  3. [SOLVED] W5100 Ethernet gateway with RFM69 Radio fails at init
31 Posts 9 Posters 13.8k Views 7 Watching
  • Frédéric GrandjeanF Offline
    Frédéric Grandjean
    I'm quite new to this great community and currently facing an issue with my first module; an Ethernet gateway (W5100) with 433Mhz RFM radio.
    As the Ethernet sample is more on NRF 2.4G radio, I have connected like this:
    Arduino - Radio - Ethernet
    13      -       - SCK
    12      -       - MISO/SO
    11      -       - MOSI/SI
    10      -       - SS/CS
    A2      - MISO
    A1      - MOSI
    A0      - SCK
    6       - NSS
    DI00 is not connected
    Of course, I use level converter chip for NSS, MOSI and SCK.
    From the code point of view, I added the radio defines, set the soft SPI pins (but I believe this is only for NRF radio), and it looks like this:
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_GATEWAY_W5100
    // radio on the same spi bus.
      #define MY_SOFTSPI
      #define MY_SOFT_SPI_SCK_PIN A0
      #define MY_SOFT_SPI_MISO_PIN A2
      #define MY_SOFT_SPI_MOSI_PIN A1
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,0,22
    #define MY_PORT 5003
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Ethernet.h>
    Error in debug log is:
    0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    How can I debug this?
    Thank you
    Frédéric
    • K Offline
      K Offline
      korttoma
      Hi, softSPI does not work with with the RFM69 yet. You need to use the same SPI pins for both W5100 and the radio.
      @jpaulin describes how in this thread
      • Tomas
        Frédéric Grandjean
        Hi Korttoma,
        Thanks a lot, I didn't find this thread.
        I have now lot's of improvements. Now gateway boots,and radio is OK.
        But when it shows the IP address, seems it reboots ... constantly.
        Y 1 Reply Last reply
        • Frédéric GrandjeanF Frédéric Grandjean
          Hi Korttoma,
          Y Offline
          Y Offline
          @Frédéric-Grandjean Try reverting the AVR board package, as described here: https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/3
            Frédéric Grandjean
            Perfect, thank you.
            That solved all issues! Now working super fine.
            • J Offline
              J Offline
              Jonathan Caes
              Hi, Frédéric Grandjean
              I'm also trying to build an ethernet gateway with the rfm69 radio's. But also have some errors when testing the code. Also I'm not sure I connected everything the right way, because there's not that info about those modules.
              Since you have this al working now, is it possible for me to take a look at your code and maybe show me how you connected everything?
              Thank you!
              Jonathan
                Frédéric Grandjean
                Hi Jonathan,
                Before I show my code, please check:
                • Connect W5100 and radio like this
                13      - SCK   - SCK
                12      - MISO  - MISO/SO
                11      - MOSI  - MOSI/SI
                10      - NSS (CS)
                7       -       - SS/CS
                2       - DIO0  -
                Be sure to power the W5100 with 5V and the radio with 3v3!
                Then, you need to modify the w5100.h file to disable radio interruption during SPI use:
                Find
                #else
                  inline static void initSS()    { DDRB  |=  _BV(2); };
                  inline static void setSS()     { PORTB &= ~_BV(2); };
                  inline static void resetSS()   { PORTB |=  _BV(2); };
                and replace with
                #elif defined(W5100SPIPATCH)
                  inline static void initSS()    { DDRD  |=  _BV(7); };
                  inline static void setSS()     { cli(); PORTD &= ~_BV(7); };
                  inline static void resetSS()   { PORTD |=  _BV(7); sei(); };
                Then, downgrade the board manager "Arduino AVR boards" to version 1.6.11 and rebuild.
                Finally, here is my working code:
                 * Version 1.0 - Henrik EKblad
                 * Contribution by Tomas Hozza <thozza@gmail.com>
                 * LED purposes:
                 * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
                // La définition des PIN ci dessous n'est pas nécessaire, car c'est celle de base
                //#define MY_RF69_IRQ_PIN 2
                //#define MY_RF69_SPI_CS 10
                #define MY_LEDS_BLINKING_FEATURE
                #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
                #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
                #define MY_DEFAULT_TX_LED_PIN  6  // Transmit led pin
                void presentation() {
                Hope it helped
                Fred
                J 2 Replies Last reply
                  Hi Jonathan,
                  13      - SCK   - SCK
                  12      - MISO  - MISO/SO
                  11      - MOSI  - MOSI/SI
                  10      - NSS (CS)
                  7       -       - SS/CS
                  2       - DIO0  -
                  Find
                  #else
                  and replace with
                   * LED purposes:
                  Hope it helped
                  Fred
                  J Offline
                  J Offline
                  Jonathan Caes
                  @Frédéric-Grandjean
                  Thank you for replying so quickly!
                  I`m going to try this as quickly as possible and let you know how it went.
                  Thanks!
