  3. Re-establishing connection with gateway
5 Posts 3 Posters 1.8k Views 2 Watching
  • A Offline
    A Offline
    Alexander Ivanov
    I found that after rebooting Ethernet gateway some nodes are not responding (at least first minutes, I didn't check longer).
    Does MySensor nodes automatically tries to re-establish connection with gateways once the connection was lost? If yes, how to tune time to connection re-establishing?
    S 1 Reply Last reply
    • A Alexander Ivanov
      @Alexander-Ivanov - what controller do you use? I have this problem in Domoticz and after a restart i manually have to reboot some nodes (and some takes up to a couple of days before they find back). This is not a mysensors problem thought, because the data is reported in to the controller but added to another node. This happens on multisensors only.
      • F Offline
        F Offline
        flopp
        If Node doesn't get any response from a GW it will start to search for a Parent after 6 failures.
        This is what I read about version 1.5.1.
        So if your node is sending every 30 minutes it can take up to 2.5 hours before it starts to search for new Parent
        • A Offline
          A Offline
          Alexander Ivanov
          @sundberg84, I'm using Vera (Edge). Really surprised on nodes behaviour. If it's really 6 tries, my node which updates temperature twice a min should restart connection in 3 mins after loosing it. But this is not happening.
          • A Offline
            A Offline
            Alexander Ivanov
            I found problem in my code: my node sends update if only it has value changed, which can take really long.
            @flopp, "it will start to search for a Parent after 6 failures" - does 6 tries happen automatically or the node need to send something 6 times?
