  3. !TSM:RADIO:FAIL - Newby with Mini NRF24L01 + Mini Pro
18 Posts 4 Posters 4.9k Views 4 Watching
  • wuschelW wuschel
    I think the wireing is not right.
    But is habe the Problem i dont understand the Intsruction for sensors.
    The Gateway was not the problem .... the instruction was perfekt....
    i have no idea how check the error, is it the powerd is it the wired, is the radio damaged ?
    @wuschel
    Try swapping radio from gateway to sensor and see if problem follows the radio or not.
    • wuschelW
      wuschelW
      wuschel
      @gohan thx but in the gateway i used nrf with NRF24L01 PA LNA the sensors Mini NRF24L01+ SMD 1.27MM i have x25 NRF SMD the switch/swipe is not a option the SMD have to be work ... i hope u know what u mean
        Ok i got that, I meant to swap the radios just to check is the problem was the radio or not, because if the gateway is working it mean the wiring in that one is correct so you know the radio module has to work and if not then it is the module that has problem. After the test you put the NRF24L01 PA LNA back to the gateway
        • wuschelW
          wuschelW
          wuschel
          ok i have 2 from the PA i will try this.
          i will post the result today or tomorrow.
          THX
          • wuschelW
            wuschelW
            wuschel
            i have orderd new nrf without the adapter and that looks great
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=3)
            TSM:FPAR
            TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            have everyone tested the OSH adapter ? and what must be changed to use ist in the code.
            the pins are diffrent
              There are too mail failures, there is probably something wrong in the code
              wuschelW 1 Reply Last reply
                wuschelW
                wuschelW
                wuschel
                @gohan the code is from the mysensros libery, the error is always after 4 cycles.
                is that a problem ?
                  This is how it should look like when it can establish a connection to gateway
                  0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                  3 TSM:INIT
                  4 TSF:WUR:MS=0
                  12 TSM:INIT:TSP OK
                  13 TSM:INIT:STATID=2
                  15 TSF:SID:OK,ID=2
                  17 TSM:FPAR
                  58 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  88 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  92 TSF:MSG:FPAR OK,ID=0,D=1
                  2066 TSM:FPAR:OK
                  2067 TSM:ID
                  2068 TSM:ID:OK
                  2070 TSM:UPL
                  2074 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  2086 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  2091 TSF:MSG:PONG RECV,HP=1
                  2094 TSM:UPL:OK
                  2096 TSM:READY:ID=2,PAR=0,DIS=1
                  2101 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  2117 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  2125 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                  2137 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  3154 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  3164 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=25,sg=0,ft=0,st=OK:PIR_TemperatureAndHumidit
                  3174 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                  3183 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                  3192 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  3201 TSF:MSG:SEND,2-2-0-0,s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                  3207 MCO:REG:REQ
                  3211 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  3220 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  3225 MCO:PIM:NODE REG=1
                  3227 MCO:BGN:STP
                  When you have 4 repeats it mean there is a problem and it can not find the gateway
                  • wuschelW
                    wuschelW
                    wuschel
                    Ok, i understand.
                    but how can i fix that?
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    0;255;3;0;9;TSM:INIT
                    0;255;3;0;9;TSM:RADIO:OK
                    0;255;3;0;9;TSM:GW MODE
                    0;255;3;0;9;TSM:READY
                    0;255;0;0;18;2.0.0
                    0;255;3;0;9;TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    0;255;3;0;9;TSP:MSG:BC
                    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=3)
                    0;255;3;0;9;TSP:MSG:GWL OK
                    0;255;3;0;9;!TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                    0;255;3;0;9;TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                    0;255;3;0;9;TSP:MSG:READ 3-3-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                    0;255;3;0;9;TSP:MSG:PINGED (ID=3, hops=1)
                    0;255;3;0;9;!TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
                    0;255;3;0;9;TSP:SANCHK:OK
                      When I had that problem I replaced the radio modules with different ones and it started to work. Did you put capacitor on the radio module?
                      • wuschelW
                        wuschelW
                        wuschel
                        I have capacitor on the gateway on sensor not.
                        i will try tomorrow, have a long way ahead of me
                          Capacitor is pretty much mandatory. Start from 4.7 uF and increase up to 100 and see if you see any changes
                          • jogantJ
                            jogantJ
                            jogant
                            Another thing is that sensor and gateway need a minimum distance. I had gateway and sensor on my desktop for testing and had problems. So I put away the gateway 2 meters and problems are gone. Just a try.
                              wuschelW
                              wuschelW
                              wuschel
                              @gohan on sensor too ? or only gateway ?
                                Capacitor needs to go as close as possible to the vcc/gnd pins of the radio module as possible on both of them.
