  3. rpi gateway with nrf24 sharing spi with other hardware
4 Posts 2 Posters 1.4k Views 2 Watching
  • rozpruwaczR
    rozpruwaczR
    rozpruwacz
    Hi all,
    is there any software that implements any type of a gateway that can be used with nrf24 module connected to the spi bus shared with other hardware ? I'm already using spi0 to connect with audio dac (so i'm not able to use spi1 since it is used as pcm bus) and i think that this will not work with the software that uses bcm2825 driver to communicate with nrf module.
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      i found this repo:
      https://github.com/mysensors/Raspberry
      and was able to compile it and run with the newest RF24 library with SPIDEV driver. it seems to comunicate with the nrf module correctly but i think it is not updated to MySensors 2.0 so my sensors (not MySensors :)) are not compatible. Are ther plans to update this repo to MySensors 2.0 ?
      • rozpruwaczR rozpruwacz
        i found this repo:
        @rozpruwacz Yes. See https://www.mysensors.org/build/raspberry (currently requires the development branch of MySensors)
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          ok, so how do i configure the build to use RF24 with SPIDEV driver ?
