  3. Vera
  4. "Choose the Serial Port" error with MySensors and RFXtrx433?
29 Posts 6 Posters 12.9k Views 6 Watching
  • BartEB BartE
    @Magnus just a wild guess.
    Did you try to compile the MySensors GW with baudrate set to 38400 so they both use the same baudrate?
    Aron SjöbergA
    Aron SjöbergA
    Aron Sjöberg
    @BartE Hmm... I didn't know you could choose the baudrate? I just followed the instructions on the website (https://www.mysensors.org/build/serial_gateway) but when I check the code I can clearly read that there is something in the sketch about the baud rate:
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    However, I use the recommended Arduino Nano for my Vera Serial Gateway, not Arduino Pro Mini 3.3V or SenseBender.
    How would I change the baud rate for the MySensor gateway if I can't use 38400 because it is used by my RFXtrx433E?
    BartEB 1 Reply Last reply
    • MagnusM Magnus
      @Aron-Sjöberg
      My config below:
      0_1487014260023_upload-8c1c7a47-553e-4710-bd9d-6492dcabd120
      Aron SjöbergA
      Aron SjöbergA
      Aron Sjöberg
      @Magnus Thank you for your trouble! Did you photoshop your screenshot or can you configure two different serial port devices at the same time? I only have one instance I can change settings for?
      Otherwise my settings seems to be the same as yours.
      MagnusM 1 Reply Last reply
      • Aron SjöbergA Aron Sjöberg
        BartEB
        BartEB
        BartE
        @Aron-Sjöberg said in "Choose the Serial Port" error with MySensors and RFXtrx433?:
        Add this line
        above the #include <SPI.h>
        • miroM
          miroM
          miro
          @Aron-Sjöberg
          Have you restart luup after you connected both usb-ports?
            MagnusM
            MagnusM
            Magnus
            @Aron-Sjöberg I can configure both ports at the same time. It looks exactly as in the posted picture.
            @BartE I justfollowed the instructions on the website. This was probably a year ago and the code used for the serial GW was designed only for Arduino Nano 328p / 16MHz.
            • Aron SjöbergA
              Aron SjöbergA
              Aron Sjöberg
              Thank you for your help!
              Unfortunately nothing works. I have even tried to change the radio module from RFM69 to NRF24L01 to make sure it wasn't the connections that was badly soldered.
              @Magnus Could you please post the sketch you use for your gateway? I tried to add #define MY_BAUD_RATE 38400 as @BartE suggested but this doesn't seem to make a difference.
              I'm starting to think there is something wrong on Veras end. I don't get two different devices under the Serial Port configuration like @Magnus. You also have different ports (3482 for the serial gateway and 3481 for the RFXtrx).
              As a last resort I guess I could install Domoticz on a RPi and import the devices to the Vera as virtual devices, but this seems like a hassle if it is possible for the gateway to work directly.
              • korttomaK
                korttomaK
                korttoma
                Have you ever confirmed that the MySensors USB gateway works without the RFXtrx attached? Or checked that you really have an FTDI chip on the MySensors USB gateway? This is the only chip that the Vera can detect out of the box. A complete reboot of your Vera might also help.
                • Tomas
                • Aron SjöbergA
                  Aron SjöbergA
                  Aron Sjöberg
                  I'm using a Arduino Nano. How do I check if it is a genuine FTDI chip?
                  korttomaK 1 Reply Last reply
                    korttomaK
                    korttomaK
                    korttoma
                    @Aron-Sjöberg the FTDI chip is on the under side of Arduino nanos and clearly sais FTDI. Please post pictures of your devise if your uncertain. I don't know if fake or real maters when used on Vera.
                    • Tomas
                    • Aron SjöbergA
                      Aron SjöbergA
                      Aron Sjöberg
                      @korttoma said in "Choose the Serial Port" error with MySensors and RFXtrx433?:
                      Arduino nanos
                      It's a bit hard to read but the black chips on the back says:
                      A106
                      and
                      WCH
                      CH340G
                      202686635
                      and
                      AMS1117
                      5.0 DN628
                      on the front (where the button is)
                      ALMEL
                      MEGA328P
                      AU 1639
                      I can't find any mention of "FTDI". Should I assume it is not a genuine Arduino nano?
