  3. mysgw: bind: Address already in use
7 Posts 4 Posters 4.1k Views 4 Watching
  • F Offline
    F Offline
    fipster
    Hi there!
    Just started with my diy home automation project and as was following the https://www.mysensors.org/build/raspberry tutorial.
    What I have done so far:
    1. Installed openhab2 on a rpi2
    2. followed all the steps of the guide
    3. wired the NRF24L01+ onto the rpi
    Now, as my sensors haven't arrived yet, I would like to test if I can make the rpi and a adruino mini pro communicate via the radio.
    The problem:
    pi@raspberrypi:~ $ sudo /usr/local/bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: Failed to bind!
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: accept: Bad file descriptor
    mysgw: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    mysgw: !TSF:MSG:LEN,0!=7
    I found what I think is a similar issue here: https://forum.mysensors.org/topic/1598/openhab-2-0-binding/303
    But the process was overwhelming for a a beginner at my level.
    There probably is a step I am missing, but couldn't locate it.
    The problem with all these tutorials is that they tell what to do but don't explain what you are doing and why. If anyone knows any good basic principle "text books" on the subject, please add a link or something.
    Regards,
    Fipster
    • T Offline
      T Offline
      TimO
      Looks like another service is already blocking the port for the gateway. My guess: there already is a instance of the gateway running. Check with: "ps -ax" command. You should see all running process.
      F 1 Reply Last reply
      • T TimO
        F Offline
        F Offline
        fipster
        @TimO
        Thank you for quick response!
        There are the running processes:
          PID TTY      STAT   TIME COMMAND
            1 ?        Ss     0:03 /sbin/init splash
            2 ?        S      0:00 [kthreadd]
            3 ?        S      0:01 [ksoftirqd/0]
            5 ?        S<     0:00 [kworker/0:0H]
            7 ?        S      0:15 [rcu_sched]
            8 ?        S      0:00 [rcu_bh]
            9 ?        S      0:00 [migration/0]
           10 ?        S      0:00 [migration/1]
           11 ?        S      0:01 [ksoftirqd/1]
           13 ?        S<     0:00 [kworker/1:0H]
           14 ?        S      0:00 [migration/2]
           15 ?        S      0:01 [ksoftirqd/2]
           17 ?        S<     0:00 [kworker/2:0H]
           18 ?        S      0:00 [migration/3]
           19 ?        S      0:02 [ksoftirqd/3]
           21 ?        S<     0:00 [kworker/3:0H]
           22 ?        S      0:00 [kdevtmpfs]
           23 ?        S<     0:00 [netns]
           24 ?        S<     0:00 [perf]
           25 ?        S      0:00 [khungtaskd]
           26 ?        S<     0:00 [writeback]
           27 ?        S<     0:00 [crypto]
           28 ?        S<     0:00 [bioset]
           29 ?        S<     0:00 [kblockd]
           30 ?        S      0:00 [kworker/0:1]
           31 ?        S<     0:00 [rpciod]
           32 ?        S      0:00 [kswapd0]
           33 ?        S<     0:00 [vmstat]
           34 ?        S      0:00 [fsnotify_mark]
           35 ?        S<     0:00 [nfsiod]
           44 ?        S<     0:00 [kthrotld]
           45 ?        S<     0:00 [bioset]
           46 ?        S<     0:00 [bioset]
           47 ?        S<     0:00 [bioset]
           48 ?        S<     0:00 [bioset]
           49 ?        S<     0:00 [bioset]
           50 ?        S<     0:00 [bioset]
           51 ?        S<     0:00 [bioset]
           52 ?        S<     0:00 [bioset]
           53 ?        S<     0:00 [bioset]
           54 ?        S<     0:00 [bioset]
           55 ?        S<     0:00 [bioset]
           56 ?        S<     0:00 [bioset]
           57 ?        S<     0:00 [bioset]
           58 ?        S<     0:00 [bioset]
