  3. [SOLVED] After upgrade to mysensors 2.1 problems with radio module might manifest itself more.
23 Posts 4 Posters 8.7k Views 4 Watching
  • AnticimexA Anticimex
    @Nicklas-Starkel
    I owe you an apology. It appears there for some configuration combinations does exist a bug for signing in 2.1. @tekka found a problem where the signing presentation in some situations would not be sent to the correct node.
    That said, you do appear to also have issues with the radio (the NACKs) but you are correct in that there is an issue with signing. It will be resolved in 2.1.1.
    Thank you for reporting, and again, please accept my sincere apology for failing to look more thoroughly through your logs.
    N
    N
    Nicklas Starkel
    @Anticimex , eh, no apologies needed. I'm thankful mysensors is opensource and actually FREE!
    Cool that you found a bug and if I helped, I'm glad :)
    • N
      N
      Nicklas Starkel
      @Anticimex and @tekka .
      I just upgraded my GW (MEGA) and most sensors.
      I do not know what you did, but my range is incredible now (and everything works!)
      I had good coverage in my apartment before, but if I went outside my front door it started failing (steel security door).
      Now, I can not only go outside the door, I can actually go 3 stairs down in my building with AWIs NRF tester.
      Same hardware is used and nothing has changed from my part.
      Kudos and thank you.
      AnticimexA 1 Reply Last reply
      • N Nicklas Starkel
        AnticimexA
        AnticimexA
        Anticimex
        @Nicklas-Starkel nice to hear! We are constantly trying to improve the performance in various aspects. I think it is @tekka that deserves the credit for increased rf performance as he has done a tremendous work with the drivers.
