  3. Multi-sensor soil moisture node
3 Posts 3 Posters 3.5k Views 3 Watching
  • L
    L
    lafleur
    wrote on last edited by lafleur
    This is a work in progress! , but most everything works.
    Heavy rain lately, so soil is at 100% saturation...
    This was developed with MySensor 2.1.1  https://www.mysensors.org/
    IDE 1.81
    SAMD 1.6.11
    RocketScream M0 with RFM95 radio
    Data from the sensor to MQTT-gateway to MQTT to (Telegraf to InFluxdb to Grafana)
    Controller function via NODE.RED connected via MQTT.
    It measures soil moisture from 1 to 4 sensors, has options for soil and air temperature.
    Support MCP9800 or Si7021 (humidity also) or temp sensor in DS3231 for air temp
    DS18B20 for soil temp
    Support of a water pressure sensor via an analog port
    Has a DS3231 Real Time clock to wake up processor at designated hour
    Has support on the board for a flow meter and pressure sensor (but no software in this code base)
    Solar, battery Powered or via 8 to 28v AC or DC
    Sleep's most of the time and just wakes up to see if its time to send a report.
    Support for requesting and receiving time of day for setting RTC
    Support for updating sensor tx schedule via V_VAR1
    (Board is designed to fit in a Hammond 1554 case)
    https://github.com/trlafleur/Soil_Moisture_Sensor_MS_R1.1-RFM95
    http://www.rocketscream.com/blog/product/mini-ultra-pro-with-radio/
    Sensor are made from plaster of paris (gypsum)
    http://vanderleevineyard.com/1/post/2012/07/the-vinduino-project-2-making-and-installing-gypsum-soil-moisture-sensors.html
    http://www.irrometer.com/sensors.html#wm
    https://www.amazon.com/Delmhorst-GB-1-Gypsum-Sensor-Moisture/dp/B0002IKRUS (pkg of 10 each)
    Based on the work of: Reinier van der Lee, www.vanderleevineyard.com
    0_1487526137636_IMG_5178.JPG 0_1487526144517_IMG_5177.JPG 0_1487526150950_IMG_5308.JPG
    • L lafleur
      IDE 1.81
      SAMD 1.6.11
      Very nice work @lafleur !
      • scalzS
        scalzS
        wrote on last edited by scalz
        I've a similar project in progress :) but not same cpu, nor tensiometer-like sensors, and i'm doing my custom box..
        but this is a nice setup, good work :+1:
