  3. MQTT Client gateway
MQTT Client gateway
91 Posts 33 Posters 66.2k Views 14 Watching
  • siodS
    siodS
    siod
    wrote on last edited by siod
    #61
    Hi Guys,
    I get this:
    Started!
    0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
    0;0;3;0;9;version mismatch
    Also the Gateway does not answer to pings. Any suggestions?
    edit: after a rebbot I get valid readings in the Serial monitor of the Arduino IDE now:
    0;0;3;0;9;read: 20-20-0 s=3,c=1,t=16,pt=2,l=2:1
    0;0;3;0;9;read: 20-20-0 s=3,c=1,t=16,pt=2,l=2:0
    But still, can´t ping the gw. Double checked IP and Port, seems to be fine.
    still learning...
    • John ConnollyJ
      John ConnollyJ
      John Connolly
      I've ordered a new W5100 module - this time the red mini W5100 board missing the SD Card slot to see if I have better luck. Still keen to see code for an ENC based MQTTClientGateway though, as this will take a while to arrive... ;)
      • R
        R
        ruslan
        To developers of the MQTT client:
        I just tried the GatewayW5100MQTTClient in the latest development branch - it gives me "0;0;3;0;9;Radio init fail" error, while GatewayW5100 sketch works fine. What could be the reason? I noticed that the declarations parts in these sketches are rather different.
        My setup: ARduino nano clone + W5100 module + NRF24L01 radio. All wired as in the MySensors ethernet gateway guide ([http://www.mysensors.org/build/ethernet_gateway])
          For the W5100 SOFTSPI has to be enabled. I see that this is missing from the sketch..
          Try adding (coming from the normal W5100 sketch)
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
          #if !defined(MY_W5100_SPI_EN)
            #define MY_SOFTSPI
          I'll update the repository.
          • R
            R
            ruslan
            Hi, Hek!
            You are correct. except I also had to add these 2 lines and then radio worked:
            #define MY_RF24_CE_PIN 5
            #define MY_RF24_CS_PIN 6
            Pls fix the repo. Looking forward to seeing mqtt client in the master branch.
              Pushed to build server. Soon merged.
              https://github.com/mysensors/Arduino/pull/241
              • R
                R
                ruslan
                What is the MQTT message to switch MQTT client gateway into inclusion mode?
                  Something like this should work...
                  Topic: mygateway/0/255/3/0/6
                  Payload: 1
                  http://www.mysensors.org/download/serial_api_15
                  • dakkyD
                    dakkyD
                    dakky
                    wrote on last edited by dakky
                    #69
                    Is this MQTTClientGateway in the dev branch only? I didn't see something like this in the 1.5 release/master.
                    I would prefer to use my gateway as client, but I am not skilled enough to use the dev branch and work around resulting problems :sa:
                    greetings
                    Dakky
                    edit:
                    @tomkxy said:
                    @tomkxy said:
                    here https://github.com/tomkxy/Arduino.git in the branch MQTTClient.
                    Did you have a look at my repository above? Functional wise it is the same adapted for version 1.5. I have it in use for quite a while now.
                    hmm is this repo still functional? with the signing_feature enabled i'm getting compile errors:
                    mqttClientGateway:175: error: 'signer' was not declared in this scope
                                 , signer
                    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
                    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
                    Software: MySensors 2.0development
                    S 1 Reply Last reply
                    • dakkyD dakky
                      greetings
                      Dakky
                      edit:
                                   , signer
                      Samuel235
                      @dakky It is currently only in the Dev branch, yes.
                      MySensors 2.1.1
                      • maxtoxM
                        maxtoxM
                        maxtox
                        I Think HERE is the answer of our problem!!!!
                        http://electronics.stackexchange.com/questions/67212/how-to-avoid-sd-card-and-w1500-spi-mixup-on-the-ethernet-shield
                        Arduino Mega 2560 with iobroker.net (MQTT, node-red, etc..)
