  3. Home Assistant
  4. Reversed Relay
Reversed Relay
8 Posts 4 Posters 3.1k Views 4 Watching
  • RoosterR Offline
    RoosterR Offline
    Rooster
    Hi, I was wondering if anyone can tell me what's going on here?
    I've got a relay node setup but as soon as it's registered by HASS is flicks the relay to on even though the web GUI shows it as off? Flicking the switch in the GUI to on turns the relay off... I'm sure it must be something obvious but I can't see it.
    Here's the sketch on the node:
    #define MY_REPEATER_FEATURE
    //#define MY_NODE_ID 1
    #define RELAY_PIN  3
    #define CHILD_ID 1
    #define RELAY_ON 1
    #define RELAY_OFF 0
    bool state = false;
    bool initialValueSent = false;
    MyMessage msg(CHILD_ID, V_STATUS);
      pinMode(RELAY_PIN, OUTPUT);
    void presentation()  {
      sendSketchInfo("MyRelay", "1.0");
      present(CHILD_ID, S_BINARY);
      if (!initialValueSent) {
        send(msg.set(state?RELAY_ON:RELAY_OFF));
        Serial.println("Requesting initial value from controller");
        request(CHILD_ID, V_STATUS);
        wait(2000, C_SET, V_STATUS);
      if (message.isAck()) {
          Serial.println("Receiving initial value from controller");
          initialValueSent = true;
        // Change relay state
        state = (bool)message.getInt();
    When the Node presents itself to HASS I get the following:
    12/5/2016 11:15:19 PM16-12-05 23:15:19 INFO (Thread-12) [homeassistant.components.mysensors] Adding new devices: <Entity MyRelay 1 1: off>
    12/5/2016 11:15:19 PM16-12-05 23:15:19 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.myrelay_1_1, old_state=None, new_state=<state switch.myrelay_1_1=unavailable; friendly_name=MyRelay 1 1 @ 2016-12-05T23:15:19.403632+00:00>>
    12/5/2016 11:15:19 PM16-12-05 23:15:19 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, old_state=<state group.all_switches=off; auto=True, entity_id=('switch.wswitch1',), friendly_name=all switches, hidden=True, order=1 @ 2016-12-05T23:14:34.823591+00:00>, new_state=None>
    12/5/2016 11:15:19 PM16-12-05 23:15:19 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, old_state=None, new_state=<state group.all_switches=off; auto=True, entity_id=('switch.myrelay_1_1', 'switch.wswitch1'), friendly_name=all switches, hidden=True, order=1 @ 2016-12-05T23:15:19.406471+00:00>>
    12/5/2016 11:15:19 PM16-12-05 23:15:19 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.myrelay_1_1, old_state=<state switch.myrelay_1_1=unavailable; friendly_name=MyRelay 1 1 @ 2016-12-05T23:15:19.403632+00:00>, new_state=<state switch.myrelay_1_1=off; description=, node_id=1, friendly_name=MyRelay 1 1, V_STATUS=off, device=172.16.23.30, battery_level=0, child_id=1 @ 2016-12-05T23:15:19.410796+00:00>>]
    But no other mentions of switches or states.
    Any ideas??
    • martinhjelmareM Offline
      martinhjelmare
      I suggest either inverting the high/low logic when writing to the relay, or checking and possibly changing the wiring of the relay. Some relays "default" to on (active low).
      • RoosterR Offline
        RoosterR Offline
        Rooster
        Thanks, that never occurred to me and your're absolutely correct, the relay does default to on.
        Ill have a play with the sketch and see if I can figure out how to reverse it, I'm pretty new to this though so I may be back asking for help before long.
        Thanks again.
        • RoosterR Rooster
          Thanks again.
          @Rooster replace
          #define RELAY_ON 1
          #define RELAY_OFF 0
          with
          #define RELAY_ON 0
          #define RELAY_OFF 1
          to reverse. It's that simple :)
            @Rooster replace
            #define RELAY_ON 1
            #define RELAY_OFF 0
            with
            #define RELAY_ON 0
            #define RELAY_OFF 1
            martinhjelmare
            @mfalkvidd
            Only doing that will also reverse the reporting to home assistant, I think. You can maybe add two new defines for either the reporting or the the writing to the relay.
            • RoosterR Offline
              RoosterR Offline
              Rooster
              Thanks for the help I actually fixed the scketch by reversing the RELAY_ON:RELAY_OFF in the digital write. However I was hoping to expand the script to include two relays. After comparing this sketch with the RelayActuator example it was pretty clear that my coding skills would fall short of being able to modify the first sketch.
              Instead I've modified the RelayActuator example (which by default doesn't send the initial states required by HASS).
              This sketch is working well although I think it would have a problem if I wanted the child ID of the first relay to be anything but 1 (but I dont so thats ok for now :) )
              As I said I'm pretty new to this so if there are any glaring problems with how im doing this I'd welcome the feedback.
              Thanks again for the help.
               * Version 1.0 - Henrik Ekblad
              void before() {
                  pinMode(pin, OUTPUT);
                  present(sensor, S_BINARY);
                  MyMessage msg(sensor, V_STATUS);
                  send(msg.set(0));
                  wait(1000);
                if (message.type==V_STATUS) {
                   digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_OFF:RELAY_ON);
                   // Store state in eeprom
                   // Write some debug info
                   Serial.print(message.sensor);
                   // Tell Controller about it
                   MyMessage msg(message.sensor-1+RELAY_1, V_STATUS);
                   send(msg.set(message.getBool()?RELAY_OFF:RELAY_ON));
              B 1 Reply Last reply
              • RoosterR Rooster
                void before() {
                    send(msg.set(0));
                    wait(1000);
                B Offline
                B Offline
                blacey
                @Rooster If you only want to send the initial values once, you can move the logic to setup(). Setup is called after the radio transport is initialized however you may need the 2.1 beta.
                  martinhjelmare
                  In mysensors 2.0 setup is called before registering the sensors at the gateway, so values can't be sent during setup in 2.0. This is changed in 2.1.
