  3. 💬 RFM69 Relay Actuator Node (mains powered)
rfm69mysensorsrelay
10 Posts 7 Posters 2.9k Views 7 Watching
  • openhardware.ioO Offline
    openhardware.io
    https://www.openhardware.io/view/334/RFM69-Relay-Actuator-Node-mains-powered
    • AnticimexA Offline
      AnticimexA Offline
      Anticimex
      Nice board. Please also add the necessary documentation to follow the CERN open hardware license guidelines. This is also discussed here.
      • hekH Offline
        hekH Offline
        Sweet board @mtiutiu !
        • alexsh1A Offline
          alexsh1A Offline
          alexsh1
          Excellent board!
          @mtiutiu did you receive the board? did you test it?
          mtiutiuM 1 Reply Last reply
          • alexsh1A alexsh1
            Excellent board!
            mtiutiuM Offline
            mtiutiuM Offline
            mtiutiu
            @alexsh1
            I sent the design files for manufacturing last week so it will take about 2-3 weeks to arrive to my door. I know this may be a long time but unfortunately this is out of my control.
            • PhracturedBlueP Offline
              PhracturedBlue
              Is there a reason you chose to use the AMS1117 vs directly using an HLK-PM03? Are you worried about P/S ripple?
              Also, did you consider using a thermal fuse? As far as I know the HLK-PM01 does not have any thermal protection
              Nice board. I'll be awaiting your results.
              • PhracturedBlueP PhracturedBlue
                mtiutiuM Offline
                mtiutiuM Offline
                mtiutiu
                wrote on last edited by mtiutiu
                @PhracturedBlue
                Well the reason I used HLK-PM01 in the first place was because I had many laying around and actually this was the first AC/DC compact module that I bought when it first came out on aliexpress. I noticed that a 3.3V variant came out in the meantime but I didn't wanted to invest more and buy it. I have also many AMS1117/3.3V chips around so yeah...I think you know now why. This is a good combination also for reducing power supply ripple because it's a switching one type so a classic voltage regulator can reduce the ripple - well I'm not saying that the AMS1117 it's a very good candidate for this regarding PSRR but it has for sure some effect.
                • E Offline
                  E Offline
                  esawyja
                  Hi
                  Nice design, what will the rated watts be, I think the relay (RM50-SP) is 10A at 240VAC? So will that be 2400W max? Also the relay coil voltage, will you use a 5V coil as I can only see RM50-SPs in 24V?
                  • E esawyja
                    Hi
                    mtiutiuM Offline
                    mtiutiuM Offline
                    mtiutiu
                    @esawyja
                    I see now that it was withdrawn from sales. This is the main supplier from where I buy components and from where that relay was bought: http://www.tme.eu/en/details/rm50-z-05/miniature-electromagnetic-relays/relpol/rm50-3021-85-1005/.
                    This site offers some alternatives: http://micros.com.pl/en/product/17467/p-rm50z005 . But please bear in mind that it's the 4 pins variant not the 5 pins one.
                    • mtiutiuM Offline
                      mtiutiuM Offline
                      mtiutiu
                      I finally received the boards from the manufacturer(big thanks to @Seeed-Fusion). I manage to assemble one board by soldering the components and such and...it WORKS(including OTA)! I will post the instructions on openhardware.io project page.
