  3. !TSM:RADIO:FAIL - Newby with Mini NRF24L01 + Mini Pro
18 Posts 4 Posters 4.9k Views 4 Watching
  • wuschelW
    wuschelW
    wuschel
    @gohan thx but in the gateway i used nrf with NRF24L01 PA LNA the sensors Mini NRF24L01+ SMD 1.27MM i have x25 NRF SMD the switch/swipe is not a option the SMD have to be work ... i hope u know what u mean
      Ok i got that, I meant to swap the radios just to check is the problem was the radio or not, because if the gateway is working it mean the wiring in that one is correct so you know the radio module has to work and if not then it is the module that has problem. After the test you put the NRF24L01 PA LNA back to the gateway
      • wuschelW
        wuschelW
        wuschel
        ok i have 2 from the PA i will try this.
        i will post the result today or tomorrow.
        THX
        • wuschelW
          wuschelW
          wuschel
          i have orderd new nrf without the adapter and that looks great
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=3)
          TSM:FPAR
          TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          have everyone tested the OSH adapter ? and what must be changed to use ist in the code.
          the pins are diffrent
            There are too mail failures, there is probably something wrong in the code
            wuschelW 1 Reply Last reply
              wuschelW
              wuschelW
              wuschel
              @gohan the code is from the mysensros libery, the error is always after 4 cycles.
              is that a problem ?
                This is how it should look like when it can establish a connection to gateway
                0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                3 TSM:INIT
                4 TSF:WUR:MS=0
                12 TSM:INIT:TSP OK
                13 TSM:INIT:STATID=2
                15 TSF:SID:OK,ID=2
                17 TSM:FPAR
                58 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                88 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                92 TSF:MSG:FPAR OK,ID=0,D=1
                2066 TSM:FPAR:OK
                2067 TSM:ID
                2068 TSM:ID:OK
                2070 TSM:UPL
                2074 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                2086 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                2091 TSF:MSG:PONG RECV,HP=1
                2094 TSM:UPL:OK
                2096 TSM:READY:ID=2,PAR=0,DIS=1
                2101 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                2117 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                2125 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                2137 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                3154 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                3164 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=25,sg=0,ft=0,st=OK:PIR_TemperatureAndHumidit
                3174 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                3183 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                3192 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                3201 TSF:MSG:SEND,2-2-0-0,s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                3207 MCO:REG:REQ
                3211 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                3220 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                3225 MCO:PIM:NODE REG=1
                3227 MCO:BGN:STP
                When you have 4 repeats it mean there is a problem and it can not find the gateway
                • wuschelW
                  wuschelW
                  wuschel
                  Ok, i understand.
                  but how can i fix that?
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSM:RADIO:OK
                  0;255;3;0;9;TSM:GW MODE
                  0;255;3;0;9;TSM:READY
                  0;255;0;0;18;2.0.0
                  0;255;3;0;9;TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSP:MSG:BC
                  0;255;3;0;9;TSP:MSG:FPAR REQ (sender=3)
                  0;255;3;0;9;TSP:MSG:GWL OK
                  0;255;3;0;9;!TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                  0;255;3;0;9;TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                  0;255;3;0;9;TSP:MSG:READ 3-3-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  0;255;3;0;9;TSP:MSG:PINGED (ID=3, hops=1)
                  0;255;3;0;9;!TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
                  0;255;3;0;9;TSP:SANCHK:OK
                    When I had that problem I replaced the radio modules with different ones and it started to work. Did you put capacitor on the radio module?
                    • wuschelW
                      wuschelW
                      wuschel
                      I have capacitor on the gateway on sensor not.
                      i will try tomorrow, have a long way ahead of me
                        Capacitor is pretty much mandatory. Start from 4.7 uF and increase up to 100 and see if you see any changes
                        • jogantJ
                          jogantJ
                          jogant
                          Another thing is that sensor and gateway need a minimum distance. I had gateway and sensor on my desktop for testing and had problems. So I put away the gateway 2 meters and problems are gone. Just a try.
                            wuschelW
                            wuschelW
                            wuschel
                            @gohan on sensor too ? or only gateway ?
                              Capacitor needs to go as close as possible to the vcc/gnd pins of the radio module as possible on both of them.