                      I DO have an unused Arduino Uno laying around. Maybe it would be easier to buy a ethernet shield and use a ethernet gateway instead of the serial gateway? Is it a W5100 ethernet shield I would need for the Uno?
                      MagnusM 2 Replies Last reply
                        Arduino nanos
                        A106
                        and
                        WCH
                        CH340G
                        202686635
                        and
                        AMS1117
                        5.0 DN628
                        ALMEL
                        MEGA328P
                        AU 1639
                        MagnusM
                        MagnusM
                        Magnus
                        @Aron-Sjöberg I would guess the problems are due to the CH340G chip (instead of an FTDI chip). I use this nano for my gateway:
                        https://www.aliexpress.com/item/Nano-V3-0-Mini-USB-ATmega328-5V-16M-100-ORIGINAL-FTDI-FT232RL/32338360936.html?spm=2114.13010608.0.0.ZU4WHD
                          Arduino nanos
                          A106
                          and
                          WCH
                          CH340G
                          202686635
                          and
                          AMS1117
                          5.0 DN628
                          ALMEL
                          MEGA328P
                          AU 1639
                          MagnusM
                          MagnusM
                          Magnus
                          @Aron-Sjöberg Used sketch below, I didn't make any changes to the original sketch:
                           * LEDs (OPTIONAL):
                          #define NO_PORTB_PINCHANGES
                          #include <MySigningNone.h>
                          #include <MyTransportRFM69.h>
                          #include <MyTransportNRF24.h>
                          #include <MyHwATMega328.h>
                          #include <MyParserSerial.h>
                          #include <stdarg.h>
                          #include <PinChangeInt.h>
                          #include "GatewayUtil.h"
                          //MyTransportRFM69 transport;
                          //MySigningNone signer;
                          //MySigningAtsha204 signer;
                          // Hardware profile
                          MyHwATMega328 hw;
                          #ifdef WITH_LEDS_BLINKING
                          MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                          char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                          int inputPos = 0;
                          boolean commandComplete = false;  // whether the string is complete
                          void parseAndSend(char *commandBuffer);
                          void output(const char *fmt, ... ) {
                             va_list args;
                             va_start (args, fmt );
                             va_end (args);
                             Serial.print(serialBuffer);
                            // Add interrupt for inclusion button to pin
                            PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
                            // Send startup log message on serial
                            serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
                            checkInclusionFinished();
                            if (commandComplete) {
                              // A command wass issued from serial interface
                              // We will now try to send it to the actuator
                              parseAndSend(gw, inputString);
                              inputPos = 0;
                            SerialEvent occurs whenever a new data comes in the
                           hardware serial RX.  This routine is run between each
                           time loop() runs, so using delay inside loop can delay
                           response.  Multiple bytes of data may be available.
                          void serialEvent() {
                            while (Serial.available()) {
                              // get the new byte:
                              char inChar = (char)Serial.read();
                              // if the incoming character is a newline, set a flag
                              // so the main loop can do something about it:
                              if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
                                if (inChar == '\n') {
                                  inputString[inputPos] = 0;
                                  commandComplete = true;
                                  // add it to the inputString:
                                  inputString[inputPos] = inChar;
                                  inputPos++;
                                  inputPos = 0;
                          • Aron SjöbergA
                            Aron SjöbergA
                            Aron Sjöberg
                            Thanks @Magnus!
                            I'll order the one you linked to and see if that works better. I assume I can always use my current ones as base for sensors instead of a gateway. I'll order a ethernet shield as well, so I can try and build a ethernet gateway if my Vera Edge still doesn't recognize the new Nano.
                            However, your sketch is not the same as the one in the getting started guide? The sketch I've used is this, from https://www.mysensors.org/build/serial_gateway :
                            * LEDs (OPTIONAL):
                            * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                            // Enable serial gateway
                            #define MY_GATEWAY_SERIAL
                            // Enable inclusion mode
                            // Set blinking period
                            // Flash leds on rx/tx/err
                            This sketch seems to be the same as the one in the Ardinuo IDE named "GatewaySerial":
                            * LEDs (OPTIONAL):
