  3. Is serial.print blocked by mySensors?
11 Posts 3 Posters 5.1k Views 4 Watching
  • samburner3S
    samburner3S
    samburner3
    wrote on last edited by samburner3
    Hi All,
    I am trying to implement a RDIF sensor (https://www.mysensors.org/build/rfid).
    I have copied and using this sketch example without it being modified.
    My issue is that the Serial.print outputs are not being output to the serial monitor because the #define MY_DEBUG data about the radio takes up the serial monitor, and no Serial.print from the main code ever gets through.
    I have even tested this by placing Serial.print("TestMessage to Serial that is not displaying."); throughout the sketch and only the radio debug info is displayed on the serial monitor.
    These messages should be getting through as in the instructions, "Hold tag in front of reader and your identifier should pop up." indicates that the serial prints should show up along with the radio debug info.
    I have also tried commenting out the //#define MY_DEBUG line, the radio debug info is not displayed, but neither is the program print lines.
    I also tried including the Serial.begin(115200); but with no luck.
    I have tried this with the latest mySensors 2.1.1, 2.1.0 and 2.0.0, all having the same effect.
    I have tried using Arduino IDE 1.6 and 1.8.
    My system is MAC OS 10.11, and my board is an Uno.
    I need this to work so I can debug the actual main sketch as I am making a few modifications. However this sketch does NOT work even without any modifications.
    Makes me wonder if the main sketch is even running??
    Some other user was also having the same problem on this sketch;
    @miro said in 💬 RFID Lock Sensor:
    @mfalkvidd
    I have followed the guide here (https://www.mysensors.org/build/rfid) to the letter. Yes, it could be me that have problems but this isn´t so hard project. Feels like something is missing?
    In the description it says:
    "To find out the unique ID of your tag just run the example while looking at serial monitor. Hold tag in front of reader and your identifier should pop up."
    This I did, but the monitor don`t show anything
    Regards,
    Sam.
    PS: I have tried it in the example MySensors sketch, and Serial Prints don't return anything, so it is not project specific;
    #define NODE_ID 3
    #define OPEN 1
    #define CLOSE 0
    MyMessage msg(NODE_ID, V_TRIPPED);
    uint8_t value = OPEN;
        present(NODE_ID, S_DOOR);
        value = value == OPEN ? CLOSE : OPEN;
        send(msg.set(value));
        Serial.print("TestMessage to Serial that is not displaying."); //<< Not displaying
        sleep(10000);
      Does it ever reach the loop-section then? Please post your log.
      samburner3S 1 Reply Last reply
      • T
        Tag
        wrote on last edited by Tag
        Hi!,
        Where did the following piece of code go?
        Serial.Begin(115200);
        That might help, since it will tell the sketch you want to talk to the outside world using serial communication.
        Have you tried that?
        Another option is adding this in your sketch:
        (before you include the mysensors lib!)
        See: https://www.mysensors.org/build/debug
        • T Tag
          Hi!,
          samburner3S
          samburner3S
          samburner3
          @Tag said in Is serial.print blocked by mySensors?:
          I did try putting in a Serial.begin(115200); as I mentioned in my post, and yes it was in the void setup loop.
          I also do have the #define MY_DEBUG and it outputs the radio debug only.
          Still did not fix it.
          T 1 Reply Last reply
            samburner3S
            samburner3S
            samburner3
            @hek It is reaching the loop, yep.
            Source Sketch:
            #define NODE_ID 3
            #define OPEN 1
            #define CLOSE 0
                sleep(10000);
            Serial Output:
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=2)
            TSM:FPAR
            TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            (the fails are not of concern at this time as my test bench is quite far from the gateway and I need to add a capacitor to the radio. This just proves that the program is hitting the loop but not outputting any Serial.print.)
              wrote on last edited by hek
              No, it's not....
              The node is searching for a gateway or repeater. If you want it to enter the loop without finding a parent, you have to add the following to your sketch:
              #define MY_TRANSPORT_WAIT_READY_MS 1
              Which means it will only wait one millisecond before entering loop even if transport is unavailable.
              • samburner3S samburner3
                Tag
                @samburner3
                Strange, will have a look later today see if i can recreate your issue.
                Did you post your complete sketch?
                  No, it's not....
                  samburner3S
                  samburner3S
                  samburner3
                  Oh so the send messages are it attempting to connect to the gateway? I thaught they were the loop as they were appearing exactly once a second (hence the sleep(10000);)
                  Even after moving next to the gateway it still won't connect? Gateway is up and ok:
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSM:RADIO:OK
                  0;255;3;0;9;TSM:GW MODE
                  0;255;3;0;9;TSM:READY
                  0;255;0;0;18;2.0.0
                  0;255;3;0;9;TSP:SANCHK:OK
                  Anyway first things first;
                  @hek Ok so I added the line #define MY_TRANSPORT_WAIT_READY_MS 1 to my sketch, however it did not turn blue in the IDE like other define tags have. This is using libray version 2.0.0.
                  So I re-added the mysensors lib from the menu in the IDE (Sketch > Include Library > MySensors) to ensure it was added correctly.
                  Then I tried to compile I got an error
                     #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                  exit status 1
                  Error compiling for board Arduino/Genuino Uno.
                  I think I got this before but overlooked it. However the sketch is the same as the example so not sure what I am missing?
                  My current sketch (with compile error):
                  #include <MyConfig.h>
                  //#include <MySensors.h>
                  #define NODE_ID 3
                  #define OPEN 1
                  #define CLOSE 0
                      sleep(10000);
                    Put MySensors include at the bottom of the file (or at least below the defines)
                    samburner3S 2 Replies Last reply
                      samburner3S
                      samburner3S
                      samburner3
                      @hek Ok have done so:
                      #define NODE_ID 3
                      #define OPEN 1
                      #define CLOSE 0
                          sleep(10000);
                      It now compiles ok however the MY_TRANSPORT_WAIT_READY_MS 1 is still not blue. (Just a sanity check this define feature exists in library version 2.0.0. correct?)
                      Also still no serial prints:
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                        samburner3S
                        samburner3S
                        samburner3
                        @hek Ok I tried again using lib version 2.1.1. and it works!
                        3 TSM:INIT
                        4 TSF:WUR:MS=1
                        11 TSM:INIT:TSP OK
                        13 TSF:SID:OK,ID=2
                        14 TSM:FPAR
                        1613 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        1620 MCO:BGN:STP
                        1622 MCO:BGN:INIT OK,TSP=0
                        1625 !MCO:SND:NODE NOT REG
                        TestMessage to Serial that is not displaying.1627 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        1635 !MCO:SLP:TNR
                        3621 !TSM:FPAR:NO REPLY
                        3623 TSM:FPAR
                        5223 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        7230 !TSM:FPAR:NO REPLY
                        7232 TSM:FPAR
                        8832 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        10839 !TSM:FPAR:NO REPLY
                        10841 TSM:FPAR
                        However the '1' is still not blue
                        and got the compile warning
                        warning: "MY_TRANSPORT_WAIT_READY_MS" redefined
                        note: this is the location of the previous definition
                         #define MY_TRANSPORT_WAIT_READY_MS (0ul)
                        Glad it is working, however would the output suggest it is not connected to the gate way or just not registered? (forgive me I should RTFM go read the serial debug output message documentation)
                        Is the MY_TRANSPORT_WAIT_READY_MS needed when not just connected to the gateway or when its has not been 'included' or regestered?
                        So the main code im MySensors won't run until what condition is met? (forgive me again I am still learning the exciting mySensors lib :)