           59 ?        S<     0:00 [bioset]
           60 ?        S<     0:00 [bioset]
           61 ?        S<     0:00 [bioset]
           62 ?        S<     0:00 [bioset]
           63 ?        S<     0:00 [bioset]
           64 ?        S<     0:00 [bioset]
           65 ?        S<     0:00 [bioset]
           66 ?        S<     0:00 [bioset]
           67 ?        S<     0:00 [bioset]
           68 ?        S<     0:00 [bioset]
           69 ?        S<     0:00 [VCHIQ-0]
           70 ?        S<     0:00 [VCHIQr-0]
           71 ?        S<     0:00 [VCHIQs-0]
           72 ?        S<     0:00 [iscsi_eh]
           73 ?        S<     0:00 [dwc_otg]
           75 ?        S<     0:00 [DWC Notificatio]
           77 ?        S      0:00 [VCHIQka-0]
           78 ?        S<     0:00 [deferwq]
           80 ?        S<     0:00 [bioset]
           81 ?        S      0:01 [mmcqd/0]
           82 ?        S      0:00 [jbd2/mmcblk0p2-]
           83 ?        S<     0:00 [ext4-rsv-conver]
           87 ?        S<     0:00 [ipv6_addrconf]
          104 ?        S<     0:00 [kworker/0:1H]
          131 ?        Ss     0:06 /lib/systemd/systemd-journald
          135 ?        Ss     0:00 /lib/systemd/systemd-udevd
          283 ?        S      0:00 [kworker/2:2]
          367 ?        Ssl    0:01 /usr/sbin/rsyslogd -n
          368 ?        Ss     0:00 /usr/sbin/cron -f
          370 ?        Ss     0:00 avahi-daemon: running [raspberrypi.local]
          371 ?        Ss     1:51 /usr/local/bin/mysgw
          372 ?        Ss     0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfil
          375 ?        S      0:00 avahi-daemon: chroot helper
          379 ?        S<     0:00 [cfg80211]
          380 ?        Ss     0:00 /sbin/dhcpcd -q -b
          405 ?        Ss     0:00 /lib/systemd/systemd-logind
          414 ?        S<     0:00 [kworker/3:1H]
          430 ?        Ss     0:00 /usr/sbin/sshd -D
          437 ?        Ss     0:00 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
          454 ?        Ssl    0:00 /usr/sbin/lightdm
          596 ?        Ss     0:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --so
          619 tty7     Ssl+   0:03 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -no
          620 tty1     Ss     0:00 /bin/login -f
          621 ?        Ss     0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:111
          622 ?        Ss+    0:00 /sbin/agetty --keep-baud 115200 38400 9600 ttyAMA0 vt102
          629 ?        S<     0:00 [kworker/2:1H]
          633 ?        Ss     0:00 /lib/systemd/systemd --user
          638 ?        S      0:00 (sd-pam)
          646 tty1     S+     0:00 -bash
          703 ?        Sl     0:00 lightdm --session-child 13 16
          723 ?        Ssl    0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
          782 ?        Sl     1:53 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc
          804 ?        Ss     0:00 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session x-sessio
          807 ?        S      0:00 /usr/bin/dbus-launch --exit-with-session x-session-manager
          808 ?        Ss     0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --sessio
          818 ?        Sl     0:00 /usr/lib/gvfs/gvfsd
          822 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
          823 ?        S<     0:00 [kworker/1:1H]
          997 ?        S      0:01 openbox --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
          999 ?        Sl     0:00 lxpolkit
         1003 ?        Sl     0:01 pcmanfm --desktop --profile LXDE-pi
         1009 ?        Ss     0:00 /usr/bin/ssh-agent -s
         1018 ?        Ssl    0:00 /usr/lib/policykit-1/polkitd --no-debug
         1023 ?        S      0:00 sh -c zenity --info --text="Your Raspbian system has been upgraded t
         1025 ?        Sl     0:01 zenity --info --text=Your Raspbian system has been upgraded to the l
