  3. More then one MAX6675 in one node? ...smoking meat and fish...
12 Posts 3 Posters 4.2k Views 3 Watching
  • jonehrJ
    jonehrJ
    jonehr
    I'm using this example to have control over the temperature in the meat in my smoker, and it is working fine.
    The question:
    Can I have 6 temp sensors/MAX6675 connected to one node?
    How do I change the exemple?
    // this example is public domain. enjoy!
    // www.ladyada.net/learn/sensors/thermocouple
    #include "max6675.h"
    #define MY_NODE_ID 10
    #define CHILD_ID_TEMP 10
    #define TEMP_SENSOR_DIGITAL_PIN 4
    int thermoDO = 4;
    int thermoCS = 5;
    int thermoCLK = 6;
    MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
    int vccPin = 3;
    int gndPin = 2;
    MyMessage msg(CHILD_ID_TEMP, V_TEMP);
    void presentation()  {
      sendSketchInfo("Temp Sensor", "0.1");
      Serial.begin(115200);
      // use Arduino pins
      pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
      pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
      Serial.println("MAX6675 test");
      // wait for MAX chip to stabilize
      delay(500);
      // basic readout test, just print the current temp
      int tempCelsius = thermocouple.readCelsius();
       Serial.print("C = ");
       Serial.println(thermocouple.readCelsius());
       Serial.print("F = ");
       Serial.println(thermocouple.readFahrenheit());
       send(msg.set(tempCelsius));
       delay(5000);
    • vorowskiV
      vorowskiV
      vorowski
      Where do you buy the sensors?
      • jonehrJ
        jonehrJ
        jonehr
        ebay.com
        ex.
        http://www.ebay.com/itm/1-K-Type-Thermocouple-Sensor-Probe-Diameter-1-6mm-Probe-Length-50-300mm-1500mm-/271178661987?var=&hash=item3f23820063:m:mlAXKtAdCmssGX3Sudq31Ww
        and
        http://www.ebay.com/itm/381359075336?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
        • jonehrJ jonehr
          The question:
          int thermoDO = 4;
          int thermoCS = 5;
          int thermoCLK = 6;
          int vccPin = 3;
          int gndPin = 2;
            // use Arduino pins
            delay(500);
             delay(5000);
          @jonehr yes you can. You need different CS pins for each sensor, but the rest of the pins can be shared.
          • jonehrJ
            jonehrJ
            jonehr
            Thank you. I'll make a try.
            • jonehrJ jonehr
              @jonehr great. Please report back on the progress.
              If you want to dive deeper i to how SPI works, sparkfun has a nice tutorial.
              jonehrJ 1 Reply Last reply
                jonehrJ
                jonehrJ
                jonehr
                @mfalkvidd
                Thank you.
                I'll do so.
                • jonehrJ
                  jonehrJ
                  jonehr
                  wrote on last edited by jonehr
                  Now I've studied and done some copy pasting...I'm not a programmer as you can see.
                  This code seems to work.. a bit...
                  My problem now is that I don't know how to write the code to tell the controller/Domoticz that there are three sensors to the node. I only get one child in "the hardware list" in Domoticz.
                  #define MY_NODE_ID AUTO
                  #define CHILD_ID_TEMP AUTO
                  //#define NUMBER_OF_SENSORS 3 // Change this depending on how many sensors you connect.
