  3. Which chip for OTA flash?
9 Posts 3 Posters 2.8k Views 2 Watching
  • S
    shabba
    wrote on last edited by shabba
    Anyone recommend some flash for both 3 and 5v mix of mini, nanos and a few megas? Not sure whether I need spi or i2c either.
    Thanks!
    (edited title so as not to confuse people)
    • S shabba
      Thanks!
      @shabba the forum post linked from https://www.mysensors.org/about/ota has a good discussion on flash options
      • S
        shabba
        Thanks @mfalkvidd !
        • S
          shabba
          I am going to try out http://ie.farnell.com/stmicroelectronics/m95128-wmn6p/serial-eeprom-128kbit-10mhz-soic/dp/9755870
          Will report back.
          tbowmoT 1 Reply Last reply
          • S shabba
            Will report back.
            tbowmoT
            tbowmoT
            tbowmo
            @shabba
            This will not work with ota
            1. it's an eeprom, not a flash (different command set)
            2. it only contains 16k byte (128kbits /8 bits per byte)
            S 1 Reply Last reply
            • tbowmoT tbowmo
              @shabba
              shabba
              @tbowmo yes - well spotted. Would be nice to have a clear recommendation that all can use and know to work.
              • S shabba
                @shabba could you elaborate on why you can't use the recommendation from https://www.mysensors.org/about/ota ?
                • S
                  shabba
                  if you mean the AT25DF512C-SSHN-B then it is hard to find (in small quantities - I do see http://www.ebay.ie/itm/10x-AT25DF512C-XMHNB-Memory-Serial-Flash-Dual-Output-Read-SPI-104MHz-/201805447862?hash=item2efc8ac2b6:g:ks4AAOSw9GhYlJCY) and also not 5v friendly. I know I can drop voltage but I want to minimise components.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @shabba
                    As far as I can see (from search on mouser) there is no spi flashes available, which is capable at operating at 5V..
                    The closest is AT25XV021 / AT25XV041, which have an absolute maximum VCC of 4.4V
                    http://www.mouser.dk/Semiconductors/Memory/Flash-Memory/_/N-488w1?P=1z0y176Z1yzmm0hZ1yzmm18