         1049 ?        Sl     0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
         1051 ?        Ssl    0:00 /usr/lib/udisks2/udisksd --no-debug
         1063 ?        SNsl   0:00 /usr/lib/rtkit/rtkit-daemon
         1073 ?        Sl     0:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
         1077 ?        Sl     0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
         1083 ?        Sl     0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
         1089 ?        Sl     0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
         1091 ?        Ss     0:00 /usr/lib/bluetooth/bluetoothd
         1104 ?        S      0:00 /bin/sh /usr/bin/start-pulseaudio-x11
         1105 ?        S      0:00 /usr/bin/xprop -root -spy
         1121 ?        Ssl    0:00 /usr/lib/menu-cache/menu-cached /tmp/.menu-cached-:0-pi
         1138 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.1 /org/gtk/gvfs/exec_spaw/0
         1508 ?        S      0:00 [kworker/u8:0]
         1523 ?        S      0:00 [kworker/1:2]
         1556 ?        S      0:00 [kworker/3:2]
         1641 ?        Sl     0:08 lxpanel --profile LXDE-pi
         1661 ?        S      0:00 [spi0]
         1747 ?        S      0:00 [kworker/2:0]
         1762 ?        Ss     0:00 sshd: pi [priv]
         1769 ?        R      0:00 sshd: pi@pts/0
         1771 pts/0    Ss     0:00 -bash
         1874 ?        Ssl    0:00 /usr/lib/packagekit/packagekitd
         1883 ?        S      0:00 [kworker/3:1]
         2153 ?        S      0:00 [kworker/1:0]
         2212 ?        S      0:00 [kworker/0:0]
         2241 ?        S      0:00 [kworker/u8:2]
         2286 pts/0    R+     0:00 ps -ax
        • F fipster
          @TimO
              8 ?        S      0:00 [rcu_bh]
             24 ?        S<     0:00 [perf]
          @fipster you already have one mysgw running
          • J Offline
            J Offline
            jacikaas
            I asking for help with same question. How I see there is no solution, so I try to explain step by step what I did and whats the problem I have.
            1. I install Domoticz on fresh Raspberry Pi Raspbian image
            2. Build a Raspberry Pi Ethernet Gateway by instructions (https://www.mysensors.org/build/raspberry)
              • git clone https://github.com/mysensors/MySensors.git --branch master
              • cd MySensors
              • sudo ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003
            3. After that comand I have answer, that my SoC and Type of machine unknown (I using RPi 2):
            [SECTION] Detecting target machine.
              [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv7l.
            But I found the solution about that in forum, where I change two lines of the configure file to "BCM2835":
            function detect_machine {
                case $hardware in
                BCM2835)
                    soc="BCM2835"
                    if [[ $machine == "Raspberry"* ]]; then
                        local rev=($(detect_rpi_revision))
                        if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                            tp="RPi3"
                        else
                            tp="Rpi2"
                        fi
                    fi
            After changing it , all looks fine.
            1. I repeat
            My board is recognized so I continue with gateway building instructions...
            • sudo make
            • sudo ./bin/mysgw -h
            • sudo ./bin/mysgw -d
            And I got results with no errors, gateway is running. Continue with comands
            • sudo make install
            • sudo systemctl enable mysgw.service
            • sudo systemctl start mysgw.service
            No errors. I connect one LED strip node to Domoticz and its working perfectly.