                        • cowen71C
                          cowen71C
                          cowen71
                          Good afternoon gents!
                          So I have been playing with openHab and an arduino as a mqtt gateway and this has been successful. The only thing I don't like is that the arduino does not seem to like multiple connections to the MQTT broker.
                          My next step then is to use an MQTT broker (mosquitto) on the pi and then subscribe to this from the arduino. If I understand correctly, this is exactly what this thread is discussing.
                          So - I have downloaded the codes and without changing anything, tried to compile. This fails with numerous errors. I have te latest libraries installed and to be honest, I am a little lost as to what is wrong. Before I post lots of error messages, are there any known 'tricks' to get the latest version working?
                          Hopefully someone can help - Thanks guys :-)
                          • cowen71C cowen71
                            Samuel235
                            @cowen71 - Could you please give us a little more information to help troubleshoot your issues.
                            What ethernet module are you using? W5100? If so you need to makesure that you have enabled soft SPI for NRF radio as it doesn't like it being on the same bus. We also have to move the CE/CSN pins for the radio too. All this is explained inside of the sketch itself.
                            MySensors 2.1.1
                            • cowen71C
                              cowen71C
                              cowen71
                              wrote on last edited by cowen71
                              #74
                              Hi Samuel,
                              OK, I was hoping there was a known 'trick' to get things working, but maybe I was just dreaming. Of course, if not - much more information is needed!
                              At the moment I am testing with a Mega2560 with an arduino ethernet shield attached. This has (and still does) work well with the mqtt gateway downloaded from mysensors after a few minor pin assignment changes.
                              The problem I am having is that I cannot compile the mqttClientGateway code. I get errors. I have to be honest that whilst I had experience 20 years ago with PIC's and other uC's, I am incredibly rusty with C and completely new to Arduinos. So it is a steep learning curve currently. In this case, I would not be surprised if I have made a real schoolboy error!
                              So what did I do?....
                              At the moment I installed the PubSubLient library into the Arduino libraries file.
                              I copied the code from here: https://github.com/ntruchsess/MySensors/tree/mqttclient/libraries/MySensors/examples/MQTTClientGateway
                              creating the three files in my mqttClientGateway development folder.
                              I changed nothing (accept target and com port and hit the compile button! This fails with the following error initially:
                              sketch\MyMQTTClient.cpp:14:30: fatal error: utility/MsTimer2.h: No such file or directory
                              #include "utility/MsTimer2.h"
                              I modified the include text to: #include "MsTimer2.h"
                              and tried to compile again again. The result is:
                              sketch\MyMQTTClient.cpp: In constructor 'MyMQTTClient::MyMQTTClient(PubSubClient, uint8_t, uint8_t)':
                              MyMQTTClient.cpp:106: error: no matching function for call to 'MySensor::MySensor(uint8_t&, uint8_t&)'
                               MySensor(_cepin, _cspin), buffsize(0)
                              sketch\MyMQTTClient.cpp:106:41: note: candidates are:
                              In file included from sketch\MyMQTTClient.h:15:0,
                                           from sketch\MyMQTTClient.cpp:13:
                              C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:158:2: note: MySensor::MySensor(MyTransport&, MyHw&)
                              MySensor(MyTransport &radio =*new MyTransportNRF24(), MyHw &hw=*new MyHwDriver()
                              C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:158:2: note: no known conversion for argument 1 from 'uint8_t {aka unsigned char}' to 'MyTransport&'
                              C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:149:7: note: constexpr MySensor::MySensor(const MySensor&)
                              class MySensor
                              C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:149:7: note: candidate expects 1 argument, 2 provided
                              C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:149:7: note: constexpr MySensor::MySensor(MySensor&&)
                              sketch\MyMQTTClient.cpp: In member function 'void MyMQTTClient::begin(rf24_pa_dbm_e, uint8_t, rf24_datarate_e, uint8_t, uint8_t, uint8_t)':
                              MyMQTTClient.cpp:146: error: 'setupRepeaterMode' was not declared in this scope
                              setupRepeaterMode();
                              MyMQTTClient.cpp:152: error: 'setupRadio' was not declared in this scope
                              setupRadio(paLevel, channel, dataRate);
                              MyMQTTClient.cpp:153: error: 'BASE_RADIO_ID' was not declared in this scope
                              RF24::openReadingPipe(WRITE_PIPE, BASE_RADIO_ID);
                              MyMQTTClient.cpp:155: error: cannot call member function 'void RF24::startListening()' without object
                              RF24::startListening();
                              My suspicion is I have a compatibility problem between library versions and/or the sketch I have downloaded. The radio stuff I can probably solve (hopefully) its the issues before that I am struggling with.