                  int thermoDO = 4;
                  int thermoCS = 5;
                  int thermoCS2 = 7;
                  int thermoCS3 = 8;
                  int thermoCLK = 6;
                  MAX6675 thermocouple2(thermoCLK, thermoCS2, thermoDO);
                  MAX6675 thermocouple3(thermoCLK, thermoCS3, thermoDO);
                  int vccPin = 3;
                  int gndPin = 2;
                    // use Arduino pins
                    delay(500);
                    int tempCelsius2 = thermocouple2.readCelsius();
                    int tempCelsius3 = thermocouple3.readCelsius();
                     Serial.print("prob1---C = ");
                     Serial.print("prob2---C = ");
                     Serial.println(thermocouple2.readCelsius());
                     Serial.print("prob3---C = ");
                     Serial.println(thermocouple3.readCelsius());
                      send(msg.set(tempCelsius2));
                      send(msg.set(tempCelsius3));
                     delay(5000);
                  My Domotics log:
                  2017-01-03 21:23:57.057 (Mysensor server) Temp (2.1.0)
                  2017-01-03 21:23:57.083 (Mysensor server) Temp (2.1.0)
                  2017-01-03 21:23:57.105 (Mysensor server) Temp (2.1.0) ```
                  My serial log:
                  prob1---C = 0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                  3 TSM:INIT
                  4 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  13 TSF:SID:OK,ID=10
                  14 TSM:FPAR
                  51 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  521 TSF:MSG:READ,0-0-10,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  526 TSF:MSG:FPAR OK,ID=0,D=1
                  1574 TSF:MSG:READ,8-8-10,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                  2058 TSM:FPAR:OK
                  2059 TSM:ID
                  2060 TSM:ID:OK
                  2062 TSM:UPL
                  2067 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  2077 TSF:MSG:READ,0-0-10,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  2082 TSF:MSG:PONG RECV,HP=1
                  2085 TSM:UPL:OK
                  2086 TSM:READY:ID=10,PAR=0,DIS=1
                  2092 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  2101 TSF:MSG:READ,0-0-10,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  2108 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                  2116 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  2130 TSF:MSG:READ,0-0-10,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  2138 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:Temp Sensor
                  2147 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
                  2155 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=6,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                  2161 MCO:REG:REQ
                  2165 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  2171 TSF:MSG:READ,0-0-10,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  2177 MCO:PIM:NODE REG=1
                  2179 MCO:BGN:STP
                  MAX6675 test
                  2680 MCO:BGN:INIT OK,TSP=1
                  prob1---C = 0.00
                  prob2---C = 0.00
                  prob3---C = 23.75
                  2891 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:256
                  2909 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:32
                  2917 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:23
                  prob1---C = 0.00
                  prob2---C = 16.00
                  prob3---C = 23.50
                  8130 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:0
                  8138 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:0
                  8146 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:23
                  • jonehrJ jonehr
                    int thermoDO = 4;
                    int thermoCS = 5;
                    int thermoCS2 = 7;
                    int thermoCS3 = 8;
                    int thermoCLK = 6;
                    int vccPin = 3;
                    int gndPin = 2;
                      // use Arduino pins
                      delay(500);
                       delay(5000);
                    My Domotics log:
                    My serial log:
                    3 TSM:INIT
                    4 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    13 TSF:SID:OK,ID=10
                    14 TSM:FPAR
                    2058 TSM:FPAR:OK
                    2059 TSM:ID
                    2060 TSM:ID:OK
                    2062 TSM:UPL
                    2085 TSM:UPL:OK
                    2161 MCO:REG:REQ
                    2179 MCO:BGN:STP
                    MAX6675 test
                    prob1---C = 0.00
                    prob2---C = 0.00
                    prob3---C = 23.75
                    prob1---C = 0.00
                    prob2---C = 16.00
                    prob3---C = 23.50
                    @jonehr great that you got them workin.
                    All three sensors need to be presented, and the sensor number needs to be set when sending values. See the temperature example, especially this part:
                         present(i, S_TEMP);
                    for presentation and this part for sending values:
                          send(msg.setSensor(i).set(temperature,1));
                    • jonehrJ
                      jonehrJ
                      jonehr
                      Now I've tried all day...I can't get it to work.
                      Trying to follow your advice @mfalkvidd but only made small steps with "presentation". Very thankful for your help but unfortunately I don't get it right.
                      I've specified 5 sensors to the node but Domoticz sees 6 . The only working child is child 255. There I see the temperature.
                      The code looks like this now:
                      #define MAX_ATTACHED_SENSORS 5
                      #define NUMBER_OF_SENSORS 5 // Change this depending on how many sensors you connect.
