  3. MQTT Client gateway
MQTT Client gateway
91 Posts 33 Posters 66.2k Views 14 Watching
  • GizMoCuzG GizMoCuz
    Questions (Sorry)
    I have rebuild the whole original MQTT sketch so it supports the standard mysensors protocol (the serial/ethernet gateway).
    With this, we have all functionality that the original mysensor serial gateway supports.
    What would be the downside with this implementation ?
    The data being transferred is like
    http://www.mysensors.org/download/serial_api_14
    It is now also very easy to pass the payload an internal serial/ethernet gateway handler, but the payload is not easily interpreted as human text of course.
    Would this be something to submit as a replacement of the original MQTT library?
    Devs just need to push the payload to their original serial/ethernet handler, and sending messages is also in the same format
    AWIA
    AWIA
    AWI
    @GizMoCuz Can you elaborate a little on your rebuild? ie. what was the objective?
    • T
      TommySharp
      Could someone please post the latest working version of the MQTT Client gateway sketch?
      • TD22057T
        TD22057T
        TD22057
        Does anyone have a version of this reworked for the new 1.5 client? Looking through the MySensor class, it looks like a lot of the code in MyMQTTClient.cpp can be removed as it's now in the sensor class. I'd like to use this for my gateway as it's a much better system than the broker gateway that's in the standard library but it needs to support message signing and the newer 1.5 code base. If someone else finished this already I'll just use that, otherwise I'll start working on it. I have family coming in town so I don't expect to get much done in the next week but assuming that the MQTT code is working fine (I have no experience with that writing an MQTT client), it shouldn't take much work to refactor the client to use the new MySensor base.
        • T
          tomkxy
          I just did an adaptation. I removed the MyMQTTClient.cpp completely. It looks codewise more than the MQTTGateway. I am in the process of testing it.
          You can find it here https://github.com/tomkxy/Arduino.git in the branch MQTTClient.
          • G
            G
            Gambituk
            wrote on last edited by Gambituk
            #45
            @tomkxy Any updates to this? my setup has been running well for a long time, but i am itchy to see if it will survive with 1.5.. i know i should just leave it alone :D but i cannot help but tinker with it.
            • T
              tomkxy
              Well it seems to work. Only point I saw and don't understand is that the gateway tries to send a message back to the sensor which does not seem to be an ACK. See my post here http://forum.mysensors.org/topic/1782/gateway-is-sending-command-1-type-1-c-1-t-1-message-to-sensor but so far no feedback on that. Functional wise it works, at least with my test temp and humidity sensor.
              • R
                R
                ruslan
                Please help! This MQTT client gateway fails to compile. I use 1.6.5. IDE, 1.5 library. Applied patches as suggested by ntruchsess and still get this error:
                MyMQTTClient.cpp: In constructor 'MyMQTTClient::MyMQTTClient(PubSubClient, uint8_t, uint8_t)':
                MyMQTTClient.cpp:108: error: no matching function for call to 'MySensor::MySensor(uint8_t&, uint8_t&)'
                     MySensor(_cepin, _cspin), buffsize(0)
                MyMQTTClient.cpp:108:41: note: candidates are:
                In file included from MyMQTTClient.h:16:0,
                                 from MyMQTTClient.cpp:14:
                R:\Arduino\libraries\MySensors/MySensor.h:153:2: note: MySensor::MySensor(MyTransport&, MyHw&)
                  MySensor(MyTransport &radio =*new MyTransportNRF24(), MyHw &hw=*new MyHwDriver()
                R:\Arduino\libraries\MySensors/MySensor.h:153:2: note:   no known conversion for argument 1 from 'uint8_t {aka unsigned char}' to 'MyTransport&'
                R:\Arduino\libraries\MySensors/MySensor.h:144:7: note: MySensor::MySensor(const MySensor&)
                 class MySensor
                R:\Arduino\libraries\MySensors/MySensor.h:144:7: note:   candidate expects 1 argument, 2 provided
                MyMQTTClient.cpp: In member function 'void MyMQTTClient::begin(rf24_pa_dbm_e, uint8_t, rf24_datarate_e, uint8_t, uint8_t, uint8_t)':
                MyMQTTClient.cpp:148: error: 'setupRepeaterMode' was not declared in this scope
                   setupRepeaterMode();
                MyMQTTClient.cpp:154: error: 'setupRadio' was not declared in this scope
                   setupRadio(paLevel, channel, dataRate);
                MyMQTTClient.cpp:155: error: 'BASE_RADIO_ID' was not declared in this scope
                   RF24::openReadingPipe(WRITE_PIPE, BASE_RADIO_ID);
                MyMQTTClient.cpp:157: error: cannot call member function 'void RF24::startListening()' without object
                   RF24::startListening();
                • T
                  tomkxy
                  Did you have a look at my repository above? Functional wise it is the same adapted for version 1.5. I have it in use for quite a while now.
