  dtostrf(PMax,5,2,tbuf);
                  myGLCD.print(sbuf, 20, 30);   //от края, высота
                  myGLCD.print("MaX:", 0, 30);   //от края, высота
                  dtostrf(Floating,5,2,tbuf);
                  myGLCD.print(sbuf, 20, 40);   //от края, высота
                  myGLCD.print("flt:", 0, 40);   //от края, высота
                  myGLCD.update();
                if (message.isAck()) {
                if (message.type == V_VAR1) {
                   // Change state
                   stateFloating = message.getInt();
                   // Store state in eeprom
                   saveState(CHILD_ID_FLOATING_CUR_SENSOR, stateFloating);
                   Serial.print(", Delta =: ");
                 //  Serial.print(", New status: ");
                 //  Serial.println(message.getBool());
                Christian Wilhelm
                Thanks for the sketch :)
                I managed to find the time library but seem to have a problem with settime I don't understand:
                It says 'setTime' was not declared in this scope
                : In function 'void receiveTime(long unsigned int)':
                New_powermonitor:132: error: 'setTime' was not declared in this scope
                setTime(time);
                : In function 'void loop()':
                New_powermonitor:156: error: 'hour' was not declared in this scope
                int HH = hour();
                New_powermonitor:157: error: 'minute' was not declared in this scope
                int MM = minute();
                New_powermonitor:158: error: 'second' was not declared in this scope
                int SS = second();
                : In function 'void displayUpdate()':
                277:30: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                :282:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                :287:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                :292:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                :297:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                exit status 1
                • Vincent PandoyV Offline
                  Vincent Pandoy
                  Does anyone here done with this code?
                    setTime(time);
                    int HH = hour();
                    int MM = minute();
                    int SS = second();
                    exit status 1
                    O Offline
                    O Offline
                    Oleg Greengo
                    @Christian-Wilhelm
                    #include <Time.h>
                    add them to your library
                    C:\Program Files\Arduino\libraries
                    12.2k
