  3. Vibration measurement sensor for mysensors node
5 Posts 4 Posters 2.5k Views 4 Watching
  • RedguyR
    RedguyR
    Redguy
    I am looking for a way to monitor shocks and vibrations using a mysensors node.
    There are plenty of vibration sensors et, but they just signal that a certain threshhold was reached or not.
    what i want to do is monitor shocks and trembling throughout my apartment building caused by either external causes (passing train, earth shocks) or through the building itself (weather, other tenants, the elevators, thermal expansion of the concrete)
    but i am not sure what type of sensor i should use.. any thoughts ?
    mfalkviddM Nca78N 2 Replies Last reply
    • RedguyR Redguy
      @Redguy mayve @Cliff-Karlsson has some news on his eperiment: https://forum.mysensors.org/topic/5398/using-gyros-with-mysensors
      Not sure if AWI's orientation sensor is sensitive enough, but I think it is possible to turn upp the gain. https://www.mysensors.org/build/orientation_actuator
      • RedguyR Redguy
        Nca78N
        Nca78N
        Hello, you have to look for accelerometers.
        Something very sensible I suppose for your use case.
        • wallyllamaW
          wallyllamaW
          wallyllama
          Siesmometer?
          http://www.instructables.com/id/This-Seismometer-is-no-toy/step2/Seismometer-seismograph-System-Components/
          https://www.sparkfun.com/news/2074
          https://www.sparkfun.com/tutorials/235
          RedguyR 1 Reply Last reply
          • wallyllamaW wallyllama
            Siesmometer?
            RedguyR
            RedguyR
            Redguy
            Thanx guys !
            I ordered a ADXL345 digital three-axis acceleration of gravity tilt module on ali to see what this will do with such small measurements.
            stumbled upon this via one of Wallyllama's links :
            https://tc1seismometer.wordpress.com/2012/06/18/tc1-vertical-seismometer-plans/
            Seems easy enough to have some fun with as well.
