  3. !TSM:RADIO:FAIL - Newby with Mini NRF24L01 + Mini Pro
18 Posts 4 Posters 4.9k Views 4 Watching
  • wuschelW
    wuschelW
    wuschel
    Hello
    The components used first:
    • Adapter - https://oshpark.com/shared_projects/CtW4Xaow
    • Mini NRF24L01+ SMD 1.27MM,
    • 3,3V Arduino Pro mini
    My Problem:
    The serial Gateway works fine.
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:SANCHK:OK
    The sensor gives me only a error, no matter what I use. CO2 Sketch or Soil Moisture everything gives me this error:
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    I have built 3 Sensors everything the same.
    I can take pictures from the sensors if it helps!
    can someone help me ?
    Thx wuschel
    • wuschelW wuschel
      Hello
      My Problem:
      0;255;0;0;18;2.0.0
      TSM:INIT
      !TSM:RADIO:FAIL
      !TSM:FAILURE
      TSM:PDT
      Thx wuschel
      @wuschel - !TSM:RADIO:FAIL means the radio isnt working.
      Either its not powered correctly, not wired correctly or broken.
      • wuschelW
        wuschelW
        wuschel
        I think the wireing is not right.
        But is habe the Problem i dont understand the Intsruction for sensors.
        The Gateway was not the problem .... the instruction was perfekt....
        i have no idea how check the error, is it the powerd is it the wired, is the radio damaged ?
        gohanG 1 Reply Last reply
        • wuschelW wuschel
          @wuschel
          Try swapping radio from gateway to sensor and see if problem follows the radio or not.
          • wuschelW
            wuschelW
            wuschel
            @gohan thx but in the gateway i used nrf with NRF24L01 PA LNA the sensors Mini NRF24L01+ SMD 1.27MM i have x25 NRF SMD the switch/swipe is not a option the SMD have to be work ... i hope u know what u mean
              Ok i got that, I meant to swap the radios just to check is the problem was the radio or not, because if the gateway is working it mean the wiring in that one is correct so you know the radio module has to work and if not then it is the module that has problem. After the test you put the NRF24L01 PA LNA back to the gateway
              • wuschelW
                wuschelW
                wuschel
                ok i have 2 from the PA i will try this.
                i will post the result today or tomorrow.
                THX
                • wuschelW
                  wuschelW
                  wuschel
                  i have orderd new nrf without the adapter and that looks great
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=3)
                  TSM:FPAR
                  TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  have everyone tested the OSH adapter ? and what must be changed to use ist in the code.
                  the pins are diffrent
                    There are too mail failures, there is probably something wrong in the code
                    wuschelW 1 Reply Last reply
                      wuschelW
                      wuschelW
                      wuschel
                      @gohan the code is from the mysensros libery, the error is always after 4 cycles.
                      is that a problem ?
                        This is how it should look like when it can establish a connection to gateway
                        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        12 TSM:INIT:TSP OK
                        13 TSM:INIT:STATID=2
                        15 TSF:SID:OK,ID=2
                        17 TSM:FPAR
                        58 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        88 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        92 TSF:MSG:FPAR OK,ID=0,D=1
                        2066 TSM:FPAR:OK
                        2067 TSM:ID
                        2068 TSM:ID:OK
                        2070 TSM:UPL
                        2074 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                        2086 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        2091 TSF:MSG:PONG RECV,HP=1
                        2094 TSM:UPL:OK
                        2096 TSM:READY:ID=2,PAR=0,DIS=1
                        2101 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        2117 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        2125 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                        2137 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        3154 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        3164 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=25,sg=0,ft=0,st=OK:PIR_TemperatureAndHumidit
                        3174 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                        3183 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                        3192 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        3201 TSF:MSG:SEND,2-2-0-0,s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                        3207 MCO:REG:REQ
                        3211 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                        3220 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        3225 MCO:PIM:NODE REG=1
                        3227 MCO:BGN:STP
                        When you have 4 repeats it mean there is a problem and it can not find the gateway
                        • wuschelW
                          wuschelW
                          wuschel
                          Ok, i understand.
                          but how can i fix that?
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          0;255;0;0;18;2.0.0
                          0;255;3;0;9;TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSP:MSG:BC
                          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=3)
                          0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                          0;255;3;0;9;TSP:MSG:GWL OK
                          0;255;3;0;9;!TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                          0;255;3;0;9;TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                          0;255;3;0;9;TSP:MSG:READ 3-3-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          0;255;3;0;9;TSP:MSG:PINGED (ID=3, hops=1)
                          0;255;3;0;9;!TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
                            When I had that problem I replaced the radio modules with different ones and it started to work. Did you put capacitor on the radio module?
                            • wuschelW
                              wuschelW
                              wuschel
                              I have capacitor on the gateway on sensor not.
                              i will try tomorrow, have a long way ahead of me
                                Capacitor is pretty much mandatory. Start from 4.7 uF and increase up to 100 and see if you see any changes
                                • jogantJ
                                  jogantJ
                                  jogant
                                  Another thing is that sensor and gateway need a minimum distance. I had gateway and sensor on my desktop for testing and had problems. So I put away the gateway 2 meters and problems are gone. Just a try.
                                    wuschelW
                                    wuschelW
                                    wuschel
                                    @gohan on sensor too ? or only gateway ?
                                      Capacitor needs to go as close as possible to the vcc/gnd pins of the radio module as possible on both of them.
