  3. Vera
  4. "Choose the Serial Port" error with MySensors and RFXtrx433?
29 Posts 6 Posters 12.9k Views 6 Watching
  • Aron SjöbergA Aron Sjöberg
    Argh!
    I finally received my new USB-hub and tried a new serial gateway I built.
    I STILL get the same error. I can't seem to have both my RFXtrx433E and the MySensor gateway connected (and working) at the same time.
    @Magnus, could you post a screenshot of your settings in Vera Edge?
    MagnusM
    MagnusM
    Magnus
    wrote on last edited by Magnus
    @Aron-Sjöberg
    My config below:
    0_1487014260023_upload-8c1c7a47-553e-4710-bd9d-6492dcabd120
    BartEB Aron SjöbergA 2 Replies Last reply
    • MagnusM Magnus
      @Aron-Sjöberg
      My config below:
      BartEB
      BartEB
      BartE
      @Magnus just a wild guess.
      Did you try to compile the MySensors GW with baudrate set to 38400 so they both use the same baudrate?
      Aron SjöbergA 1 Reply Last reply
      • BartEB BartE
        Aron SjöbergA
        Aron SjöbergA
        Aron Sjöberg
        @BartE Hmm... I didn't know you could choose the baudrate? I just followed the instructions on the website (https://www.mysensors.org/build/serial_gateway) but when I check the code I can clearly read that there is something in the sketch about the baud rate:
        #if F_CPU == 8000000L
        #define MY_BAUD_RATE 38400
        However, I use the recommended Arduino Nano for my Vera Serial Gateway, not Arduino Pro Mini 3.3V or SenseBender.
        How would I change the baud rate for the MySensor gateway if I can't use 38400 because it is used by my RFXtrx433E?
        BartEB 1 Reply Last reply
        • MagnusM Magnus
          @Aron-Sjöberg
          My config below:
          Aron SjöbergA
          Aron SjöbergA
          Aron Sjöberg
          @Magnus Thank you for your trouble! Did you photoshop your screenshot or can you configure two different serial port devices at the same time? I only have one instance I can change settings for?
          Otherwise my settings seems to be the same as yours.
          MagnusM 1 Reply Last reply
            BartEB
            BartEB
            BartE
            @Aron-Sjöberg said in "Choose the Serial Port" error with MySensors and RFXtrx433?:
            Add this line
            above the #include <SPI.h>
            • miroM
              miroM
              miro
              @Aron-Sjöberg
              Have you restart luup after you connected both usb-ports?
                MagnusM
                MagnusM
                Magnus
                @Aron-Sjöberg I can configure both ports at the same time. It looks exactly as in the posted picture.
                @BartE I justfollowed the instructions on the website. This was probably a year ago and the code used for the serial GW was designed only for Arduino Nano 328p / 16MHz.
                • Aron SjöbergA
                  Aron SjöbergA
                  Aron Sjöberg
                  Thank you for your help!
                  Unfortunately nothing works. I have even tried to change the radio module from RFM69 to NRF24L01 to make sure it wasn't the connections that was badly soldered.
                  @Magnus Could you please post the sketch you use for your gateway? I tried to add #define MY_BAUD_RATE 38400 as @BartE suggested but this doesn't seem to make a difference.
                  I'm starting to think there is something wrong on Veras end. I don't get two different devices under the Serial Port configuration like @Magnus. You also have different ports (3482 for the serial gateway and 3481 for the RFXtrx).
                  As a last resort I guess I could install Domoticz on a RPi and import the devices to the Vera as virtual devices, but this seems like a hassle if it is possible for the gateway to work directly.
                  • korttomaK
                    korttomaK
                    korttoma
                    Have you ever confirmed that the MySensors USB gateway works without the RFXtrx attached? Or checked that you really have an FTDI chip on the MySensors USB gateway? This is the only chip that the Vera can detect out of the box. A complete reboot of your Vera might also help.
                    • Tomas
                    • Aron SjöbergA
                      Aron SjöbergA
                      Aron Sjöberg
                      I'm using a Arduino Nano. How do I check if it is a genuine FTDI chip?
                      korttomaK 1 Reply Last reply
                        korttomaK
                        korttomaK
                        korttoma
                        @Aron-Sjöberg the FTDI chip is on the under side of Arduino nanos and clearly sais FTDI. Please post pictures of your devise if your uncertain. I don't know if fake or real maters when used on Vera.
