  3. Vera
  4. "Choose the Serial Port" error with MySensors and RFXtrx433?
29 Posts 6 Posters 12.6k Views 6 Watching
  • Aron SjöbergA Aron Sjöberg
    @Magnus Thank you for your trouble! Did you photoshop your screenshot or can you configure two different serial port devices at the same time? I only have one instance I can change settings for?
    Otherwise my settings seems to be the same as yours.
    MagnusM
    MagnusM
    Magnus
    @Aron-Sjöberg I can configure both ports at the same time. It looks exactly as in the posted picture.
    @BartE I justfollowed the instructions on the website. This was probably a year ago and the code used for the serial GW was designed only for Arduino Nano 328p / 16MHz.
    • Aron SjöbergA
      Aron SjöbergA
      Aron Sjöberg
      Thank you for your help!
      Unfortunately nothing works. I have even tried to change the radio module from RFM69 to NRF24L01 to make sure it wasn't the connections that was badly soldered.
      @Magnus Could you please post the sketch you use for your gateway? I tried to add #define MY_BAUD_RATE 38400 as @BartE suggested but this doesn't seem to make a difference.
      I'm starting to think there is something wrong on Veras end. I don't get two different devices under the Serial Port configuration like @Magnus. You also have different ports (3482 for the serial gateway and 3481 for the RFXtrx).
      As a last resort I guess I could install Domoticz on a RPi and import the devices to the Vera as virtual devices, but this seems like a hassle if it is possible for the gateway to work directly.
      • korttomaK
        korttomaK
        korttoma
        Have you ever confirmed that the MySensors USB gateway works without the RFXtrx attached? Or checked that you really have an FTDI chip on the MySensors USB gateway? This is the only chip that the Vera can detect out of the box. A complete reboot of your Vera might also help.
        • Tomas
        • Aron SjöbergA
          Aron SjöbergA
          Aron Sjöberg
          I'm using a Arduino Nano. How do I check if it is a genuine FTDI chip?
          korttomaK 1 Reply Last reply
            korttomaK
            korttomaK
            korttoma
            @Aron-Sjöberg the FTDI chip is on the under side of Arduino nanos and clearly sais FTDI. Please post pictures of your devise if your uncertain. I don't know if fake or real maters when used on Vera.
            • Tomas
            • Aron SjöbergA
              Aron SjöbergA
              Aron Sjöberg
              @korttoma said in "Choose the Serial Port" error with MySensors and RFXtrx433?:
              Arduino nanos
              It's a bit hard to read but the black chips on the back says:
              A106
              and
              WCH
              CH340G
              202686635
              and
              AMS1117
              5.0 DN628
              on the front (where the button is)
              ALMEL
              MEGA328P
              AU 1639
              I can't find any mention of "FTDI". Should I assume it is not a genuine Arduino nano?
              I DO have an unused Arduino Uno laying around. Maybe it would be easier to buy a ethernet shield and use a ethernet gateway instead of the serial gateway? Is it a W5100 ethernet shield I would need for the Uno?
              MagnusM 2 Replies Last reply
                Arduino nanos
                A106
                and
                WCH
                CH340G
                202686635
                and
                AMS1117
                5.0 DN628
                ALMEL
                MEGA328P
                AU 1639
                MagnusM
                MagnusM
                Magnus
                @Aron-Sjöberg I would guess the problems are due to the CH340G chip (instead of an FTDI chip). I use this nano for my gateway:
                https://www.aliexpress.com/item/Nano-V3-0-Mini-USB-ATmega328-5V-16M-100-ORIGINAL-FTDI-FT232RL/32338360936.html?spm=2114.13010608.0.0.ZU4WHD
                  Arduino nanos
                  A106
                  and
                  WCH
                  CH340G
                  202686635
                  and
                  AMS1117
                  5.0 DN628
                  ALMEL
                  MEGA328P
                  AU 1639
                  MagnusM
                  MagnusM
                  Magnus
                  @Aron-Sjöberg Used sketch below, I didn't make any changes to the original sketch:
                   * The ArduinoGateway prints data received from sensors on the serial link.
