  3. Is serial.print blocked by mySensors?
11 Posts 3 Posters 5.1k Views 4 Watching
    Does it ever reach the loop-section then? Please post your log.
    samburner3S 1 Reply Last reply
    • T
      Tag
      wrote on last edited by Tag
      Hi!,
      Where did the following piece of code go?
      Serial.Begin(115200);
      That might help, since it will tell the sketch you want to talk to the outside world using serial communication.
      Have you tried that?
      Another option is adding this in your sketch:
      (before you include the mysensors lib!)
      See: https://www.mysensors.org/build/debug
      • T Tag
        Hi!,
        samburner3S
        samburner3S
        samburner3
        @Tag said in Is serial.print blocked by mySensors?:
        I did try putting in a Serial.begin(115200); as I mentioned in my post, and yes it was in the void setup loop.
        I also do have the #define MY_DEBUG and it outputs the radio debug only.
        Still did not fix it.
          samburner3S
          samburner3S
          samburner3
          @hek It is reaching the loop, yep.
          Source Sketch:
          #define NODE_ID 3
          #define OPEN 1
          #define CLOSE 0
          MyMessage msg(NODE_ID, V_TRIPPED);
          uint8_t value = OPEN;
              present(NODE_ID, S_DOOR);
              value = value == OPEN ? CLOSE : OPEN;
              send(msg.set(value));
              Serial.print("TestMessage to Serial that is not displaying.");
              sleep(10000);
          Serial Output:
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=2)
          TSM:FPAR
          TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          (the fails are not of concern at this time as my test bench is quite far from the gateway and I need to add a capacitor to the radio. This just proves that the program is hitting the loop but not outputting any Serial.print.)
            wrote on last edited by hek
            No, it's not....
            The node is searching for a gateway or repeater. If you want it to enter the loop without finding a parent, you have to add the following to your sketch:
            #define MY_TRANSPORT_WAIT_READY_MS 1
            Which means it will only wait one millisecond before entering loop even if transport is unavailable.
            • samburner3S samburner3
              Tag
              @samburner3
              Strange, will have a look later today see if i can recreate your issue.
              Did you post your complete sketch?
                No, it's not....
                samburner3S
                samburner3S
                samburner3
                Oh so the send messages are it attempting to connect to the gateway? I thaught they were the loop as they were appearing exactly once a second (hence the sleep(10000);)
                Even after moving next to the gateway it still won't connect? Gateway is up and ok:
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:RADIO:OK
                0;255;3;0;9;TSM:GW MODE
                0;255;3;0;9;TSM:READY
                0;255;0;0;18;2.0.0
                0;255;3;0;9;TSP:SANCHK:OK
                Anyway first things first;
                @hek Ok so I added the line #define MY_TRANSPORT_WAIT_READY_MS 1 to my sketch, however it did not turn blue in the IDE like other define tags have. This is using libray version 2.0.0.
                So I re-added the mysensors lib from the menu in the IDE (Sketch > Include Library > MySensors) to ensure it was added correctly.
                Then I tried to compile I got an error
                   #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                exit status 1
                Error compiling for board Arduino/Genuino Uno.
                I think I got this before but overlooked it. However the sketch is the same as the example so not sure what I am missing?
                My current sketch (with compile error):
                #include <MyConfig.h>
                //#include <MySensors.h>
                #define NODE_ID 3
                #define OPEN 1
                #define CLOSE 0
                    sleep(10000);
                  Put MySensors include at the bottom of the file (or at least below the defines)
                  samburner3S 2 Replies Last reply
                    samburner3S
                    samburner3S
                    samburner3
                    @hek Ok have done so:
                    #define NODE_ID 3
                    #define OPEN 1
                    #define CLOSE 0
                        sleep(10000);
                    It now compiles ok however the MY_TRANSPORT_WAIT_READY_MS 1 is still not blue. (Just a sanity check this define feature exists in library version 2.0.0. correct?)
                    Also still no serial prints:
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                      samburner3S
                      samburner3S
                      samburner3
                      @hek Ok I tried again using lib version 2.1.1. and it works!
                      3 TSM:INIT
                      4 TSF:WUR:MS=1
                      11 TSM:INIT:TSP OK
                      13 TSF:SID:OK,ID=2
                      14 TSM:FPAR
                      1613 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      1620 MCO:BGN:STP
                      1622 MCO:BGN:INIT OK,TSP=0
                      1625 !MCO:SND:NODE NOT REG
                      TestMessage to Serial that is not displaying.1627 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      1635 !MCO:SLP:TNR
                      3621 !TSM:FPAR:NO REPLY
                      3623 TSM:FPAR
                      5223 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      7230 !TSM:FPAR:NO REPLY
                      7232 TSM:FPAR
                      8832 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      10839 !TSM:FPAR:NO REPLY
                      10841 TSM:FPAR
                      However the '1' is still not blue
                      and got the compile warning
                      warning: "MY_TRANSPORT_WAIT_READY_MS" redefined
                      note: this is the location of the previous definition
                       #define MY_TRANSPORT_WAIT_READY_MS (0ul)
                      Glad it is working, however would the output suggest it is not connected to the gate way or just not registered? (forgive me I should RTFM go read the serial debug output message documentation)
                      Is the MY_TRANSPORT_WAIT_READY_MS needed when not just connected to the gateway or when its has not been 'included' or regestered?
                      So the main code im MySensors won't run until what condition is met? (forgive me again I am still learning the exciting mySensors lib :)