                        • Tomas
                        • Aron SjöbergA
                          Aron SjöbergA
                          Aron Sjöberg
                          @korttoma said in "Choose the Serial Port" error with MySensors and RFXtrx433?:
                          Arduino nanos
                          It's a bit hard to read but the black chips on the back says:
                          A106
                          and
                          WCH
                          CH340G
                          202686635
                          and
                          AMS1117
                          5.0 DN628
                          on the front (where the button is)
                          ALMEL
                          MEGA328P
                          AU 1639
                          I can't find any mention of "FTDI". Should I assume it is not a genuine Arduino nano?
                          I DO have an unused Arduino Uno laying around. Maybe it would be easier to buy a ethernet shield and use a ethernet gateway instead of the serial gateway? Is it a W5100 ethernet shield I would need for the Uno?
                          MagnusM 2 Replies Last reply
                            Arduino nanos
                            A106
                            and
                            WCH
                            CH340G
                            202686635
                            and
                            AMS1117
                            5.0 DN628
                            ALMEL
                            MEGA328P
                            AU 1639
                            MagnusM
                            MagnusM
                            Magnus
                            @Aron-Sjöberg I would guess the problems are due to the CH340G chip (instead of an FTDI chip). I use this nano for my gateway:
                            https://www.aliexpress.com/item/Nano-V3-0-Mini-USB-ATmega328-5V-16M-100-ORIGINAL-FTDI-FT232RL/32338360936.html?spm=2114.13010608.0.0.ZU4WHD
                              Arduino nanos
                              A106
                              and
                              WCH
                              CH340G
                              202686635
                              and
                              AMS1117
                              5.0 DN628
                              ALMEL
                              MEGA328P
                              AU 1639
                              MagnusM
                              MagnusM
                              Magnus
                              @Aron-Sjöberg Used sketch below, I didn't make any changes to the original sketch:
                               * LEDs (OPTIONAL):
                              #define NO_PORTB_PINCHANGES
                              #include <MySigningNone.h>
                              #include <MyTransportRFM69.h>
                              #include <MyTransportNRF24.h>
                              #include <MyHwATMega328.h>
                              #include <MyParserSerial.h>
                              #include <stdarg.h>
                              #include <PinChangeInt.h>
                              #include "GatewayUtil.h"
                              //MyTransportRFM69 transport;
                              //MySigningNone signer;
                              //MySigningAtsha204 signer;
                              // Hardware profile
                              MyHwATMega328 hw;
                              #ifdef WITH_LEDS_BLINKING
                              MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                              char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                              int inputPos = 0;
                              boolean commandComplete = false;  // whether the string is complete
                              void parseAndSend(char *commandBuffer);
                              void output(const char *fmt, ... ) {
                                 va_list args;
                                 va_start (args, fmt );
                                 va_end (args);
                                 Serial.print(serialBuffer);
                                // Add interrupt for inclusion button to pin
                                PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
                                // Send startup log message on serial
                                serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
                                checkInclusionFinished();
                                if (commandComplete) {
                                  // A command wass issued from serial interface
                                  // We will now try to send it to the actuator
                                  parseAndSend(gw, inputString);
                                  inputPos = 0;
                                SerialEvent occurs whenever a new data comes in the
                               hardware serial RX.  This routine is run between each
                               time loop() runs, so using delay inside loop can delay
                               response.  Multiple bytes of data may be available.
                              void serialEvent() {
                                while (Serial.available()) {
                                  // get the new byte:
                                  char inChar = (char)Serial.read();
                                  // if the incoming character is a newline, set a flag
                                  // so the main loop can do something about it:
                                  if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
                                    if (inChar == '\n') {
                                      inputString[inputPos] = 0;
                                      commandComplete = true;
                                      // add it to the inputString:
                                      inputString[inputPos] = inChar;
                                      inputPos++;
                                      inputPos = 0;
                              • Aron SjöbergA
                                Aron SjöbergA
                                Aron Sjöberg
                                Thanks @Magnus!
                                I'll order the one you linked to and see if that works better. I assume I can always use my current ones as base for sensors instead of a gateway. I'll order a ethernet shield as well, so I can try and build a ethernet gateway if my Vera Edge still doesn't recognize the new Nano.
                                However, your sketch is not the same as the one in the getting started guide? The sketch I've used is this, from https://www.mysensors.org/build/serial_gateway :
                                * LEDs (OPTIONAL):
                                * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                                // Enable serial gateway
                                #define MY_GATEWAY_SERIAL
                                // Enable inclusion mode
                                // Set blinking period
                                // Flash leds on rx/tx/err
                                This sketch seems to be the same as the one in the Ardinuo IDE named "GatewaySerial":
                                * LEDs (OPTIONAL):
