  3. Efergy e2 power meter
33 Posts 9 Posters 17.2k Views 11 Watching
  • korttomaK
    korttomaK
    korttoma
    Tried exchanging the NRF24L01+ with an RFM69 but it does not seem to work at all with this setup. Might be because the RFM69 is using the same frequency as the RFM12B or maybe I can not have the 2 in the same node because they are related.
    • Tomas
    • G gtortone
      @korttoma
      at the moment I'm defining some things in order to use RFM69 modules...
      in the past, on my NRF24L01+ I was using 10 uF capacitor but I had same problems of "stop responding"...
      korttomaK
      korttomaK
      korttoma
      @gtortone did you have any chance to look at the "stop responding" issue of this device?
      I tried to add some more debug prints to your code today but if I add them to the wrong places the efergy receive function stops working and receives only 0 value. I guess it messes with the timing.
      • Tomas
      G 1 Reply Last reply
      • korttomaK korttoma
        G
        G
        gtortone
        @korttoma Hi, I just returned to play with Efergy and Arduino. I realized that debug messages on UART reset the micro. Now I'm skipping (with a #define DEBUG and #ifdef) all debug messages and it seems to work fine. But take into account that now I'm not using any radio module... just to test the firmware.
        • korttomaK
          korttomaK
          korttoma
          #24
          :D What a coincidence. I returned to this project today also. Now trying to set this up as an Ethernet GW with local sensor without NRF radio. I still have to share the SPI bus with the Ethernet module though. I'll let you know how it goes.
          I think I did try removing the serial prints earlier but I'm not sure..
          • Tomas
          • korttomaK
            korttomaK
            korttoma
            The ethernet GW approach performs even worse than your original solution. I get one or 2 measurements and then nothing. Still responds to ping but no communication with the controller.
            I don't know how to debug this since it just stops working. Is there by any chance anything in the code that consumes memory?
            • Tomas
            • A
              A
              ailiev
              Hi All,
              First of all, great work man!
              I was wondering do you know if we need to have established link between the wireless sensor and the receiver?
              I only have the wireless sensor so I was wondering if I can use this without the receiver?
              Any thoughts?
              korttomaK 1 Reply Last reply
              • A ailiev
                Hi All,
                Any thoughts?
                korttomaK
                korttomaK
                korttoma
                @ailiev it "works" without the receiver but for me the node fails after about 1h so I gave up. I could try again now with the new MySensors 2.2.0 lib to see if it makes any difference (when I find some time).
                • Tomas
                • S
                  shifaz
                  I have been trying to receive the efergy signal using RFM69 and so far it's a dead end. I'm unable to receive any data on the RFM69 module.
                  Since you guys talked about RFM69 module here, I thought you might have some insight to share.
                  gohanG 1 Reply Last reply
                  • S shifaz
                    @shifaz I think you need the RFM12B to receive the data you want
                    • J
                      J
                      Jens Lauridsen
                      wrote on last edited by Jens Lauridsen
                      #30
                      @gtortone
                      Any chance that I can see how you wired up the NRF24L01+? I bought the parts back in January 2017 and just found it in a drawer this evening. I assembled everything but the NRF24L01+ and I am a bit stuck right now.
                      BTW: Great build - I really hope that I will get mine up and running :)
                      /Jens
                      • B
                        B
                        banda banda
                        Banned
                        #31
                        Since you guys talked about RFM69 module here, I thought you might have some insight to share. (spam links removed by moderator)
                          @gtortone that is the same useless junk I got from e-bay at first, range is terrible.
                          This gives me some hope to get this working with the RXB6. I will test this as son as I can (might be a few weeks until I can).
                          MaurettoFarmer
                          @korttoma
                          I resume an old topic: i'm trying to receive data from Energy2 whith arduino connected to an RXB6. I can't receive any data, and i don't know how to substitute the code block related to RF12 with a correct one for my receiver. Can someone help me? Thanks in advance, Mauro
                            mrives
                            Long story short, try 433.55 MHz
                            I tried for years to received my Chacon Ecowatt 800 (a rebranded Efergy 2 classic) data. I knew the frequency wasn't 433.92 MHz.
                            I lastly opened transmitter case to find which RF chip was used ... but I didn't get any datasheet for the "A71C03AUF" I found :(
                            On last resort, I sought a signal on all "433.92MHz" ISM band (433.05~434.79 MHz, with sdr-sharp). I did find something centered on 433.51 (433.47 and 433.56, FSK?) MHz.
                            As for Somfy stuff (which uses 433.42 MHz), many generic receiver can't work with those *special" 433MHz frequencies.
                            In the end, I tested this new frequency using rtl-433 and guess what, there's a working Efergy module ! Moreover, I did not make a great discover, 433.55MHz is well precised in the "efergy_e2_classic.c" module comments...
                            RFM69 or NRF24L01 may be frequency ajustable!