                              Any advice would be appreciated.
                              Cheers
                              • cowen71C cowen71
                                Hi Samuel,
                                class MySensor
                                Cheers
                                Samuel235
                                @cowen71, from a glancing look over that post, i would expect the issue to lie within your libraries. Whether it be a version merging issue or just a general error in placements.
                                I will put money on that you have your Arduino folder setup incorrectly when it comes to the libraries. I'll be honest and admit that i'm not too sure why you're getting your client sketch from ntruchsess rather than directly from the MySensors github/download page.
                                Lets just run through it from the start on where to get your libraries placed, in theory they could be located anywhere as long as the files inside of the mysensors folder are in the correct structure. You firstly need to get the development version, I prefer to just go for the direct download off of the download Page. Once you have that downloaded you should have a .zip folder called 'Arduino-development.zip'. Once you have extracted that you need to place all of its contents (3 folders and 5 files) into your Documents\Arduino folder.
                                I would do all of the above with a clean folder structure for the arduino folder, save any library confusions for the software. Then we need to go back into your gateway sketch and change your pin configuration like you need to.
                                Come back with your findings :)
                                MySensors 2.1.1
                                • cowen71C
                                  cowen71C
                                  cowen71
                                  Cheers Samuel,
                                  I will let you know. I am happy (actually perhaps not happy!) to admit the failures are purely down to me trying to get to grips with everything here.
                                  I also have just noticed that ruslan reported the same error somewhere above and so I will also look at the solutions that worked for him.
                                  I let you know what happens
                                  • cowen71C
                                    cowen71C
                                    cowen71
                                    OK so as you suggested - everything redownloaded and a new folder structure created. And actually, I get exactly the same problem. Incidentally, my other sketches compile no problem. Some written by me, some downloaded (e.g. Serial_Gateway, mqtt_Gateway). The only one I have a problem with is the mqttClientGateway.
                                    I see above that ruslan had exactly the same issue 7 months ago and then got it working. The answer that helped him was....
                                    but this link seems dead now.
                                    I better stop for the evening before my wife files for divorce! I get back to this tomorrow!
                                    Thanks for the support so far.
                                    • cowen71C cowen71
                                      Samuel235
                                      @cowen71 Could you post your sketch for either me or a software contributor to see what is going on with it please. If you're certain that the error codes are the same as before then we can use the previous post as reference, if they're different in any way, please post the error codes again with the sketch :)
                                      MySensors 2.1.1
                                      • T
                                        tomkxy
                                        The link mentioned by @cowen71 was put into a pull request which went into the development branch. However, the MQTTClientGateway has been reworked significantly in the development branch. The message structure is now similar to the serial gateway. I just completed a "migration" from that old version to the latest development branch version which worked perfectly, apart from RF issues I had.
                                        Thus, I suggest to use the latest version of the development branch.
                                        • T tomkxy
                                          Samuel235
                                          @tomkxy, if he followed my instructions like he said he has, he should all being well be running the latest version of the development branch. I may be incorrect but i still feel there may be some sort of folder structure error going on here.
                                          MySensors 2.1.1
