  3. [SOLVED] W5100 Ethernet gateway with RFM69 Radio fails at init
31 Posts 9 Posters 14.1k Views 7 Watching
  • T Tris
    The Ethernet and MQTT wiring is the same (according to main MySesnors instructions).
    As far as protocols go, I choose the MQTT route because its simple and lightwieght, tipped to be a big player in IoT.
    Im not a Mysensors expert, more of a hardware guy, but briefly looking at your diagram - i havent grounded the reset pin on the RFM69 like you have.
    Try cutting that track so it floats
    J Offline
    J Offline
    Jonathan Caes
    @Tris That can indeed be the fault, because i was looking at the hoop up page from sparfun (https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide#hardware-overview) and thought I read that you have to connect the reset to ground, but that might be not true after reading it again. So i'll try doing that and see what happens.
    Thanks!!
    • T Tris
      J Offline
      J Offline
      Jonathan Caes
      @Tris Cut the reset connection and tried again, did not work.. still getting the same debugging info.. :(
      • T Tris
        J Offline
        J Offline
        Jonathan Caes
        @Tris I also get the same debugging when using the MQTTclientgateway..
        • T Offline
          T Offline
          Tris
          Only thing i can think of, is quite basic but i do it myself quite often.
          Remember to put the // lines back infront of the soft spi line in MyConfig.h file.
          You only need that for NRF24 W5100 setup
          Also define the new MI/MO/SCK pins in the sketch
          #define MY_SOFT_SPI_SCK_PIN 13
          #define MY_SOFT_SPI_MISO_PIN 12
          #define MY_SOFT_SPI_MOSI_PIN 11```
          J 1 Reply Last reply
          • T Tris
            J Offline
            J Offline
            Jonathan Caes
            @Tris This is the code I used, it was sugested by Frédéric. With this I don't need to change anything to the myconfig.h file, or do I?
             * Version 1.0 - Henrik EKblad
             * Contribution by Tomas Hozza <thozza@gmail.com>
             * LED purposes:
             * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
            #define MY_RADIO_RFM69
            // La définition des PIN ci dessous n'est pas nécessaire, car c'est celle de base
            //#define MY_RF69_IRQ_PIN 2
            //#define MY_RF69_SPI_CS 10
            #define MY_GATEWAY_W5100
            #define MY_IP_ADDRESS 192,168,0,22
            #define MY_PORT 5003
            // Enable inclusion mode
            // Flash leds on rx/tx/err
            #define MY_LEDS_BLINKING_FEATURE
            // Set blinking period
            #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
            #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
            #define MY_DEFAULT_TX_LED_PIN  6  // Transmit led pin
            #if defined(MY_USE_UDP)
              #include <EthernetUdp.h>
            #include <Ethernet.h>
            void presentation() {
            • T Offline
              T Offline
              Tris
              This post is deleted!
              • T Offline
                T Offline
                Tris
                Try adding the pins to the sketch
                • T Tris
                  I THINK with the W5100.h file amended.
                  try using Mysensors ClearEepromConfig too
                  A Offline
                  A Offline
                  abrasha
                  @Tris
                  ok it didnt work with the w5100.h amendment, so i reverted to the original config.
                  now im on your new pinout with the a0-a2 thing, and i got identification on domoticz log and ping throught win7 command line. everything looks fine, but when i try mockmysensors to see if it recieves any comminication i dont see anything.
                  also the serial log looks wierd:
                  IP: 192.168.254.204
                  0;255;3;0;9;MCO:BGN:STP
                  0;255;3;0;9;Eth: connect
                  0;255;3;0;9;Eth: 0;0;3;0;2;
                  0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
                  0;255;3;0;9;Eth: 0;0;3;0;18;PING
                  and it goes on and on...
                  of course both nodes have gone eeprom clearing
                  • X Offline
                    X Offline
                    xefil
                    I'm following this guide to try compile the MQTTClient on a RFM69 but it doesn't work :(
                    I've Arduino UNO with Ethernet shield W5100 and RFM69. MySensors 2.2 API.
