  3. Serial gateway error???
4 Posts 2 Posters 1.0k Views 2 Watching
  • speedieS
    speedieS
    speedie
    Strange behavior of serial gateway.
    I already build it and used it with Pimatic and it works.
    Now i want to use it with Domotics but it did not work.
    Whem i look in the serial monitoring I see this error?
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    dbemowskD 1 Reply Last reply
    • speedieS speedie
      0;255;3;0;9;TSM:PDT
      dbemowskD
      dbemowskD
      @speedie Radio failures are usually due to not havin, or having the wrong value capacitor on your radio. Put the capacitor right next to, or directly on top of the radio header connector on the incoming power line.
      • speedieS
        speedieS
        speedie
        Hello @dbemowsk ,
        But it worked in Pimatic,
        Seems to me that then the serialgateway was working?
        • speedieS speedie
          Hello @dbemowsk ,
          dbemowskD
          dbemowskD
          @speedie It still could be a capacitor issue. Another thing, check your solder joints and wires to the radio. The first gateway I built worked intermittently and a bad connection was the cause.
