Plugin for Indigo for Mac
Yesterday evening I added a bit to the read me and improved support for the motion sensor.
And I updated the readme file so that it should be possible for those that feel like it to start testing it.
This was my favourite piece of work :) -
It is a long time ago (too long) since I found the time to work on the plugin.
Once I restarted the project I noticed that 1.4 beta was out so I first wanted to work on adopting these libs before moving on.There are still a few things I don't like so I am not going to commit yet but the work is going well.
One of the things I wanted to add was support for the battery level.
Indigo supports it very well (see screenshot) and it is dynamic.What does that mean: when you implement 'gw.sendBatteryLevel(value);' indigo will create support for it and from that moment on Indigo will update the battery level.
BTW don't pay attention to the 200%, I definitely need to do some additional work on my battery check libs...
I will keep you posted again :)
Following the release of MySensors 1.4 I made the latest build of the MySensors plugin for Indigo available on GitHub.
I have been using it for a while now with 1.4beta and changed things around to support the 1.4 release (among other things).
When you start using this version of the plugin please be aware of yet limited support of sensors simply because I have not (yet in some cases) built them...
Please use GitHub to let me know about bugs and/or feature requests...
- Added support for 1.4 (1.3 is not supported anymore).
- Added support for batteryLevel
- Added more variable types with 'native' states instead of generic states:
- TEMP
- HUM
- PRESSURE
- RAIN
- RAINRATE
- WIND
- GUST
- UV
- DISTANCE
- TRIPPED
- HEATER_SW
- LIGHT_LEVEL
- Added menu item to remove failed devices
- Added menu item to remove unused device
- Cleaned up and optimized code
I released a new, more stable, version of the plugin: https://github.com/IT2BE/indigo-mysensors/releases/tag/v1.2.179.
From the release notes:
- Added menu item to reset the plugin (all sensors and devices are removed).
- Improved the way a plugin is added or updated.
- Fixed an issue with on/off state sensor like the motion sensor.