                    All was working well via serial port (so it means that the connection are ok and the level shifter as well), but I need to migrate to an IP version, better if MQTTClient.
                    I've used the @Frédéric-Grandjean patch and the @Jonathan-Caes modification on the #else error. I'm using arduino 1.8.2 software and I've downgraded the AVR Board to 1.6.11. It compiles fine, but the output is the following:
                    0 MCO:BGN:INIT GW,CP=RRNGTSM:INIT:TSP FAIL
                    10117 TSM:FAIL:CNT=2
                    10119 TSM:FAIL:DIS
                    10121 TSF:TDI:TSL
                    0 MCO:BGN:INIT GW,CP=RRNGA---,VER=2.2.0
                    3 TSM:INIT
                    4 TSF:WUR:MS=0
                    55 !TSM:INIT:TSP FAIL
                    56 TSM:FAIL:CNT=1
                    58 TSM:FAIL:DIS
                    59 TSF:TDI:TSL
                    10062 TSM:FAIL:RE-INIT
                    10064 TSM:INIT
                    10115 !TSM:INIT:TSP FAIL
                    10119 TSM:FAIL:DIS
                    10121 TSF:TDI:TSL
                    This is my code:
                    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway2-out"
                    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway2-in"
                    #define MY_MQTT_CLIENT_ID "mysensors-2"
                    #define MY_SOFTSPI
                    #ifndef MY_RF24_CE_PIN
                    #define MY_RF24_CE_PIN 5
                    #ifndef MY_RF24_CS_PIN
                    #define MY_RF24_CS_PIN 6
                    #define MY_IP_ADDRESS 192,168,1,52
                    #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
                    #define MY_CONTROLLER_IP_ADDRESS 192,168,1,50
                    #define MY_PORT 1883
                    Thanks a lot for any help!!
                    Simon
                    • FalcogeorgeF Offline
                      Falcogeorge
                      Well I’m a complete Noob here and started off with a similar setup.
                      I’m not going for an MQTT gateway, just Ethernet but my radio problems were similar with similar debug output.
                      I have an Etherten board and Rfm69 radio.
                      I’ve now got it working great. I didn’t change and code in w5100.h. What I did do was move the NSS from pin 10 down to pin 6 (7-9 was for the status LEDs)
                      So the only changes I have are as follows..
                      #define MY_RFM69_NEW_DRIVER
                      #define MY_RF69_SPI_CS 6
                      #define MY_RFM69_FREQUENCY (RFM69_433MHZ)
                      I thought I’d go with the new driver from the outset. I don’t think I needed to define the IRQ pin but I did it anyway. Moving CS was the fix for me initially to get past the radio errors. Then the final key was defining the frequency. Before I did that everything looked good but I couldn’t get a node talking to the gateway. As soon as I defined the frequency it all started working.
                      Now I just need to grow my hair back.
                      • JohnRobJ Offline
                        JohnRobJ Offline
                        JohnRob
                        @Falcogeorge
                        I have an RFM69 on a Anarduino (basically a AT328p with solder pads for the RFM69. I started with MySensors V2.2.0 My RFM69 NSS is connected to D10. All works fine. My setup code is below.
                        One note, the default debug baud is 115k. This is likely too fast for some with lower speed clocks.
                        #define MY_BAUD_RATE (9600ul)
                        // === Hardware / MySensors Initialization ================
                        #define MY_RFM69_FREQUENCY RFM69_915MHZ
                        // === Node Initialization ================================
                        #define CHILD_ID 5
                        #define sensortype S_MULTIMETER
                        #define LEDPIN 9 //PB1 is pin 9 on ProMini
                        #define LED_TST A0
                        #define NODE_TXT "Counting_test_Node"
                        uint8_t MyCount;
                        uint8_t ACK_Result;
                        uint8_t NACK_Count;
                        MyMessage msg_Voltage(CHILD_ID, V_VOLTAGE);