                   * The gateway accepts input on seral which will be sent out on radio network.
                   * The GW code is designed for Arduino Nano 328p / 16MHz
                   * Wire connections (OPTIONAL):
                   * - Inclusion button should be connected between digital pin 3 and GND
                   * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
                   * LEDs (OPTIONAL):
                  #define NO_PORTB_PINCHANGES
                  #include <MySigningNone.h>
                  #include <MyTransportRFM69.h>
                  #include <MyTransportNRF24.h>
                  #include <MyHwATMega328.h>
                  #include <MySigningAtsha204Soft.h>
                  #include <MySigningAtsha204.h>
                  #include <MyParserSerial.h>
                  #include <stdarg.h>
                  #include <PinChangeInt.h>
                  #include "GatewayUtil.h"
                  #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
                  #define INCLUSION_MODE_PIN  3 // Digital pin used for inclusion mode button
                  #define RADIO_ERROR_LED_PIN 4  // Error led pin
                  #define RADIO_RX_LED_PIN    6  // Receive led pin
                  #define RADIO_TX_LED_PIN    5  // the PCB, on board LED
                  MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                  //MyTransportRFM69 transport;
                  // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
                  //MySigningNone signer;
                  //MySigningAtsha204Soft signer;
                  //MySigningAtsha204 signer;
                  // Hardware profile
                  MyHwATMega328 hw;
                  // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
                  // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
                  #ifdef WITH_LEDS_BLINKING
                  MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                  #else
                  MySensor gw(transport, hw /*, signer*/);
                  char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                  int inputPos = 0;
                  boolean commandComplete = false;  // whether the string is complete
                  void parseAndSend(char *commandBuffer);
                  void output(const char *fmt, ... ) {
                     va_list args;
                     va_start (args, fmt );
                     vsnprintf_P(serialBuffer, MAX_SEND_LENGTH, fmt, args);
                     va_end (args);
                     Serial.print(serialBuffer);
                    gw.begin(incomingMessage, 0, true, 0);
                    setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output);
                    // Add interrupt for inclusion button to pin
                    PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
                    // Send startup log message on serial
                    serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
                    gw.process();
                    checkButtonTriggeredInclusion();
                    checkInclusionFinished();
                    if (commandComplete) {
                      // A command wass issued from serial interface
                      // We will now try to send it to the actuator
                      parseAndSend(gw, inputString);
                      inputPos = 0;
                    SerialEvent occurs whenever a new data comes in the
                   hardware serial RX.  This routine is run between each
                   time loop() runs, so using delay inside loop can delay
                   response.  Multiple bytes of data may be available.
                  void serialEvent() {
                    while (Serial.available()) {
                      // get the new byte:
                      char inChar = (char)Serial.read();
                      // if the incoming character is a newline, set a flag
                      // so the main loop can do something about it:
                      if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
                        if (inChar == '\n') {
                          inputString[inputPos] = 0;
                          commandComplete = true;
                        } else {
                          // add it to the inputString:
                          inputString[inputPos] = inChar;
                          inputPos++;
                      } else {
                         // Incoming message too long. Throw away
                          inputPos = 0;
                  • Aron SjöbergA
                    Aron SjöbergA
                    Aron Sjöberg
                    Thanks @Magnus!
                    I'll order the one you linked to and see if that works better. I assume I can always use my current ones as base for sensors instead of a gateway. I'll order a ethernet shield as well, so I can try and build a ethernet gateway if my Vera Edge still doesn't recognize the new Nano.
                    However, your sketch is not the same as the one in the getting started guide? The sketch I've used is this, from https://www.mysensors.org/build/serial_gateway :
                    * LEDs (OPTIONAL):
                    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                    // Enable serial gateway
                    #define MY_GATEWAY_SERIAL
                    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
                    #if F_CPU == 8000000L
                    // Enable inclusion mode
                    // Set blinking period
                    // Flash leds on rx/tx/err
                    This sketch seems to be the same as the one in the Ardinuo IDE named "GatewaySerial":
                    * LEDs (OPTIONAL):
