  3. A good locking switch/button for "oldschool" mysensor-device control
23 Posts 5 Posters 9.3k Views 7 Watching
  • L
    L
    LastSamurai
    I have searched for something like this but haven't come up with a nice solution yet, perhaps you guys can help.
    I currently have several led strips with my controller nodes illuminating some rooms. While most of the time I simply control them with my smartphone/pc/motion sensor there are some instances where a simpler solution is needed (near the frontdoor to shutdown everything quickly when leaving, beside the bed to kill the lights in the evening,...).
    We already have several boards that are very small and flat with CR2032 batteries but I havent found any casing for them so that they don't look so out of place. A normal lightswitch cover would be perfect as it should be (nearly) big enough to house the pcb while looking normal on the wall. I don't want to drill into the wall for these as the might change positions more often.
    Do you have any idea how to build something like that? Or are there any cheaper device that already do something like that (only found really expensive hardware like the flic button)?
    • L LastSamurai
      @LastSamurai which part of the world are you in? If you're in North America, this project might be useful https://forum.mysensors.org/topic/4243/custom-node-for-usa-wall-switch-module
      L 1 Reply Last reply
        L
        L
        LastSamurai
        @mfalkvidd I am living in germany so the size of this project doesn't really fit. Still a great idea though, thanks! I was thinking about bying some of these touch sensors and getting a small plate of plexiglas as a cover + some kind of very small box for the pcb => (livolo) glas like looking switch which should not cost that much :) Perhaps I'll build that...
        • vorowskiV
          vorowskiV
          vorowski
          http://shop.ezcontrol.de/fernbedienungen/elv-fs20-s6a-6-tasten-aufputz-wandsender/a-10164/
          Would ne neat....not Sure if You Can buy enclosure only though....
          Anybody knows?
          W
            Conrad has a few light switch covers, for example https://www.conrad.de/de/gao-einsatz-wechselschalter-nova-aufputz-weiss-0325-625031.html
            Not sure what they look on the inside though.
            • Nca78N
              Nca78N
              wrote on last edited by Nca78
              Our friends at Aliexpress have some nice 433MHz remote controls in the shape of glass switches for less than 10$:
              https://www.aliexpress.com/item/Vhome-Smart-Home-EU-433MHZ-black-Glass-panel-Switch-shape-remote-control-Wall-Light-Touch-Switch/32727839576.html
              Else here, much more expensive but nice colors and option up to 3 buttons :
              https://fywfactorystore.aliexpress.com/store/group/Single-Remote-Control/2182093_508229474.html
              I see 3 buttons version is still under 10$ in the shop of the first link, so pay twice the price only if you crave for blue/pink switches :D
              • Nca78N Nca78
                L
                L
                LastSamurai
                @Nca78 Wow, that looks great! I guess I will order some :)
                Have you already used them? Do you know if there is any documentation for the signal codes they are sending? I would use them with a mysensor node connected to a 433MHz sender/receiver and one of the arduino libs for that.
                Nca78N 1 Reply Last reply
                • L LastSamurai
                  Nca78N
                  Nca78N
                  @LastSamurai no not yet, I'm hesitating right now to order them. If I do I will just replace the PCB I guess.
                  Edit: ok, just bought one. See you in march when it will arrive :P
                  • Nca78N Nca78
                    L
                    L
                    LastSamurai
                    @Nca78 I guess I won't be able to stop myself from ordering one too ;) Please keep me updated about your progress!
                    • Nca78N
                      Nca78N
                      it's a already here, which is impressive if we take the lunar new year holidays into account.
                      I have quite a good feeling about it :
                      • looks ok with glass front
                      • in two parts, back that you fix on the wall (using screws or tape) and the front panel which pops in
                      • there's a blue led for each button to confirm action when you press it. It's very dim but it's visible in dark room and it's a nice touch at this price
                      • it's using ev1527 encoding chip so it's all "standard" 433MHz switch. Recognized at "PT2262" type by rfxtrx433 / domoticz. If you have rfxtrx just activate "Lighting 4" type and you can receive the commands. If not I think it'll be recognized easily by the 433MHz switches libraries.
                      I wanted to make a PCB to replace the board, but I'll try to use it as it is at the moment. Not sure if it can be managed correctly in Domoticz though, as it's only sending "on" signal (with a different "ID" for each button, "Unit" is always 0).
                      • Nca78N
                        Nca78N
                          There is also the xiaomi button but it uses zigbee or its own smart gateway, but it's a quite cheap solution
                          • L
                            L
                            LastSamurai
                            @Nca78 Thanks for the pictures! Looks nice. I ordered mine about ~2 weeks ago, hopefully it'll be here soon too. I don't have a rfxtrx (yet) but will try to build my own node with an arduino and a cheap 433 receiver/sender.
                            • L LastSamurai
                              Nca78N
                              Nca78N
                              @LastSamurai said in A good locking switch/button for "oldschool" mysensor-device control:
                              Yes it will be fine with that. I plan to do that too as I regularly have inverted usb port between rfxtrx and mysensors gateway when pi restarts. I'll probably make a PCB later but it's not a priority at the moment.
                              • L
                                L
                                LastSamurai
                                @Nca78 did you already work with the switch? Mine should arrive soon too :)
                                • L LastSamurai
                                  Nca78N
                                  Nca78N
                                  No, not yet I've been busy with many things and my MySensors project have been slowed down. On holidays right now so one more week of delay :p
                                  • L
                                    L
                                    LastSamurai
                                    I just received mine and did some testing. As I don't have an rfxtrx433 (thats more than 100€ :() I used a cheap 433Mhz receiver and the RC-switch library. It receives a unique code for every button. You have to press the button pretty long though (not just touch it once). Was it the same with yours?
                                    Also do you have any idea if these buttons all have unique codes? If this work I want to get more that one ;)
                                    Here is the output of one of the buttons of my switch, in case someone needs this:
                                    • Decimal: 12587345 (24Bit) Binary: 110000000001000101010001 Tri-State: 10000F0FFF0FÖ PulseLength: 409 microseconds Protocol: 1
                                      Raw data: 12680,1304,360,1300,340,388,1288,388,1200,452,1220,400,1212,472,1156,452,1216,512,1120,456,1212,444,1160,1276,412,412,1200,464,1224,348,1268,1284,324,504,1152,1296,332,508,1128,1284,384,444,1180,468,1204,396,1196,1304,380,
                                    • Nca78N
                                      Nca78N
                                      Hello, I have ordered 2 more so I will confirm you when I receive them. But based on the circuit used it should be different for each switch.
                                      I don't need to press a long time on the buttons, just similar to livolo. I just touch the button and the LED around the butto lights on immediately to confirm sending. Maybe you have problem with your receiving code ?
                                      • L
                                        L
                                        LastSamurai
                                        Ah nice, I was thinking about doing the same. Only possible downside might be the battery runtime. Otherwise they look great and seem to work just fine in my apartment (nearly everywhere).
                                        I don't own any other switches to compare this but its not just a touch. I think it might be a pairing request although I sadly have no clue how to respond. Do you have any idea?
                                        • Nca78N
                                          Nca78N
                                          I think it's just a touch, there's no receiver on it and from the cheap used it's just made to send a code through the 433MHz when you press it. Each button has it's own code and sends a "on" command associated with that code.
                                          I tried long press (>5s then >10s) and it's not sending a different signal, always "on" command.
                                          This is what I have in Domoticz, each button is seen as a different device using a different ID.
