  3. Home Assistant
  4. [Solved] Auto reset motion sensor state
3 Posts 2 Posters 3.3k Views 2 Watching
  • abmantisA
    abmantisA
    abmantis
    wrote on last edited by abmantis
    Is there any way to set the state of a motion sensor (binary_sensor) to "off" from Home Assistant?
    My sensor sends a TRIPPED=0 when there's no movement, but if the message is lost or the sensor goes out of battery, I want it to appear as "off" in HA after some time.
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      You could use a template binary sensor that is based on the mysensors binary sensor but also checks time since last changed state.
      See the last example here for how to use last changed state.
      https://home-assistant.io/topics/templating/#sensor-states
      • abmantisA
        abmantisA
        abmantis
        @martinhjelmare great idea! Thank you.