            But after ~10 minutes trying to on/off LED strip it doesn't work anymore. Nothing was changed. Checking the gateway with command:
            And getting:
            Sep 24 21:37:15 raspberrypi mysgw: accept: Bad file descriptor
            Output of "ps -ax" command:
                1 ?        Ss     0:02 /sbin/init splash
                3 ?        S      0:00 [ksoftirqd/0]
                6 ?        S      0:00 [kworker/u8:0]
                7 ?        S      0:01 [rcu_sched]
                8 ?        S      0:00 [rcu_bh]
               10 ?        S<     0:00 [lru-add-drain]
               11 ?        S      0:00 [cpuhp/0]
               12 ?        S      0:00 [cpuhp/1]
               13 ?        S      0:00 [migration/1]
               14 ?        S      0:00 [ksoftirqd/1]
               16 ?        S<     0:00 [kworker/1:0H]
               17 ?        S      0:00 [cpuhp/2]
               18 ?        S      0:00 [migration/2]
               19 ?        S      0:00 [ksoftirqd/2]
               21 ?        S<     0:00 [kworker/2:0H]
               22 ?        S      0:00 [cpuhp/3]
               23 ?        S      0:00 [migration/3]
               24 ?        S      0:00 [ksoftirqd/3]
               26 ?        S<     0:00 [kworker/3:0H]
               27 ?        S      0:00 [kdevtmpfs]
               28 ?        S<     0:00 [netns]
               29 ?        S      0:00 [khungtaskd]
               30 ?        S      0:00 [oom_reaper]
               31 ?        S<     0:00 [writeback]
               32 ?        S      0:00 [kcompactd0]
               33 ?        S<     0:00 [crypto]
               34 ?        S<     0:00 [bioset]
               35 ?        S<     0:00 [kblockd]
               36 ?        S<     0:00 [watchdogd]
               37 ?        S      0:00 [kworker/0:1]
               38 ?        S<     0:00 [rpciod]
               39 ?        S<     0:00 [xprtiod]
               40 ?        S      0:00 [kswapd0]
               41 ?        S<     0:00 [vmstat]
               42 ?        S<     0:00 [nfsiod]
               52 ?        S<     0:00 [kthrotld]
               69 ?        S<     0:00 [bioset]
               70 ?        S<     0:00 [bioset]
               71 ?        S<     0:00 [bioset]
               72 ?        S<     0:00 [bioset]
               73 ?        S<     0:00 [bioset]
               74 ?        S<     0:00 [bioset]
               75 ?        S<     0:00 [bioset]
               76 ?        S<     0:00 [bioset]
               77 ?        S<     0:00 [iscsi_eh]
               78 ?        S<     0:00 [dwc_otg]
               80 ?        S<     0:00 [DWC Notificatio]
               81 ?        S<     0:00 [VCHIQ-0]
               82 ?        S<     0:00 [VCHIQr-0]
               83 ?        S<     0:00 [VCHIQs-0]
               84 ?        S      0:00 [VCHIQka-0]
               85 ?        S<     0:00 [SMIO]
               88 ?        S<     0:00 [bioset]
               89 ?        S      0:00 [mmcqd/0]
               90 ?        S      0:00 [jbd2/mmcblk0p2-]
               91 ?        S<     0:00 [ext4-rsv-conver]
               93 ?        S      0:00 [kworker/3:1]
               94 ?        S<     0:00 [ipv6_addrconf]
              109 ?        S<     0:00 [kworker/1:1H]
              110 ?        S      0:00 [kworker/u8:1]
              115 ?        Ss     0:11 /lib/systemd/systemd-journald
              144 ?        S      0:00 [kworker/1:3]
              150 ?        Ss     0:00 /lib/systemd/systemd-udevd
              200 ?        S      0:00 [spi0]
              238 ?        S      0:00 [kworker/3:2]
              266 ?        Ssl    0:00 /lib/systemd/systemd-timesyncd
              288 ?        Ss     0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
              291 ?        Ss     0:00 /usr/sbin/cron -f
              292 ?        Ssl    0:04 /usr/sbin/rsyslogd -n
              293 ?        Ss     0:00 avahi-daemon: running [raspberrypi.local]
              295 ?        Rs    80:53 /usr/local/bin/mysgw
              297 ?        Ss     0:00 /lib/systemd/systemd-logind
              299 ?        Ss     0:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
              309 ?        S      0:00 avahi-daemon: chroot helper
              320 ?        S<     0:00 [cfg80211]
              324 ?        Ss     0:00 /sbin/dhcpcd -q -b
              359 ?        Ss     0:00 /usr/sbin/sshd -D
              378 ?        Ssl    0:00 /usr/sbin/lightdm
              381 ?        S<     0:00 [kworker/2:1H]
              390 tty1     Ss     0:00 /bin/login -f
              393 ?        Ss+    0:00 /sbin/agetty --keep-baud 115200,38400,9600 ttyAMA0 vt220
              400 tty7     Ssl+   0:03 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
              402 ?        Ssl    0:16 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
              403 ?        S<     0:00 [kworker/3:1H]
              431 ?        Sl     0:00 lightdm --session-child 14 17
              439 ?        Ss     0:00 /lib/systemd/systemd --user
              442 ?        S      0:00 (sd-pam)
              447 ?        Ssl    0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