                    Hi Jonathan,
                    13      - SCK   - SCK
                    12      - MISO  - MISO/SO
                    11      - MOSI  - MOSI/SI
                    10      - NSS (CS)
                    7       -       - SS/CS
                    2       - DIO0  -
                    Find
                    #else
                    and replace with
                     * LED purposes:
                    Hope it helped
                    Fred
                    J Offline
                    J Offline
                    Jonathan Caes
                    @Frédéric-Grandjean Have to wait untill my level converters are arriving.. also don't have enough transistors laying around to make one my self.. did you use a level converter, probably you did?
                      Frédéric Grandjean
                      Yes of course I used a level converter. Ordered the one proposed on the radio page. Works well!
                        J Offline
                        J Offline
                        Jonathan Caes
                        @Frédéric-Grandjean
                        Hey, I'm finally working on the gateway.
                        But the problem is that I can't seem to find the w5100.h file.. :s
                        Can you maybe tell me where I can find it?
                        Greetings
                          J Offline
                          J Offline
                          Jonathan Caes
                          @Frédéric-Grandjean
                          Hi again, because I'm a mac user didn't find the w5100.h file. after I took my laptop and searched for the file I found it.
                          after I replaced the code in the w5100.h file and changed the gateway code and complied I got these errors: 0_1484422292389_upload-59769e3e-1f23-4376-a3df-2c902afcdbeb
                          and it went on.
                          but when I changed the code in the w5100.h file from this:
                          To this:
                          #else	//This doesn't work => elif defined(W5100SPIPATCH)
                          it compiled without any errors.
                          So I uploaded the code and opened the serial debugging window in which I get this:
                          0_1484423132127_upload-e0346356-c42c-4039-add5-612525c85127
                          I don't know how to fix this, do you know maybe?
                          Thanks!!
                          Greetings!
                          A 1 Reply Last reply
                          • T Offline
                            T Offline
                            Tris
                            Jonathan Caes - i used your amended #else code in W5100.h file, along with wiring/pinout from Frédéric Grandjean, and example Mysensors MQTTClientGateway sketch and got a ProMiniMQTTW5100Gateway working.
                            You are trying Ethernet gateway (not MQTT like me), but i think you may have a radio problem - i used 10uF and 1uF caps for the RFM69 radio and separate 3.3V supply (havent tried powering radio directly from ProMini VCC though.
                            J 1 Reply Last reply
                            • J Jonathan Caes
                              @Frédéric-Grandjean
                              and it went on.
                              To this:
                              Thanks!!
                              Greetings!
                              A Offline
                              A Offline
                              abrasha
                              @Jonathan-Caes @Frédéric-Grandjean
                              if i use w5100 shield on uno - so i cant connect the pins how i want - means w5100 cs stays on pin 10.
                              what should i do?
                              • T Offline
                                T Offline
                                Tris
                                For W5100 shield on Uno with RF69 as a Gateway, i used:
                                DI00 - Pin 2
                                NSS - Pin 4 (3.3v level shifter)
                                MOSI - Pin A1 (3.3v level shifter)
                                MISO - Pin A2
                                SCK - Pin A0 (3.3v level shifter)
                                Leave as pins 14/15/16 in MyConfig.h file - the Uno uses digital pins 14-16 physically as A0-A3.
                                Using a level shifter makes the ProMini more viable as it is 3.3v and you dont need a shifter.
                                • T Tris
                                  DI00 - Pin 2
                                  MISO - Pin A2
                                  A Offline
                                  A Offline
                                  abrasha
                                  @Tris with or without w5100. H mod?
                                  • T Offline
                                    T Offline
                                    Tris
                                    I THINK with the W5100.h file amended.
                                    try using Mysensors ClearEepromConfig too
                                    A 2 Replies Last reply
                                    • T Tris
                                      A Offline
                                      A Offline
                                      abrasha
                                      @Tris thanks a lot. I'll check it on Sunday.
                                      Btw i use adafruit rfm69hw breakout so no level shifter needed, but i need to post my fix for it because it needs my transport.h mod
                                      • T Tris
                                        J Offline
                                        J Offline
                                        Jonathan Caes
                                        @Tris But I don't necessarily have to use the mqttw5100gateway, do I? Because I don't really know what you can do with mqtt, what the advantage is of that.
                                        I'm also using seperate 3.3V and a 4.7µF capacitor for the radio.
                                        Here is my schematic I used. I etched my own pcb for this and I think everything looks correct.
                                        0_1484907018198_upload-9caf576c-a61e-4bf4-90ba-e108c51e4a94
                                        • T Offline
                                          T Offline
                                          Tris
                                          The Ethernet and MQTT wiring is the same (according to main MySesnors instructions).
                                          As far as protocols go, I choose the MQTT route because its simple and lightwieght, tipped to be a big player in IoT.
                                          Im not a Mysensors expert, more of a hardware guy, but briefly looking at your diagram - i havent grounded the reset pin on the RFM69 like you have.
                                          Try cutting that track so it floats
                                          J 3 Replies Last reply
                                          12.2k
