  3. Gateway ethernet to modules arduino mcu wifi? O_o
4 Posts 2 Posters 1.7k Views 2 Watching
  • Michel - ItM
    Michel - ItM
    Michel - It
    I wondered, but you can create an Ethernet gateway with the new Arduino MCU wifi module? and where can I find sketches Library 2.0? thank you all
    • Michel - ItM Michel - It
      @Michel---It do you have any more information on the new Arduino MCU wifi module? I found http://www.arduino.org/products/boards/arduino-uno-wifi but I don't know if it is new.
      • Michel - ItM
        Michel - ItM
        Michel - It
        @mfalkvidd for me is new and on the forum I do not find many skeck Library 2.0
        for this device :cry: alt text
          @Michel---It Thanks for posting the image. Anything you find on the forum that mentions esp8266 or nodemcu will most likely work with that node, including https://www.mysensors.org/build/esp8266_gateway which is probably the best place to start.
          There are also several threads on how to connect local sensors to the esp8266. I would give you some pointers but I am on a train with crappy Internet.
