  3. Indigo Domotics
  4. Plugin for Indigo for Mac
Scheduled Pinned Locked Moved Indigo Domotics
28 Posts 3 Posters 16.3k Views 2 Watching
  • marceltrapmanM
    marceltrapmanM
    marceltrapman
    wrote on last edited by marceltrapman
    @wannabee @hek
    Both your answers have helped me a lot! Thanks a million!!!
    My 'issue' was that I was trying to do all the fancy stuff from the Controller (Indigo, or better my plugin, in this case) but obviously the sensor can be set to be active as well :)
    I have made great progress today thanks to you guys...
    Fulltime Servoy Developer
    • marceltrapmanM
      marceltrapmanM
      marceltrapman
      For the fun of it!
      Screen Shot 2014-04-29 at 21.42.13.png Screen Shot 2014-04-29 at 21.42.40.png Screen Shot 2014-04-29 at 21.42.58.png
        Cool! Great work!
        • marceltrapmanM
          marceltrapmanM
          marceltrapman
          Thanks, while looking at my screenshots again I also found a little mistake :)
          • marceltrapmanM
            marceltrapmanM
            marceltrapman
            Here you see the full power of Indigo.
            I added 2 relays to the existing temperature sensor.
            In fact a created a custom multi sensor.
            This is what it looks like in Indigo.
            I will make it so that when a device will be updated or added all sensors are included :)
            • marceltrapmanM
              marceltrapmanM
              marceltrapman
              I am happy, the plugin is not ready but I moved it to my Indigo Server and it is now in production :)
              What am I using it for right now?
              The temperature sensor shows the temperature in a computer cabinet.
              Based on the temperature a fan is enabled/disabled to lower the temperature.
              For that I added the board with attached sensors and I created triggers.
              Here it is:...
              Screen Shot 2014-05-06 at 22.11.48.png Screen Shot 2014-05-06 at 22.12.13.png Screen Shot 2014-05-06 at 22.12.17.png
              • marceltrapmanM
                marceltrapmanM
                marceltrapman
                Added the source to github: https://github.com/IT2BE/indigo-mysensors
                Please beware: the plugin is not ready. I have a few sensors working but I am awaiting my mini pro's to be delivered before I can move ahead.
                In the meantime I will polish things as I am also getting ready to go on vacation in about 10 days :)
                  Nice.
                  I cloned it to mysensors so people will find it easier.
                  • marceltrapmanM
                    marceltrapmanM
                    marceltrapman
                    @hek thanks!
                    When, in the future, you want to move it to your repo that is fine with me as well.
                    • marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      Yesterday evening I added a bit to the read me and improved support for the motion sensor.
                      • marceltrapmanM
                        marceltrapmanM
                        marceltrapman
                        And I updated the readme file so that it should be possible for those that feel like it to start testing it.
                        This was my favourite piece of work :)
                          Ok, great work!
                          Pulled your changes.
                          • marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            It is a long time ago (too long) since I found the time to work on the plugin.
                            Once I restarted the project I noticed that 1.4 beta was out so I first wanted to work on adopting these libs before moving on.
                            There are still a few things I don't like so I am not going to commit yet but the work is going well.
                            One of the things I wanted to add was support for the battery level.
                            Indigo supports it very well (see screenshot) and it is dynamic.
                            What does that mean: when you implement 'gw.sendBatteryLevel(value);' indigo will create support for it and from that moment on Indigo will update the battery level.
                            BTW don't pay attention to the 200%, I definitely need to do some additional work on my battery check libs...
                            I will keep you posted again :)
                            • marceltrapmanM
                              marceltrapmanM
                              marceltrapman
                              Following the release of MySensors 1.4 I made the latest build of the MySensors plugin for Indigo available on GitHub.
                              I have been using it for a while now with 1.4beta and changed things around to support the 1.4 release (among other things).
                              When you start using this version of the plugin please be aware of yet limited support of sensors simply because I have not (yet in some cases) built them...
                              Please use GitHub to let me know about bugs and/or feature requests...
                              • Added support for 1.4 (1.3 is not supported anymore).
                              • Added support for batteryLevel
                              • Added more variable types with 'native' states instead of generic states:
                              • TEMP
                              • HUM
                              • PRESSURE
                              • RAIN
                              • RAINRATE
                              • WIND
                              • GUST
                              • UV
                              • DISTANCE
                              • TRIPPED
                              • HEATER_SW
                              • LIGHT_LEVEL
                              • Added menu item to remove failed devices
                              • Added menu item to remove unused device
                              • Cleaned up and optimized code
                              • marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                #28
                                I released a new, more stable, version of the plugin: https://github.com/IT2BE/indigo-mysensors/releases/tag/v1.2.179.
                                From the release notes:
                                • Added menu item to reset the plugin (all sensors and devices are removed).
                                • Improved the way a plugin is added or updated.
                                • Fixed an issue with on/off state sensor like the motion sensor.
