  3. help about simple roller shutter sketch
1 Posts 1 Posters 953 Views 1 Watching
  • R
    R
    Reza
    hi
    i use this sketch for roller shutter with button.
    i want when connection is fail so button work lonely ! and when push button if connection is ok a message send to controller and in domoticz i see open or close or stop.if connection is fail (or not) after 2 hours send a message to controller from state of Blind.
    #define MY_RF24_CHANNEL 0
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 11
    #define MY_TRANSPORT_WAIT_READY_MS 10000
    #include <Bounce2.h>
    #define RELAY_ON 0
    #define RELAY_OFF 1
    #define CHILD_ID 1
    const int buttonPinA = 14;
    const int buttonPinB = 15;
    const int buttonPinC = 16;
    const int relayPinA = 3;
    const int relayPinB = 4;
    int oldValueA = 0;
    int oldValueB = 0;
    int oldValueC = 0;
    bool stateA = false;
    bool stateB = false;
    bool stateC = false;
    int trigger = 0;
    unsigned long time_m;
    unsigned long a;
    Bounce debouncerA = Bounce();
    Bounce debouncerB = Bounce();
    Bounce debouncerC = Bounce();
    MyMessage msg(CHILD_ID, V_PERCENTAGE);
      pinMode(buttonPinA, INPUT_PULLUP);
      pinMode(buttonPinB, INPUT_PULLUP);
      pinMode(buttonPinC, INPUT_PULLUP);
      pinMode(relayPinA, OUTPUT);
      pinMode(relayPinB, OUTPUT);
      debouncerA.attach(buttonPinA);
      debouncerA.interval(5);
      debouncerB.attach(buttonPinB);
      debouncerB.interval(5);
      debouncerC.attach(buttonPinC);
      debouncerC.interval(5);
      digitalWrite(relayPinA, RELAY_OFF);
      digitalWrite(relayPinB, RELAY_OFF);
      oldValueA = digitalRead(buttonPinA);
      oldValueB = digitalRead(buttonPinB);
      oldValueC = digitalRead(buttonPinC);
      sendSketchInfo("Roller shutter", "1.0");
      present(CHILD_ID, S_COVER);
        time_m = millis();
        a = time_m % 7200000;
        if (a == 0) {
          send(msg.set(stateA));
          send(msg.set(stateB));
          send(msg.set(stateC));
        debouncerA.update();
        // Get the update value
        int valueA = debouncerA.read();
        if (valueA != oldValueA) {
          stateA =  !stateA;
          send(msg.set(stateA),false);
          digitalWrite(relayPinA, HIGH);
          delay(500);
          digitalWrite(relayPinB, LOW);
          oldValueA = valueA;
        debouncerB.update();
        int valueB = debouncerB.read();
        if (valueB != oldValueB) {
          stateB =  !stateB;
          send(msg.set(stateB),false);
          delay(500);
          digitalWrite(relayPinB, HIGH);
          oldValueB = valueB;
        debouncerC.update();
        int valueC = debouncerC.read();
        if (valueC != oldValueC) {
          stateC =  !stateC;
          send(msg.set(stateC),false);
          delay(500);
          digitalWrite(relayPinA, LOW);
          oldValueC = valueC;
      if (message.type == V_UP) {
            stateA = message.getBool();
            delay(500);
       if (message.type == V_STOP ){
            stateB = message.getBool();
            delay(500);
         if (message.type == V_DOWN){
            stateC = message.getBool();
            delay(500);
        // Write some debug info
        Serial.println(message.sensor);
        Serial.print("from node:");
        Serial.println(message.sender);
    what do change in my sketch ? thank you
