  3. Please help, motion sensor doesn't show radio transmission value on serial monitor
3 Posts 2 Posters 963 Views 2 Watching
  • parnu2000P
    parnu2000P
    parnu2000
    I connected MySensors motion sensor V.2.0 with Arduino Nano and nRF24L01p. I have a serial gateway with the same configuration . When I open serial monitor on motion sensor side, it show only 0 and 1 detection value on serial monitor. it doesn't show anything about radio transmission response as shown below.
    I'm running 3 other sensors , distance ,air quality and relay sensor. All of them show correct radio transmission value on the serial monitor. Before wiring connections. I have tested motion sensor with MySensors serial gateway sketch 2.0, it show that radio transmission is ok.
    What could be the reason why motion sensor doesn't show radio transmission response on serial monitor? Please kindly suggest , Thank you very much in advanced.
    • parnu2000P parnu2000
      @parnu2000 is
      enabled in the sketch? Without it, the node will not print debug information.
      parnu2000P 1 Reply Last reply
        @parnu2000 is
        parnu2000P
        parnu2000P
        parnu2000
        @mfalkvidd Thank you very much for your reply.
        I have done as you suggested. it works. Thank a lot, it's very kind of you.