              456 ?        Ss     0:00 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation
              501 tty1     S+     0:00 -bash
              520 ?        Ss     0:00 /usr/bin/ssh-agent x-session-manager
              526 ?        Ssl    0:00 /usr/lib/gvfs/gvfsd
              531 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
              547 ?        S      0:01 openbox --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
              549 ?        Sl     0:00 lxpolkit
              551 ?        Sl     0:12 lxpanel --profile LXDE-pi
              553 ?        Sl     0:01 pcmanfm --desktop --profile LXDE-pi
              561 ?        Ss     0:00 /usr/bin/ssh-agent -s
              570 ?        Ssl    0:00 /usr/lib/policykit-1/polkitd --no-debug
              585 ?        Ssl    0:00 /usr/lib/menu-cache/menu-cached /run/user/1000/menu-cached-:0
              589 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
              592 ?        Ssl    0:00 /usr/lib/udisks2/udisksd --no-debug
              603 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
              607 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
              611 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
              620 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
              633 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.4 /org/gtk/gvfs/exec_spaw/0
              733 ?        S      0:00 sudo ./bin/mysgw -d
              737 ?        R     80:45 ./bin/mysgw -d
              751 ?        S<     0:00 [kworker/0:1H]
              760 ?        S      0:00 [kworker/0:0]
              761 ?        S      0:00 [kworker/1:1]
              766 ?        Ss     0:00 sshd: pi [priv]
              776 ?        R      0:01 sshd: pi@pts/1
              779 pts/1    Ss     0:00 -bash
              805 pts/1    T      0:00 sudo ./bin/mysgw -d
              809 pts/1    T      0:25 ./bin/mysgw -d
              850 ?        S      0:00 [kworker/2:1]
              857 ?        S      0:00 [kworker/2:0]
              862 pts/1    R+     0:00 ps -ax
            cat /sys/firmware/devicetree/base/model
            Raspberry Pi 2 Model B Rev 1.1
            Don't know how to fix that
            Looks like I using gateway building instructions step by step, but something is missing... Thanks.
            • J jacikaas
                • cd MySensors
                  case $hardware in
                  BCM2835)
                      soc="BCM2835"
                              tp="RPi3"
                          else
                              tp="Rpi2"
                          fi
                      fi
              1. I repeat
              • sudo make
              • sudo make install
              And getting:
                  8 ?        S      0:00 [rcu_bh]
                 85 ?        S<     0:00 [SMIO]
                200 ?        S      0:00 [spi0]
              @jacikaas as can be seen from the ps output, mysgw is already running:
              It is running because you started it with
              So when you try to start another instance of mysgw by running
              sudo ./bin/mysgw -d
              the new instance tries to start listening on the same port, which it can't because it is already in use.
              As mentioned in the troubleshooting section, look in /var/log/syslog to see the gateway output of the existing instance. Don't start a new one.
              Also, it seems your sudo key has gotten stuck :( If you missed that not every command is preceeded by sudo in the build instructions, maybe it is worth considering that you missed something else?
              J 1 Reply Last reply
                sudo ./bin/mysgw -d
                J Offline
                J Offline
                jacikaas
                @mfalkvidd
                Thank You for the answer.
                @mfalkvidd said in mysgw: bind: Address already in use:
                Ohh... Thats a lot more clear now... I thought command "sudo ./bin/mysgw -d" is not a service start, but just something like output mirror. Like "tail". Could I somehow use tail for watching real time output on ./bin/mysgw -d ?
                Sorry for dumb questions, but how I make that sudo key stuck? It's becose of that I start a few mysgw services?
                Another silly question, becose I'm very "advanced user" in UNIX, my best friend is called desktop there, and I know basically just install, nano, cp, rm commands, I need to ask :) Is there should be difference if I will use "make" instead of "sudo make". Sudo means that I run this command by root user, but does it make difference between "make" or "sudo make"? And if I remember clearly if I run only "make" - raspberry pi starts to swearing, but with sudo, it's ok.
                When I install the gateway by command "sudo make install" I can see that installing was successful, there is info that if I want to run this on boot I need to run two lines:
                But now, I guess, I do not need them both, because start on boot is described in "sudo make install"?
                12.1k
