  3. 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
mqttsonoffhome assistanesp8266
93 Posts 25 Posters 41.6k Views 20 Watching
    Can the Vera plug in work with mqtt?
    dbemowskD 1 Reply Last reply
      dbemowskD
      dbemowskD
      @gohan Here is a plugin for MQTT using Vera. You would still need to have an MQTT Broker set up though. I am surprised that there is not an active MQTT plugin for Vera in the plugins section. Didn't find anything when I did a search for MQTT.
        I was just asking since tasmota works great on mqtt
        • tripyT
          tripyT
          tripy
          I will just leave that here for other like me that wondered for hours why they could flash their sonoff, but it did not react once plugged to the main.
          You need to setup your arduino with DOUT as flash mode.
          Other mode will flash without errors, but the device will appear bricked.
          My settings where:
          K 1 Reply Last reply
          • tripyT tripy
            My settings where:
            K
            K
            kalle
            @tripy yes, you are absolute right - you need to set the flash Mode to DOUT for flashing the newer SONOFF generation (the SONOFF's with the hidden green LED).
            • vladimirV
              vladimirV
              vladimir
              Hello!
              Maybe someone here has a code for Sonoff RF with support 433 MHz receiver?
              In my opinion, paired with a wireless wall switch, this will turn out to be quite a cheap and convenient solution for lighting control.
              The cost of a set of relay and switch about 10 dollars.
              • electrikE
                electrikE
                electrik
                Did you try this?
                https://github.com/arendst/Sonoff-Tasmota
                vladimirV 1 Reply Last reply
                • electrikE electrik
                  Did you try this?
                  vladimirV
                  vladimirV
                  vladimir
                  @electrik Now I just read the description of this firmware. To do this, I need to understand how to work with MQTT. I hoped to find a simpler solution. Ethernet gateway is much easier to connect.:man-shrugging:
                  gohanG 1 Reply Last reply
                  • electrikE
                    electrikE
                    electrik
                    Mqtt Is really easy to use in fact. Just follow a tutorial to install mosquitto and you're ready to go.
                    It also depends on your controller of course
                      vladimirV
                      vladimirV
                      vladimir
                      @electrik Thanks you! Now I will order everything I need on TaoBao in China. I just yesterday learned about the existence of the Sonoff module with 433 MHz radio support and wall switches for them.
                      • vladimirV vladimir
                        @vladimir what controller are you using? Most home automation controllers like domoticz and Home Assistant have a quick integration with Tasmota or EspEasy
                          vladimirV
                          vladimirV
                          vladimir
                          @gohan I use OpenHAB 2. As I understand it, it also integrates well with Tasmota.
                            good, give it a try