                  • R
                    R
                    ruslan
                    to tomkhy: your gateway sketch compiles, but Arduino runs out of memory (I use Nano with W5100 ethernet module, SOFTSPI enabled). It does fit with MY_SIGNING_FEATURE and DEBUG disabled, but I need debug - somehow it is not registering with MQTT server. Please tell me how to reduce memory footprint.
                    greglG 1 Reply Last reply
                    • T
                      tomkxy
                      I am using this sketch with a Mega exactly because of that problem. If you post your MQTTClientGateway sketch I can have a look. If you use Mosquito as MQTT broker you may also post the Mosquito config file.
                      • R
                        R
                        ruslan
                        Many thanks to @tomkhy!
                        I built my MQTT client with his code. No modifications were needed.
                        BTW, Will this or any other code get included into the official MySensors library?
                        • T
                          tomkxy
                          It is now in the Development branch.
                          • A
                            A
                            ahhk
                            wrote on last edited by ahhk
                            #53
                            can this run on ESP8266 (as wifi-mqttclient-gateway), too?
                            Greetings
                            Andreas
                            M 1 Reply Last reply
                            • T
                              tomkxy
                              I don't know, you have to try it. What I can say that with signing support enabled it doesn't fit into the memory of a ProMini. I run it in a Mega.
                              • R ruslan
                                greglG
                                greglG
                                gregl
                                Looks like you have it working now, but just incase, Previously when I have had memory issues , I have upgraded my bootloader to use Optiboot which gives you a little bit more.
                                HTH
                                • A ahhk
                                  Greetings
                                  Andreas
                                  mlava
                                  @ahhk
                                  Hello all, first post here and a bit new to the mysensors field.
                                  I also want to know the answer as to whether this will run on the ESP8266 as hope to run a wifi gateway.
                                  Thanks in advance! :)
                                  • C
                                    C
                                    chris021
                                    Also keen to run this on an ESP8266 would be a great for bridging.
                                    • John ConnollyJ
                                      John ConnollyJ
                                      John Connolly
                                      OK. I've got the gateway to compile and get the following:
                                      Started!
                                      0;0;3;0;9;read: 110-110-0 s=1,c=1,t=0,pt=7,l=5:13.2
                                      0;0;3;0;9;read: 105-105-0 s=0,c=1,t=1,pt=7,l=5:70.0
                                      0;0;3;0;9;read: 110-110-0 s=0,c=1,t=1,pt=7,l=5:58.3
                                      0;0;3;0;9;read: 105-105-0 s=0,c=1,t=1,pt=7,l=5:69.9
                                      0;0;3;0;9;read: 110-110-0 s=0,c=1,t=1,pt=7,l=5:58.2
                                      0;0;3;0;9;read: 105-105-0 s=0,c=1,t=1,pt=7,l=5:69.8
                                      0;0;3;0;9;read: 110-110-0 s=1,c=1,t=0,pt=7,l=5:13.3
                                      0;0;3;0;9;read: 110-110-0 s=0,c=1,t=1,pt=7,l=5:58.5
                                      I can ping the MQTTClinetGateway from another machine and I've confirmed Mosquitto is running OK with a series of pub/subs from other machines/devices and that side of things is working perfectly fine.
                                      I'm not seeing any of the above gateway readings publish to my broker. Thoughts?
                                      Cheers.
                                      • T
                                        tomkxy
                                        Following points to verify and check:
                                        • is the gateway connected to the broker. As far as I remember you can check that by subscribiing to Mosquitto status messages
                                        mosquitto_sub -v -t \$SYS/#
                                        If not check what the authentication method is mosquitto is. If it allows anonymous access make sure that "MQTT_AUTH_REQUIRED" is not defined in the MQTTClientGateway sketch. If username and password are set correctly.
                                        It seems that you are not using signing. So ensure that your MQTTClientGateway is compiled with the signing feature disabled. That are the two points I can imagine now provided that you are sure that you have of course a working ethernet connection.
                                        • John ConnollyJ
                                          John ConnollyJ
                                          John Connolly
                                          I downloaded and installed the development branch and got the MQTTClientGateway running on an UNO with a W5100 shield (that I'm suspicious of, in terms of its reliability). The sketch runs great for a while publishing data to Mosquitto on my Mac Mini, but then stops responding after a while. I'm pretty sure the cause of the problem is the ethernet shield as it bombs out when running other sketches - the webserver one for example.
                                          I have a few of these ENC28J60 boards and I'd like to use one of those instead, but have had some problems.
                                          http://www.aliexpress.com/item/ENC28J60-LAN-Ethernet-Network-Board-Module-for-arduino-25MHZ-Crystal-AVR-51-LPC-STM32-3-3V/1956963721.html
                                          I notice in the MQTTClientGateway sketch that I should just need to comment out the one W5100 Ethernet.h library and substitute with the UIPEthernet.h one, but I tried that and had no joy. Does anyone have a working sketch based on the ENC28J60 that they could post, along with the wiring diagram to connect that board in along with any additional tweaks necessary to get it running on an Uno? Thanks in advance. Cheers.
