  3. [SOLVED] After upgrade to mysensors 2.1 problems with radio module might manifest itself more.
23 Posts 4 Posters 8.7k Views 4 Watching
  • N Nicklas Starkel
    Well so I deleted whole Arduino to make sure I got everything fresh.
    Installed arduino and mysensors 2.0 via library manager and also mysensors HW arduino manager in preferences.
    Updated my gateway and all nodes work with signing ON.
    The nodes are a mixture now with mysensors 2.0 as well as 2.1.
    I updated library to 2.1 in my GW and instantly I have failed messages with Signing ON.
    To make sure, I powered the GW from one source and NRF separately from external source (5v computer usb)
    No changes. I tried different NRF as well as NRF PA with big antenna.
    I even tried different antennas (used to other applications). With mysensors 2.0 they work, with 2.1 fails.
    I took a node and powered it similar with external power source (3x1.5v AAA) for the NRF but it would still give me fails.
    When I go back to mysensors 2.0 everything works great again.
    I guess I'll stick with 2.0 and wait and see if other people upgrade their stuff and use signing might see the same problem with their hardware.
    AnticimexA
    AnticimexA
    Anticimex
    @Nicklas-Starkel ok. Well like I already said, your problem (at least according to your logs) have nothing to do with signing, but with rf issues. If you were to send messages that were larger you most likely would have the same problem, signing on or off, so I can just stress that referencing signing just shadows the real issue. Signing is only a way of extending the message size to provoke the issue. Signing has been verified to work with 2.1 as @tekka stated, so I (as the security guy) consider the issue settled from a signing perspective.
    N 1 Reply Last reply
    • AnticimexA Anticimex
      N
      N
      Nicklas Starkel
      @Anticimex maybe I was not clear enough or used the wrong words?
      I still understand that the problem is not with signing.
      I pointed out that using signing provokes the error.
      The error is still an underlying issue weather it be my hardware or it be NRF module code in mysensors 2.1.
      tekkaT 1 Reply Last reply
      • N Nicklas Starkel
        tekkaT
        tekkaT
        tekka
        @Nicklas-Starkel Did you also try with different GW hardware, i.e. ESP8266 or a regular Uno?
        • tekkaT tekka
          N
          N
          Nicklas Starkel
          @tekka that was my next goal ;)
          I just built an UNO with an ethernet shield and low and behold its working with 47uF capacitor.
          Conclusion:
          MEGA does not work with NRF plate adapter nor 47uF capacitor.
          UNO works with 47uF capacitor only (not with plate).
          All nodes are reporting in (mixed 2.0 and 2.1).
          I use @AWI quality meter with NRF plate board to test as well and it is OK.
          So same NRF hardware yields different results on UNO and MEGA for me.
          AnticimexA 1 Reply Last reply
          • N Nicklas Starkel
            Conclusion:
            AnticimexA
            AnticimexA
            Anticimex
            @Nicklas-Starkel
            Any difference in how you power the radio?
              @Nicklas-Starkel
              N
              N
              Nicklas Starkel
              @Anticimex
              I power either with 3xAAA (4.5V) if I'm using the plate.
              If I'm using only capacitor I power with 2xAA (3.3V).
              Tried both versions with same results. Only difference is Arduino/MEGA.
              All batteries fresh and also checked with voltmeter ;)
              • N Nicklas Starkel
                @Anticimex
                AnticimexA
                AnticimexA
                Anticimex
                @Nicklas-Starkel
                I mean do you power the radio by dedicated regulator or directly from mcu?
                  @Nicklas-Starkel
                  N
                  N
                  Nicklas Starkel
                  @Anticimex I not sure I follow you and perhaps I am doing it wrong :)
                  I power my arduinos via their usb jacket, 5V/2.1A
                  If I'm using the NRF plate it has its own dedicated regulator hence its getting 3xAAA 4.5V.
                  Otherwise I am using 2xAA which is around 3.3V connected to VCC/GND of the radio module and GND is also connected to the arduino.
                  • N Nicklas Starkel
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @Nicklas-Starkel
                    I owe you an apology. It appears there for some configuration combinations does exist a bug for signing in 2.1. @tekka found a problem where the signing presentation in some situations would not be sent to the correct node.
                    That said, you do appear to also have issues with the radio (the NACKs) but you are correct in that there is an issue with signing. It will be resolved in 2.1.1.
                    Thank you for reporting, and again, please accept my sincere apology for failing to look more thoroughly through your logs.
                      @Nicklas-Starkel
                      N
                      N
                      Nicklas Starkel
                      @Anticimex , eh, no apologies needed. I'm thankful mysensors is opensource and actually FREE!
                      Cool that you found a bug and if I helped, I'm glad :)
                      • N
                        N
                        Nicklas Starkel
                        @Anticimex and @tekka .
                        I just upgraded my GW (MEGA) and most sensors.
                        I do not know what you did, but my range is incredible now (and everything works!)
                        I had good coverage in my apartment before, but if I went outside my front door it started failing (steel security door).
                        Now, I can not only go outside the door, I can actually go 3 stairs down in my building with AWIs NRF tester.
                        Same hardware is used and nothing has changed from my part.
                        Kudos and thank you.
                        • N Nicklas Starkel
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @Nicklas-Starkel nice to hear! We are constantly trying to improve the performance in various aspects. I think it is @tekka that deserves the credit for increased rf performance as he has done a tremendous work with the drivers.