                      int gndPin = 2;
                      int vccPin = 3;
                      int thermoDO = 4;
                      int thermoCLK = 6;
                      int thermoCS1 = 5;
                      int thermoCS2 = 7;
                      int thermoCS3 = 8;
                      int thermoCS4 = 8;
                      int thermoCS5 = 8;
                      MAX6675 thermocouple1(thermoCLK, thermoCS1, thermoDO);
                      MAX6675 thermocouple4(thermoCLK, thermoCS4, thermoDO);
                      MAX6675 thermocouple5(thermoCLK, thermoCS5, thermoDO);
                        for (int i=0; i<NUMBER_OF_SENSORS && i<MAX_ATTACHED_SENSORS; i++) {
                          present(i, S_TEMP);
                        // use Arduino pins
                        delay(500);
                         //basic readout test, just print the current temp
                        int tempCelsius1 = thermocouple1.readCelsius();
                        int tempCelsius4 = thermocouple4.readCelsius();
                        int tempCelsius5 = thermocouple5.readCelsius();
                         Serial.println(thermocouple1.readCelsius());
                          send(msg.set(tempCelsius1));
                          send(msg.set(tempCelsius4));
                          send(msg.set(tempCelsius5));
                           //for (int i=0; i<NUMBER_OF_SENSORS && i<MAX_ATTACHED_SENSORS; i++) {
                            //  send(msg.setreadCelsius(i));}
                         delay(5000);
                      And the serial log:
                      3 TSM:INIT
                      4 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSF:SID:OK,ID=10
                      14 TSM:FPAR
                      2058 !TSM:FPAR:NO REPLY
                      2060 TSM:FPAR
                      2096 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      3083 TSF:MSG:READ,0-0-10,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      3087 TSF:MSG:FPAR OK,ID=0,D=1
                      3228 TSF:MSG:READ,5-5-10,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                      3686 TSF:MSG:READ,8-8-10,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                      3775 TSF:MSG:READ,1-1-10,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                      4104 TSM:FPAR:OK
                      4105 TSM:ID
                      4106 TSM:ID:OK
                      4108 TSM:UPL
                      4145 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      4152 TSF:MSG:READ,0-0-10,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      4157 TSF:MSG:PONG RECV,HP=1
                      4159 TSM:UPL:OK
                      4161 TSM:READY:ID=10,PAR=0,DIS=1
                      4165 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      4179 TSF:MSG:READ,0-0-10,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      4205 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                      4213 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      4229 TSF:MSG:READ,0-0-10,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      4236 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:Temp Sensor
                      4245 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
                      4282 TSF:MSG:SEND,10-10-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                      4325 !TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=6,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.0
                      4334 TSF:MSG:SEND,10-10-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=1,st=OK:
                      4354 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=6,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                      4362 TSF:MSG:SEND,10-10-0-0,s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                      4370 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=6,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                      4378 TSF:MSG:SEND,10-10-0-0,s=3,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                      4386 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=6,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                      4397 TSF:MSG:SEND,10-10-0-0,s=4,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                      4425 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=6,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                      4432 MCO:REG:REQ
                      4435 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      4445 TSF:MSG:READ,0-0-10,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      4450 MCO:PIM:NODE REG=1
                      4452 MCO:BGN:STP
                      MAX6675 test
                      4954 MCO:BGN:INIT OK,TSP=1
                      prob1---C = 2.00
                      prob2---C = nan
                      prob3---C = 21.50
                      5227 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:0
                      5235 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:56
                      5245 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:21
                      5254 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:21
                      5273 TSF:MSG:SEND,10-10-0-0,s=255,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:21
                      • jonehrJ jonehr
                        int gndPin = 2;
                        int vccPin = 3;
                        int thermoDO = 4;
                        int thermoCLK = 6;
                        int thermoCS1 = 5;
                        int thermoCS2 = 7;
                        int thermoCS3 = 8;
                        int thermoCS4 = 8;
                        int thermoCS5 = 8;
                            present(i, S_TEMP);
                          // use Arduino pins
                          delay(500);
                           delay(5000);
                        And the serial log:
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        13 TSF:SID:OK,ID=10
                        14 TSM:FPAR
                        2060 TSM:FPAR
                        4104 TSM:FPAR:OK
                        4105 TSM:ID
                        4106 TSM:ID:OK
                        4108 TSM:UPL
                        4159 TSM:UPL:OK
                        4432 MCO:REG:REQ
                        4452 MCO:BGN:STP
                        MAX6675 test
                        prob1---C = 2.00
                        prob2---C = nan
                        prob3---C = 21.50
                        Nice work. Some small adjustments:
                        Remove this
                        The 5 temperature probes will get presented in the for loop above and will get numbers 0, 1, 2, 3, and 4.
                        Also change
                        to
                            send(msg.setSensor(0).set(tempCelsius1));
                            send(msg.setSensor(1).set(tempCelsius2));
                            send(msg.setSensor(2).set(tempCelsius3));
                            send(msg.setSensor(3).set(tempCelsius4));
                            send(msg.setSensor(4).set(tempCelsius5));
                        That should be it. The code could be made a bit cleaner by using arrays but if you aren't familiar with that type if coding I suggest you keep it the way it is.
                        • jonehrJ
                          jonehrJ
                          jonehr
                          @mfalkvidd
                          I'm very grateful...thank you! works fine.
                          As you said, the code could be cleaner but I'm fully satisfied.
                          When I get the time I'll do some basic coding studies.
